Nigel R Posted August 12, 2020 Share Posted August 12, 2020 Hi all Perhaps someone has done this before. I have several engines (some old style Irvine 46s and OS 46 SFs) I am tidying up as a bit of a background project. One or two of them have discoloured aluminium. Has anyone used any paint, successfully, on engine blocks? I did think initially of the usual automotive answer, Hammerite, but is it resistant to glow fuel? Thanks! Quote Link to comment Share on other sites More sharing options...
Dale Bradly Posted August 12, 2020 Share Posted August 12, 2020 How timely you asked! I have no idea, but am about to find out. Recently gave me old Sig Somethin' Extra an overhaul, which included giving the OS 46FX a coat of gloss black powdercoat. The powdercoater reckoned it will do it no harm, and possibly help shed some heat better than plain aluminium. Plenty of fullsize, and Saito engines, have it done. It looks the part, and owes me nothing if it doesn't work. And i got it done for free (on the proviso i report back to him on how it worked!) First engine run, and first re-test flight as early as this coming weekend, I'll report back when done. Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted August 12, 2020 Share Posted August 12, 2020 If you have access to spray equipment then automotive 2K paint baked on works well . I have painted a few over the years and all have lasted well. Rustoleum Hard Hat Paint in aerosols is also highly resistant to glow fuel if baked on. The discoloured cases can be reinstated to virtually AsNew by bead blasting ,now my preferred method. Any painted parts will need thorough clean degreasing to key properly to the alloy. Vapour blasting using soda and water also produces an excellent finish but is costly as equipment is far it's expensive than bead blasting . Some older OS engines were painted silver from new possibly to protect the alloy from discolouring. The LA engines were also painted but don't know what paint they used. All the LA engines I have done recently have been bead blasted and look great au-natural alloy. Ps the powder coat above looks good . And looks like nice light coat. Edited By Engine Doctor on 12/08/2020 10:10:20 Quote Link to comment Share on other sites More sharing options...
Former Member Posted August 12, 2020 Share Posted August 12, 2020 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted August 12, 2020 Share Posted August 12, 2020 Posted by Doc Marten on 12/08/2020 10:28:23: It's possible to anodise aluminium at home but it means handling acids, boiling water and 12v supplies if you are willing to make that decision and confident in your abilities. Cue the outrage from the safety police. Talk about safety police, in my teens the local steel storage firm would do some motor bits for me free. The parts were wired onto hooks and dipped into an open heated vat of carbontetrachloride to decrease them They were then sprayed with stoving enamel and went through an hot air oven. Most certainly fuel proof to this day, and the forerunner of modern 2K Edited By Denis Watkins on 12/08/2020 10:45:03 Quote Link to comment Share on other sites More sharing options...
Jon H Posted August 12, 2020 Share Posted August 12, 2020 I used some engine enamel from amazon on my ASP400 radial rebuild. It didnt come off immediately so i call it a win. Im not buying the line from the powder coat guy though. Any coating on top of the aluminium will act as an insulator, but i really doubt it will be enough to do any harm. Edited By Jon - Laser Engines on 12/08/2020 11:03:07 Quote Link to comment Share on other sites More sharing options...
Nigel R Posted August 12, 2020 Author Share Posted August 12, 2020 Thanks for replies, chaps, paint types noted. Posted by Engine Doctor on 12/08/2020 10:08:29: If you have access to spray equipment then automotive 2K paint baked on works well . I have painted a few over the years and all have lasted well. Rustoleum Hard Hat Paint in aerosols is also highly resistant to glow fuel if baked on. The discoloured cases can be reinstated to virtually AsNew by bead blasting ,now my preferred method. Any painted parts will need thorough clean degreasing to key properly to the alloy. That's interesting. I wasn't aware a bead blast would remove some (if not all) of the discolouration. Perhaps a bead blast might be the easy answer... Will a bead blast also take off an anodised layer? As ever, pictures, thousand words... First the SF. The staining is not too bad. The prop driver has unwanted anodising, although not a deal breaker as I have another engine with a clean driver. The worst bits: And one of the Irvines (the other is far cleaner): Quote Link to comment Share on other sites More sharing options...
