Swizzle Stick
EarlyBird
Yes the servo tubes, thanks KC.
Working on the leading edge today so to do that the board is turned around.
The leading edge has to be shaped then fitted and the bottom sheet puled up, weights will be used to stop the wing lifting. Following that all of the top sheeting and cap strips can be done.
Is the day long enough for all that, we will see.
More later.
Cheers beer
Steve
There is a wing under the batteries,
Top sheet trimmed back to the leading edge and bottom sheet glued to the leading edge.
Started the top sheeting
That's as far it got. Enough for one day I am being told.
Another good day in the workshop with plenty of practice making scarf joints. smiley
Cheers beer
Steve
Top sheeting and cap strips fitted.
Leading edge trimmed, planed and sanded.
Here is the sheeting close up.
Good enough for me. smiley
All to do again on the bottom but there is only one wing.
I have made a start by shaping the trailing edge and making a scarf joint with the trailing edge sheeting.
Cheers beer
Steve
Yes Trevor, hangar space is becoming an issue but I have a spare bedroom, just need to get rid of the bed.
As promised bottom sheeting and capstrips fitted.
Just servos and leading edge to sort out. The end is in sight, it must be as I am starting to think about covering.
Cheers beer
Steve
I was having difficulty with the servo mounting yesterday but this morning while making a scarf joint for the leading edge cap strip idea
I went with the bright idea made it up and test fitted but did not glue it as I had to go to the shops, fridge was empty.
Walking back home I realised there was a flaw in my design in that once glued in the servo could not be removed. Back home made a small adjustment and fixed it in place.
and the second one without the sheeting.
I am not sure why I sheeted it but I was enjoying myself and maybe got a bit carried away.
Cheers beer
Steve
You saw my trap and said nothingsurprise
Just adding to the fun laugh
As it happens I was going to draw the right aileron, as would be done with the wing, but then something told me I could just flip it over. To my complete surprise it obviously worked. Now I am trying to work out why this approach would not work with the wings. laugh
As this has a symmetrical wing it should work? Hmm thinking maybe not.
Thanks John,
Cheers beer
Steve
Flipping the wings over would only work if the ribs were completely symmetrical - which they appear to be in this desgn. Otherwise the 'tabs' would have to be on the top of the ribs rather than underside.
Really it's easier to just use tracing paper and trace just the ribs and spar positions with little other detail.
Yes KC I see what you mean.
Not a lot yesterday.
Just a bit of sanding and two hinges fitted, and not very good workmanship.
No rush as there is a shortage of balsa and plenty of time in the workshop now crying
Hang on what am I thinking I need to finish this and the RF-4 then there is The Ohmen waiting to be started.
Plenty to do so it's onwards and upwards today. I'll be back.
thinking too many film references?
Cheers beer
Steve
