Ron Gray Posted September 4, 2022 Author Share Posted September 4, 2022 (edited) A bit of paint makes all the difference Looks OK apart from the door panel doesn't line up due to the scale of the canopy! Back onto the cowl, filled and sanded Holes cut for front pot and needle Edited September 4, 2022 by Ron Gray 3 Quote Link to comment Share on other sites More sharing options...
Peter Jenkins Posted September 4, 2022 Share Posted September 4, 2022 Good work Ron. 1 Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted September 18, 2022 Author Share Posted September 18, 2022 Not a lot of progress due to being away for a few days plus 'other' events. Exhaust extensions machined and fitted and plumbing all done. 4 Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted September 19, 2022 Share Posted September 19, 2022 Don't worry about progress, just seeing that lovely work of art in the morning is a nice way to start the day. Quote Link to comment Share on other sites More sharing options...
Piers Bowlan Posted September 19, 2022 Share Posted September 19, 2022 Beautiful work Ron, it will look and sound amazing. If I may ask a silly question, do you think the rear cylinder may get a little warm in there, or am I missing something (probably)? Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted September 19, 2022 Author Share Posted September 19, 2022 @Piers Bowlan without correct ducting in the cowl it will cook! The idea is that the incoming air is forced to the ‘cool’ side of the engine by blanking off part of the intake. The air is then channelled through the cylinders by ducting. The hot air then escapes through the firewall holes, into the fuse where it can exit through an opening above the tailwheel (although I maybe changing that to allow it to escape through the wing into the belly rad). Some pics from my other Laser in-line installations may help explain it better. Mustang Sporster 1 Quote Link to comment Share on other sites More sharing options...
Piers Bowlan Posted September 19, 2022 Share Posted September 19, 2022 (edited) Ah ha! Thanks for that Ron, a very comprehensive answer 👍 Edited September 19, 2022 by Piers Bowlan Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted September 19, 2022 Share Posted September 19, 2022 Will you be installing a small 12v ventilator in the fuselage ?. Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted September 19, 2022 Author Share Posted September 19, 2022 @Paul De Tourtoulonthat was something I had thought about installing in the Mustang, in fact it was going to be a small edf if I found overheating problems. Fortunately no such problem with either the Sporster or the Mustang as long as they don’t sit on the ground, with the engine running, for too long! I may well have to revisit this for the Hurri! However this is the dilemma I’m now faced with the Hurri, unlike the other 2 it doesn’t have a chin air intake and elsewhere in this thread various suggestions have been given about how I could get over the problem of a lack of air intake. The fact that the front cylinder head protrudes from the cowl reinforces my thinking that converting the model to a Tropical one may be the answer as the under cowl air intake / rad will hopefully give me a chance to form a mini duct to separate incoming air to direct some to the rear pot. Obviously internal baffling will still be required. The initial flights will be made (this week?) without the cowl in place to make sure the motor is running OK Quote Link to comment Share on other sites More sharing options...
Peter Jenkins Posted September 19, 2022 Share Posted September 19, 2022 How about a NACA intake? Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted September 19, 2022 Author Share Posted September 19, 2022 Placing one behind the front pot would work but would lose some efficiency as it would be on the ‘slope’ of the cowl underside. Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted September 21, 2022 Author Share Posted September 21, 2022 First run of the engine in the garden! Second run 3 Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted September 21, 2022 Share Posted September 21, 2022 Nice Ron, but you do frighten me switching the glows on a flooded engine with your face in the line of the prop, I always hold the prop I have had 2 and 4 strokes fire up on me when turned on and I once had a 3.5cc car 2 stroke start when I put the glow driver on it. Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted September 21, 2022 Author Share Posted September 21, 2022 Never happened to me Paul but never too late to learn from other’s ‘happenings’! Quote Link to comment Share on other sites More sharing options...
Peter Jenkins Posted September 21, 2022 Share Posted September 21, 2022 Well done Ron. Great to see the engine burst into life on the first application of the starter motor! Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted September 22, 2022 Author Share Posted September 22, 2022 Thanks Peter but it is a Laser after all! To be fair, Jon tunes the engines before they leave the factory so all a bit ‘plug n play’ really! Quote Link to comment Share on other sites More sharing options...
