Richard Clayton 4 Posted May 17, 2018 Author Share Posted May 17, 2018 Chris.The Lo-boy 5 with flap is how they marketed the original version (see my pics of the 2 different boxes earlier on the thread). The revamped version was still 5 channel with a central flap but the box featured this less prominently and just called the model a Lo-boy 5Edited By Richard Clayton 4 on 17/05/2018 22:06:14 Quote Link to comment Share on other sites More sharing options...
Chris Channon Posted May 17, 2018 Share Posted May 17, 2018 Cheers Richard, i am not often right !!😁RegardsChris.C Quote Link to comment Share on other sites More sharing options...
Chris Channon Posted May 17, 2018 Share Posted May 17, 2018 I am just wondering if the 1st lo-boy i built I didn't bother with the flap and on the last one I built as 5 ch.Age thing !!Chris.C. Quote Link to comment Share on other sites More sharing options...
Richard Clayton 4 Posted May 18, 2018 Author Share Posted May 18, 2018 I built my Lo-boy without the flap as I only had a 4 chanel radio back then.A good reliable Fleet Custom 111 35mhz jobbie. I was one of the first in my club on 35Mhz. A lot of the others still were on 27Mhz AM sets. Quote Link to comment Share on other sites More sharing options...
Paul james 8 Posted May 31, 2020 Share Posted May 31, 2020 An old thread but might be some of you who still have some details of the LoBoy5 perhaps? I have put a Thunder Tigre GP42 in mine and it has plenty of power, it climbs when I open the throttle so I'm thinking I need more engine downthrust. Anybody got details of what it should be please? Also might be handy to have CofG info as I've only got the model with no plans or instructions. Quote Link to comment Share on other sites More sharing options...
Nigel R Posted June 1, 2020 Share Posted June 1, 2020 For the CG, I would have thought 25% to 30% of chord would be perfectly ok, it is a very standard layout. For thrust angle, I'd just pop a flat washer under the top pair of bolts holding the mount to the firewall and see what happens. If it works better then maybe get a proper 'thrust wedge' sorted out, but the washers will tell you if it is the right mod. Quote Link to comment Share on other sites More sharing options...
Braddock, VC Posted June 1, 2020 Share Posted June 1, 2020 Just checked out the instruction sheet for the hi boy mk2, C of G 25% to 33% of chord back from leading edge. Quote Link to comment Share on other sites More sharing options...
Paul james 8 Posted June 1, 2020 Share Posted June 1, 2020 Thanks guys!! It is an older type model with wooden engine bearers so need to pack the engine itself, I made up some aluminium wedges but think the 4ba screws are a bit tight in the engine so will try to knock out the nuts from the bottom and go for 3mm. C of g seems to be pretty good at low speed so I'm prettu sure my problems are with engine thrust line. Quote Link to comment Share on other sites More sharing options...
Nigel R Posted June 1, 2020 Share Posted June 1, 2020 As another quick fix you could try packing the wing TE a bit, it would need some elevator trim compensation but would have otherwise similar result. Quote Link to comment Share on other sites More sharing options...
Alan Gorham_ Posted June 1, 2020 Share Posted June 1, 2020 Something not right there Paul... I had an older Lo-boy 5 with the ply engine mounting plate and it had no downthrust and nor did it need any. The model has a HUGE tailplane which allows you to carry a surprisingly rearwards CG (IE 33-35%) but retain solid stability. I wonder if either your CG is too far forwards or there is an error in the decalage, especially the tailplane incidence). I think that would be unlikely due to the very prefabricated nature of the kit - hard to go too wrong! Here's my old one getting wet: Quote Link to comment Share on other sites More sharing options...
Paul james 8 Posted June 2, 2020 Share Posted June 2, 2020 It flies well at low speed with no tendency to "porpoise" so I'm not sure, having looked at loads of photos of the model I don't see any that seem to have much downthrust. Mine has a slightly bigger canopy so maybe it is an early "LoBoy 5" I've got the receiver battery way up front and the Thunder Tigre should weigh at least as much as the OS 40 LA? Going to double check the c of g and see if adding a bit of weight up front might help. Quote Link to comment Share on other sites More sharing options...
Paul Marsh Posted June 2, 2020 Share Posted June 2, 2020 This is what the Turbo was. Belonged to a friend when I was teaching him back in 1994 but was killed in a car accident. The model was given to the ATC, hanging up, named the "Westwood FLyer", never to fly again. Not sure where it is now... In fact, the building it was in got built due to 4 cadets in car accidents at the time, David was in a car of 3 (all died), the other one 2 weeks apart. Edited By Paul Marsh on 02/06/2020 14:55:03 1 Quote Link to comment Share on other sites More sharing options...