jeff2wings Posted August 12, 2020 Share Posted August 12, 2020 Maybe Nigel you should take a look at some of my engine threads to see what can be done with old 'dead' engines Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted August 12, 2020 Share Posted August 12, 2020 Posted by Doc Marten on 12/08/2020 10:28:23: It's possible to anodise aluminium at home but it means handling acids, boiling water and 12v supplies if you are willing to make that decision and confident in your abilities. Cue the outrage from the safety police. Hi Doc . crank cases don,t like being anodised as they are an alloy contianing all sorts and not pure aluminium. Nigel . the dark corrosion marks may show up after bead blasting as small dips in the surface Heres a before and after of bead blasting BEFORE. After As you can see the finish is almost as new . Good luck with whatever finish you decide on . E.D. Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted August 13, 2020 Share Posted August 13, 2020 Hi Doc . Blast media is glass beads. Don't use crushed glass as it will leave surface like a fine file ! Soda crystals work OK but absorb moisture then set in a lump and need regular breaking before use. I have tried some different media but medium glass beads are best for me. They do wear out and need replacing now and again . Cost of refill is about £20 but have to buy bigger bag to get a reasonable price. Hi Barrie. It's a home unit with mods. Most important mod is the use of a cyclonic dust extractor . A small vacuum cleaner maintains a negative pressure inside cabinet that stops workshop getting smothered in dust and the cyclonic filter catches the dust before it reaches the vacuum cleaner. Other mods are a new thicker perspex top with better hinges and better rubber seal. It's a smaller unit approx 30 inch cube . It still needs lots of air so a big compressor is needed if you want continuous blast capability. Unit cost me £70 ish on eBay ,think they are about £100 ish now. Cyclonic filter is home made cost about £10 excellent bit of kit. If you are thinking about going down this route be aware it is time consuming and preparation before blasting is key to success. E.D Quote Link to comment Share on other sites More sharing options...
Nigel R Posted August 14, 2020 Author Share Posted August 14, 2020 ED that OS looks brilliant. I suspect getting into bead blasting is a rabbit hole I can't afford to go down... jeff2wings I have seen some of your merco photos, they do look great after some TLC. Quote Link to comment Share on other sites More sharing options...
Dale Bradly Posted August 23, 2020 Share Posted August 23, 2020 My black OS46FX above runs like a sewing machine, and had 4 excellent flights today with no problems at all. The motor turned heads at the club. (not just because of the colour, it was also the only IC powered model thats flown there for some time i think). Most happy with the result. Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted August 23, 2020 Share Posted August 23, 2020 Keep flying the IC flag . Our club is the same with very few IC models these days. Did the powder coat hold up ok ? Quote Link to comment Share on other sites More sharing options...
Dale Bradly Posted August 23, 2020 Share Posted August 23, 2020 Like a bought one Quote Link to comment Share on other sites More sharing options...
