Closed loop...
I bought a second hand Pilot Extra, been setting it up and have come to a grinding halt after faffing for 2 days. The closed loop isn't right and I'm lost as to what to do ? Rudder centers with a right clatter when actuated, it's so bad I reckon It'll cause damage. Wires cross because they'd foul the formers otherwise, take the cables off the servo, move it by hand it's fine (tension on both cables) ? I believe I understand what's wrong, but don't know the solution (bigger horn on servo)? Help please. sad
HI John,
I surely would like to help but I'm afraid not to be able to.
One thing I've been reading on different occasions is to use a servo arm connected to a 'slave' straight bellcrank/horn to release any load from the looped wires to the servo.
No idea with the 'crossed' wires though.
Sorry, young man...
Chris
3 things occur to me with your set up.
1) Ideally the servo arm length should be the same as your rudder horn size. In your case 60mm.
2) If you are still using 35Mhz it pays to make sure the two cables are not touching as that can cause glitching. Not sure about 2.4 but to make sure anyway I always use nylon covered fishing trace. Because I have several varieties of trace as long as one is nylon covered all is ok.
3) Have you too much tension in your cables?
HTH
Maxg
Hi John,
As with above suggestion, do the control wires touch at the crossover point and are they insulated?
If they do touch I'd suggest a slight vertical offset to avoid this. Also if they have been touching is there any evidence of chaffing.
If you reduce the size of the servo arm can you achieve a straight cable run?
Good Luck
Alex
The problem is, I think, your linkage is 10 mm behind the hinge. And as it swings, the distance alters. Hence the clatter, and tensions altering.
Try bolting on a pair of 10 mm extensions to the ruddder arms, to put the movement point in line with the hinge.
By bolting, I mean altering the shape, so it's in line, and bolted as in rigid. I think the original arm should have been a different shape, ending in line with the hinge.
Edited By Don Fry on 23/02/2020 19:34:56
Yes the connection to the horns HAS to be on the hinge line or geometry is wrong, that’s why rudder control horns angle forward.  I got that wrong once on my LA7 and initially had awful rudder flutter until I fixed it and lined up the connection with hinge line. If the connection isn’t on the hinge line the line that is supposed to be slackening releases at a lower rate than the line that is pulling .. so the wires are “fighting each other “.
Edited By Tim Flyer on 23/02/2020 20:04:25
Edited By Tim Flyer on 23/02/2020 20:08:18
Models sat on a chair, so no pressure from the wheel, I disconnected it looking for the problem, the rudder horns will clash with the elevator if I alter them, however they t/planes removable so i can remove some elevator, just want to be sure of a cure before I cut anything. Rudder horns are f/glass insets those can be cut off and h/duty ones bolted on.
Edited By john stones 1 on 23/02/2020 20:08:40
Posted by Tim Flyer on 23/02/2020 20:12:33:
what you’re set up is doing is making a “ virtual “ pivot point 10mm back from the actual one. That’s why one wire will try to over extend when the rudder moves
I agree, I want reassurance before I commit surgery, fitted many a closed loop, never encountered this before.
Hmm quite difficult space wise . One solution is using a a disk servo arm . Then you could set both pivot points a bit towards the nose of the aircraft that would mean the pulling wire will not overtake the releasing wire . You might need a large disk .
Edited By Tim Flyer on 23/02/2020 20:26:02