Nick Somerville Posted September 22, 2022 Share Posted September 22, 2022 Love the way you give the engine a few strokes before firing it up, Ron. Sounds very nice. Lots of wire dangling about your starter. Popped my battery in a simple box and mounted it below the starter. Has a nice weighty feel when offering it up to the spinner. Quote Link to comment Share on other sites More sharing options...
Nigel R Posted September 22, 2022 Share Posted September 22, 2022 (edited) 16 hours ago, Paul De Tourtoulon said: I once had a 3.5cc car 2 stroke start when I put the glow driver on it. Can do one better. I had an OS 61SF fire and start without the glow connector anywhere near it. It had run a bit rich when starting up first time. I pulled the glow stick off and a few seconds later it stopped, on compression. I presume it was simply the heat in combustion chamber that set off the partly compressed fuel/air mix in the chamber. Cue rock steady idle... "Nothing to see here, guv." Edited September 22, 2022 by Nigel R 1 Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted September 22, 2022 Author Share Posted September 22, 2022 Mine did have the JE metal frame on it but a friend reversed over it a while back nd I haven't got round to fixing it! Dangling wires will be sorted! Cor is that a scale prop in the background Nick? 1 Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted September 22, 2022 Author Share Posted September 22, 2022 Hmmm, just weighed the Hurri, 8Kg 😲 The later ESM ones (post 2016) were a lot lighter. Quote Link to comment Share on other sites More sharing options...
Peter Jenkins Posted September 22, 2022 Share Posted September 22, 2022 Hmm. going to compromise vertical performance then! Quote Link to comment Share on other sites More sharing options...
Chris Walby Posted September 22, 2022 Share Posted September 22, 2022 At 17 1/2 lbs (8kg) IMO it will fly very scale as I have not seen a full size climb vertically for long. If the inline is anything like the FT and big singles then there is plenty of grunt (torque) it will pull the hurrie along a treat. I did wince with the starting technique as it only needs to fire once in either direction and the result would be painful at least. Did notice connecting the glow connectors were not powered so appreciate getting close not being an issue. IMO I don't like the use of tools as retaining devices especially on each wing as if one comes out the model will start to rotate around the other. Did it need any lead to achieve C of G out of interest, just I was surprised with my FT200/Eurobat that I needed nearly a pound of lead, but then again the inline is quite a bit heavier? Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted September 22, 2022 Share Posted September 22, 2022 Watch carefully the video Chris as he leans over to turn them on,,, Quote Link to comment Share on other sites More sharing options...
Peter Jenkins Posted September 22, 2022 Share Posted September 22, 2022 Chris, the issue of power is so that you can fly a decent loop without the model's airspeed decaying too much. I flew a 60 size Spitfire that had an OS91 FS and that would not even do what a full size Spit could - loop from horizontal flight! I had to divebthe aircraft to pick up speed first. I know that full size could not do vertical climbs forever but apparently a well flown Spit could pull to the vertical and do 3 rolls and recover without stalling. That's in Bader's book Reach for the Sky. Bader hadn't msnaged it but the expert aerobatic pilot in the Squadron did. I don't know if the Spit was fully armed and no ammo could make a big difference to vertical performance. I suspect it might have been armed as during wartime even just doung a bit of continuity flying they probably didn't want to get csught in the air unarmed. Quote Link to comment Share on other sites More sharing options...
Jon H Posted September 22, 2022 Share Posted September 22, 2022 6 minutes ago, Peter Jenkins said: I flew a 60 size Spitfire that had an OS91 FS and that would not even do what a full size Spit could - loop from horizontal flight! I had to divebthe aircraft to pick up speed first. oof. I would expect an 80 to pull a 60 size spit all day long. Your 90 must have really been on the struggle bus, that or the model was mega heavy. I would not expect the 200 to be short on power even if the hurricane is 20lbs. Sure it wont have infinite vertical, but the 240v in my 23lb 88inch hurricane offers me more than enough power for scale hurricane flight. If it were a sea fury it would be another story, but its fine in the hurricane. Quote Link to comment Share on other sites More sharing options...