Steven Webb (Steve Webb Models) Posted September 10, 2020 Share Posted September 10, 2020 I just read through this thread and I’ve been messing with heat proof paint that is made for painting automotive brakes. I’ve managed to get Signal Red , Green and Matt Black and Satin Black. Another modeller pal put me onto them as he had used them to re paint the black on Mills magnesium cases and ED Racers . Some Marine Diesels also, I have used the paint on a few engines but I’ve not run any I’ve painted ( yet). I have in the last 18 months invested in an ‘industrial ultrasonic cleaning bath’. The first time I painted Diesel engine the coating of the Red painting , the paint lifted easily . I found that cleaning the engine with an additive that’s designed for cleaning car and motor bike carbs worked a treat at degreasing the engines ready for the brake paint . I’m fairly confident the paint will stand diesel fuel . Not sure about glow fuel. The ultrasonic cleaner with the carb cleaning additive makes a great cleaner / degreaser . It would work well for pre anodising treatment . It’s something else ( anodising ) I have been reading up on . I found an interesting video about anodising . I’ll try and find it and post back interesting thread Steve Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted September 25, 2020 Share Posted September 25, 2020 That's interesting. I wasn't aware a bead blast would remove some (if not all) of the discolouration. Perhaps a bead blast might be the easy answer... Will a bead blast also take off an anodised layer? As ever, pictures, thousand words... First the SF. The staining is not too bad. The prop driver has unwanted anodising, although not a deal breaker as I have another engine with a clean driver. The worst bits: And one of the Irvines (the other is far cleaner): Sorry for late reply . The anodising is best removed by dipping the part in a solution of caustic soda then a good rinse / wash in water . It will leave part a matt finish and will need re-polishing/finishing.. Bead blasting will restore all the markings on the casings to an original finish although the sides of the cylinder head are a tuned bright finish and will need spinning in a lathe if you want the original or near to original finish Re Bead blasting . Make sure that Glass Beads are used and not the cheaper crushed glass . Crushed glass produces a coarser finish that is ideal for getting good paint adhesion but slightly feels rough to the touch and seems to grab dirt making cleaning difficult. Edited By Engine Doctor on 25/09/2020 12:20:05 Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted September 25, 2020 Share Posted September 25, 2020 Posted by Steven Webb (Steve Webb Models) on 10/09/2020 15:49:40: I just read through this thread and I’ve been messing with heat proof paint that is made for painting automotive brakes. I’ve managed to get Signal Red , Green and Matt Black and Satin Black. Another modeller pal put me onto them as he had used them to re paint the black on Mills magnesium cases and ED Racers . Some Marine Diesels also, I found an interesting video about anodising . I’ll try and find it and post back interesting thread Steve Hi Steve . Re painting and Anodising . A well known producer of tuned pipes used "Rustoleum Hard Hat paint " for painting tuned pipes some time/years ago . It worked extremely well with any type of fuel but had to be baked on once dried. I have used two pack paint on a few engines that looked tatty before I set up my bead blaster cabinet and it lasted for years but casing had to be very clean and keyed with a wire brush Re the anodising and Youtube , dont even bother with trying the methods using swimming pool chemicals or various so called safe electrolytes. I have tried a lot of them and the only successful job was using sulfuric acid as an electrolyte .. regards E,D Quote Link to comment Share on other sites More sharing options...
Former Member Posted September 25, 2020 Share Posted September 25, 2020 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted September 27, 2020 Share Posted September 27, 2020 Hi Doc . You can find a DIY guide on you tube . I can do a guide when I get on the PC as my tablet is a pain to use. E.D. Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted September 27, 2020 Share Posted September 27, 2020 Hi Doc . Found this on You Tube on how to make a cyclonic filter Easier than me re wording it . I used a hot glue gun and its lasted two three years with no problems and still going strong. Another thing worth mentioning is that a variable speed vacuum cleaner or an air bleed attachment is needed to adjust the vacuum in the cabinet. I bough a 15 Ltr bucket with clip on lid off e-bay . The 20 ltr paint tubs are not tall enough and dust will be drawn into your vacuum cleaner . Get a tall bucket One thing I did change from the video was the angle of inlet pipe. I made mine enter at a more sharp angle so air and dust went around the outside of the bucket. Using this type of filter has Three main advantages . 1. It clears the dust from the cabinet allowing increased visibility while blasting. 2 The vacuum in the cabinet stops the blast media escaping and making a mess of your workshop. Try it without a vacuum and see what happens 3 It draws the majority of broken down blast media out in to the waste bucket leaving the heavier still usable media for reuse and prevents it blocking or damaging your vacuum cleaner. Dont forget you WILL need a large compressor with the gun supplied in these cabinets . They use between 10and 12 CFM at 100 psi . You can use a lower psi for a softer finish and save some air Edited By Engine Doctor on 27/09/2020 11:42:02 Edited By Engine Doctor on 27/09/2020 11:47:56 Quote Link to comment Share on other sites More sharing options...
Former Member Posted September 27, 2020 Share Posted September 27, 2020 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
