john stones 1 - Moderator Posted February 11, 2017 Share Posted February 11, 2017 Best plan for Iqon would be to adapt it so he could grip it, and launch under hand. Quote Link to comment Share on other sites More sharing options...
Chris Barlow Posted February 11, 2017 Share Posted February 11, 2017 Have you tried a wing tip DLG type launch? Quote Link to comment Share on other sites More sharing options...
iqon Posted February 11, 2017 Author Share Posted February 11, 2017 Posted by Chris Barlow on 11/02/2017 13:27:06: Have you tried a wing tip DLG type launch? I tried holding various ways at weekend and didnt feel comfortable enough to throw it, best way was to give somebody else....Gary threw it perfeclty, but while i was flying mine the next chap`s didnt go to plan.....It may have just been that it was a new one and hand holds slippy ?... When I get chance I am hoping to take to field with long grass and try throwing knowing it may survive my attempts, It may turn out that the sandpaper I glued on will work fine for me.. Quote Link to comment Share on other sites More sharing options...
Paul Marsh Posted February 11, 2017 Share Posted February 11, 2017 Posted by Chris Barlow on 11/02/2017 13:27:06: Have you tried a wing tip DLG type launch? If you did that, Chris, probably the wing tips will pull off. Quote Link to comment Share on other sites More sharing options...
Don Fry Posted February 11, 2017 Share Posted February 11, 2017 I made a dolly for a HK Skipper. All a bit hairy, not enough airframe mass, and I noticed that on such a small aircraft, the motor struggles to pull the extra mass. I would explore a catapult launcher first. An old club of mine used to use bits of old broken dinghy mast, with a sail slide used to guide the plane. The only mod to the plane was a flush fitted dowel across the C of G, to hook to. We were launching funfighters for combat vandalism. Quote Link to comment Share on other sites More sharing options...
Trevor Crook Posted February 11, 2017 Share Posted February 11, 2017 Donald, I'm surprised you needed a dolly for the Skipper - as said above, mine slides into the air quite happily from grass. For protection, I've put a strip of 50mm fibreglass tape along the "keel", and that probably makes it slide better. Iqon, abrasive paper will certainly help - I used 400 grade wet or dry as it's what I had to hand. Quote Link to comment Share on other sites More sharing options...
Brian Hammond Posted February 11, 2017 Share Posted February 11, 2017 I use a home made ramp for all my pushers, it,s made out of plastic drain pipe from Toolstation and Bungee cord from EBay . Just fit a hook a bit in front of the CG and retain all your fingers! Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted February 11, 2017 Share Posted February 11, 2017 A simple request for a Radjet dolly from Iqon .But .......there is always a but....I cant throw....I`ll spell it out, I`m disabled.......I always like to be Independent even when there is no need, there is not always somebody there to throw it for me and I dont feel comfortable doing it on my own and now having seen what happens when it goes wrong I want to come up with an alternative way of launching it. Iqon Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted February 11, 2017 Share Posted February 11, 2017 And he's had some simple answers Denis, a dolly is very unlikely to work on our strip, if the grass has been cut, the cuttings will stop the dolly, if it's not been cut, the long grass will stop it. John Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted February 11, 2017 Share Posted February 11, 2017 Thanks John I understand you now Methinks a model with an undercarriage would be a better answer, I will make you one up if you send me dimensions bud Quote Link to comment Share on other sites More sharing options...
iqon Posted February 11, 2017 Author Share Posted February 11, 2017 Ive got plenty with undercarriages, but this time of year I want to travel light. Thanks. Quote Link to comment Share on other sites More sharing options...