Paul james 8 Posted June 2, 2020 Share Posted June 2, 2020 Posted by Alan Gorham_ on 01/06/2020 15:29:37: Something not right there Paul... I had an older Lo-boy 5 with the ply engine mounting plate and it had no downthrust and nor did it need any. The model has a HUGE tailplane which allows you to carry a surprisingly rearwards CG (IE 33-35%) but retain solid stability. I wonder if either your CG is too far forwards or there is an error in the decalage, especially the tailplane incidence). I think that would be unlikely due to the very prefabricated nature of the kit - hard to go too wrong! Here's my old one getting wet: Just put it all back together and checked c of g (inverted with no fuel) The chord is 9 inches and c of g 3 inches back from leading edge so 33% . I've taken out the B.A. fixed nuts and put 3mm ones in so the engine can definitely seat properly on the aluminium wedges I've made up for it. Will have to try it again when we get another fairly calm day and report back what I find. Quote Link to comment Share on other sites More sharing options...
Alan Gorham_ Posted June 2, 2020 Share Posted June 2, 2020 And did you check the wing and tailplane incidence? Like I said, mine needed no downthrust. It was a very neutral flier and it seems strange that yours needed any. I had an OS40FP fitted to mine which is probably close in power to your engine. It's hard to see why you need downthrust. Quote Link to comment Share on other sites More sharing options...
Paul Marsh Posted June 2, 2020 Share Posted June 2, 2020 Mine has a OS 40FP, but does need some nose weight, so have a large battery in the nose, as the FP is quite light. A ball raced 46 will be heavier, though the 40FP is enough for it, Quote Link to comment Share on other sites More sharing options...
Paul james 8 Posted June 3, 2020 Share Posted June 3, 2020 Posted by Alan Gorham_ on 02/06/2020 18:58:31: And did you check the wing and tailplane incidence? Like I said, mine needed no downthrust. It was a very neutral flier and it seems strange that yours needed any. I had an OS40FP fitted to mine which is probably close in power to your engine. It's hard to see why you need downthrust. I guess the Thunder Tigre GP42 is similar in weight to the OS, I personally prefer the TT, it tunes really nicely and has bags of power, way better than the 40 LA. I had a good look over the model last night and it seems to have the ailerons slightly up on both sides so I wonder if that is likely to make it lift on power? I've set them both a bit lower to more closely march the profile of the wing section, it will be interesting to see if that helps. As previously mentioned; due to the nature of the kit it is pretty unlikely that any of the incident angles are far out? There is no evidence of damage to the model. Maybe I could move the c of g a little froward from the current position, it is pretty well back at around 33% of chord. Going to see whether what I have changed so far has made a difference first, never a good idea to change too many things without testing one at a time. Quote Link to comment Share on other sites More sharing options...
Krister Westergren Posted August 28, 2022 Share Posted August 28, 2022 Hi all, is it possible to but a low boy today? I think it was made by Precindent when I was young. Regards Krister PS unbuild Quote Link to comment Share on other sites More sharing options...
Krister Westergren Posted August 28, 2022 Share Posted August 28, 2022 Hi all, is it possible to buy an Low Boy, unbuild. I think it was made by Precident. Quote Link to comment Share on other sites More sharing options...
kc Posted August 28, 2022 Share Posted August 28, 2022 (edited) No. The Low Boy was one of the Precedent ( note spelling) range that eventually became part of SLEC but they don't list it now. You might try Ebay to see if one comes up. There are probably better models to build though - consider the SLEC Funfly. Or look at the Phoenix Model Products Pepperpot. Somebody got a HiBoy used model on EBay for £4.99 this week......so it's worth looking. Edited August 28, 2022 by kc Quote Link to comment Share on other sites More sharing options...
kc Posted August 28, 2022 Share Posted August 28, 2022 Check EBay for Precedent there is a Low Boy kit with one hour left to bid! Quote Link to comment Share on other sites More sharing options...
Chrissz Posted March 5 Share Posted March 5 Great memories I have just built a Hiboy Turbo. This was my first RC aircraft back in the 1990s I have used Futaba sky sport 6A on 35 MHz. And an OS 46 LA. It flys great. Had its maiden flight last Sunday. 3 Quote Link to comment Share on other sites More sharing options...
Murat Kece 1 Posted March 5 Share Posted March 5 Well done. Very nice. 1 Quote Link to comment Share on other sites More sharing options...
PDB Posted March 6 Share Posted March 6 8 hours ago, Chrissz said: Great memories I have just built a Hiboy Turbo. This was my first RC aircraft back in the 1990s I have used Futaba sky sport 6A on 35 MHz. And an OS 46 LA. It flys great. Had its maiden flight last Sunday. Lovely job, very nice looking model 👍👍 1 Quote Link to comment Share on other sites More sharing options...
John Minchell Posted March 8 Share Posted March 8 What a superb flying site you have there. Where is it please? John M Quote Link to comment Share on other sites More sharing options...
