Dave Smith Models
Dalesman were a supplier of foam wings - adverts at the back of RCME in the 1980's showed wings for all popular designs at good prices.    Look for the small panel size adverts in an RCME of that era.
I recently built a Duplistar from OZ plans I had reduced by a local print shop down to 63" span from 68". Wingtip shape modified. The canopy I used was one from a kit Acrowot and the cowl was vac-formed from a mould I took from a DSM Joker cowl then glassed. The wings and decking were foam cut and sheeted with balsa. The whole airframe was glassed and painted. The engine is now an OS61RFP with pipe.
Jeff,
Try the York model clubs to see if anyone can get a handle on Marvic?   Some of the more mature members of NLMFC have very long memories of things like this, even if they can no longer remember who they are (St. Michael is a common mistake) and my bet would be that if any of the previous "proprietors" of any of the participants of the '80s were still traceable, they'd be chuffed to bits that someone wants to revive a concept which they thought had disappeared for good.   They don't really have any skin in the game after all.
I'd do it but I am supposed to be working, plus there's an Anderson's Rocket waiting for spray too.
Andy S, gorgeous model.   Funny how often Acrowot canopies just seem to fit, I think I have two in similar use.   i envy the cowl, and am just wondering whether it would fit my small Excelsior and Saito 100.   Any chance of three basic dimensions with a view to renting the plug off you?
Bruce
  • Haha 1
16 minutes ago, Bruce Collinson said:
Bill Manley/Bill Kits has done Excelsior wings for a couple of us recently and therefore has the patterns.   As several of us are clearly fans of these models (they all seem to fly well) and JC's contact NJR Models appears to have an appetite to re-kit them, I'm asking myself:
1)    Should the likes of Bill Manley be asked for info on the previous kitters, who probably outsourced foam wing production
2)    If the issue is one of registered design rights, if they are registered this ought to be in the public domain and they automatically expire, I think after 25 yrs and if unregistered then sooner (I'm not a real patents attorney though) but when did anyone hear of the boy-band type litigation where a model aeroplane is concerned?   Or, get the Chinese to make them because they do not seem to be bound by arcane ideals like copyright and counterfeit laws.   I'd rather they were made here or in the Czech Republic or Germany, France even, albeit at a higher price.
I fear this is crossing with Jeff's replies as I was interrupted in mid-flow.
BTC
Hi Bruce
Not crossing with my replies at all. Could use all the info I can find.
Good thought about BillKits. might give him a call. If nothing else, if Nick does decide to go ahead he will have to get his foam wings made somewhere, why not Bill.
As regards rights to the designs. You're probably right that these would have lapsed, but I think Nick is right to try to find out who has those.
Not only is it the gentlemanly way to conduct business (we're not chinese after all) but also to produce kits he would need the original drawings, since the DSM products were not supplied with plans.
The search goes on
Jeff
Well Bruce may not have heard of copyright court cases for model aircraft,  but in the 1980's or 1990's all the talk at one of the shows was of the copyright case where one model aircraft designer sued and even offered to settle for a reasonable amount 'at the court steps' which was refused.  The offender apparently lost the case and subsequently lost his house to pay for the matter!   It can happen!
Bruce
Bruce,
I originally made a silicone rubber internal mould of the original DSM cowl which I took several glass epoxy lay-ups from, some worked better than others. I used the best one to refurbish my DSM Joker but there are others which could be made good by a bit of fettling. You are welcome to the best of the cast-offs. I'll check the dimensions and let you know.
The canopy was made by removing it from the model as originally built and making a vac-form plug from it. I also made a plaster plug of the Acrowot canopy from which I have successfully taken mouldings.
Edited by Andy Stephenson
That's very nice.
Why the reduction? must go like, well, quickly, with a piped RF.
Cheers Andy, I'll measure mine after work/tea etc.
Judging by the old STD code on the Dalesman ad (remember when that related to telephony and not promiscuity?) that ad is very old so whilst Saltaire is just over the County Line from here I think there's no point door knocking on spec.
KC's anecdote is apposite, although my point was that any legal protection is likely to have lapsed purely by passage of time so that such Pyrrhic suits are very unlikely and for any classicists reading this, it will have been Pyrrhic because one very rarely recovers all one's costs in litigation.
BTC
All this exchange has motivated me to get my Joker 40 onto a clear bench.  Looks straightforward as fuselage already done.
Thinking OS55 with a pipe.  Yet to assess fit and manifold position etc, etc, etc.  At least now in the era of 2.4ghz I won’t be shot down like my last Joker ?
S
Hi Nigel, just a thought.
If you decide on the Rocket I have the plan over here. Bought it years ago, but I'll never get round to building one.
You're very welcome to it if it helps.
Mind you, if you really want to scare the horses, I can also do a plan for the Saxon by Dave Rumball.
This ones 2 mtr span for 1.40 engines, but uses built up wings and tail, not foam. Lot of building in it, but would be quite a beast when done.
Let me know
Jeff
