Ron Gray Posted October 26, 2022 Share Posted October 26, 2022 Looks like you can angle the retracts back quite a bit in the existing wells, surprising how just a couple of degrees will help! Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted October 27, 2022 Share Posted October 27, 2022 (edited) Yes I have but only about 2mm, so I stuck another 5mm of ply under the mountings which only just gives enough play, I don't know how the original wheels will fit as they are 3mm bigger and 2mm thicker, unless you grind ( sand ) the 'tyres' down,. the flaps were fitted using the flat plastic hinges fixed with a drop of cyano and powered by two Corona 939MG servos, the Ailerons were fitted using sanded down ( for grip when gluing ) and a drop of Robbe silicone oil to keep the epoxy out and nice and free, Futaba S-U300 fitted, wires everywhere but that is for tomorrow all will be soldered, I don't like servo plugs rattling in the wings so they will be soldered to a Multiplex plug to dismantle the wing. Edited October 27, 2022 by Paul De Tourtoulon Ps servos mounted with differential throws. Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted October 27, 2022 Share Posted October 27, 2022 Couldn't you do this? Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted October 27, 2022 Share Posted October 27, 2022 That's exactly what I did do, I gave it a couple of degrees to the rear. Quote Link to comment Share on other sites More sharing options...
Jon H Posted October 27, 2022 Share Posted October 27, 2022 although it would be more work are you able to make the gear swing back like on the full size? I dont know if the spar is in the way Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted October 28, 2022 Share Posted October 28, 2022 11 hours ago, Jon - Laser Engines said: although it would be more work are you able to make the gear swing back like on the full size? I dont know if the spar is in the way To much bother, if it was winter and un-flyable and I had read a build like mine on the Seafire I would probably have fitted the retracts like the real one, at the wheel end you can cut the hole back 23mm, if this helps the next builder.😇 A quick test on Y leads of the servos on a Futaba 617rx, I did this as at the model field a couple of club members have had problems with two rtf Epp Cub type models on dare I use the word, spectrum radios where the just wont work on Y leads one would jitter all over the place ( nothing to do with Bill Haley ) needing a separate channel for each flap and ailerons. Quote Link to comment Share on other sites More sharing options...
Jon H Posted October 28, 2022 Share Posted October 28, 2022 I use y leads all the time as its simple and it works. I do however avoid y leads that have a soldered joint wrapped in heatshrink as these are very easy to damage. I look for the type with a solid plastic block around the Y as this support and protects the joint from being damaged. Bad type good type The solid block prevents the two arms of the Y being tugged apart, cracking the solder. 1 Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted October 28, 2022 Share Posted October 28, 2022 All the extensions are soldered, maybe one of my own Y leads for the retracts, the wires will be collectively soldered to the Multiplex 6 contact plugs so no Y leads for the flaps or ailerons, I was getting the wings ready to glue together ( PU glue ) when I noticed tome marks on the film on the extrados where the aileron servos are, bumps where the servos are, when the glue is hard ( tomorrow ) I will have a look to see what part is touching and rectify them. Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted October 28, 2022 Share Posted October 28, 2022 Futaba 300 servos at 20mm wide wont pass so find yourselves something thinner, 1st bodge, 4 squares of 1mm ply to lift up the ply aileron servo mountings, problem solved.🤒 Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted October 28, 2022 Share Posted October 28, 2022 Wiring done in a cloud of mosquito's,,,🤒 Quote Link to comment Share on other sites More sharing options...
David Ovenden Posted October 28, 2022 Share Posted October 28, 2022 55 minutes ago, Paul De Tourtoulon said: Wiring done in a cloud of mosquito's,,,🤒 Nice work Paul. Amazing that you kept the soldering iron steady with all those Mozzies about! Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted October 28, 2022 Share Posted October 28, 2022 Yes a real head ache, and my next problem was getting 2 pack polyurethane mat varnish my local supplier does not sell the amount that you need only 2 kilos at 200€ 😮, I have the hardener and varnish but no matting agent, maybe talc or micro balloons ?. Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted October 29, 2022 Share Posted October 29, 2022 I just read the instructions, 4 spectrum A6330 servos for the wings, they are too wide and at silly prices 🤢 A reminder to do a radio check engine running, an Extra 260 of around 2.2metres with it's Dle 55cc engine went haywire after take off yesterday and luckily it didn't injure anyone just itself, a total right off and no I wasn't there to check it 😇 I was riding my motorbike in the hills,,, Quote Link to comment Share on other sites More sharing options...
GrumpyGnome Posted October 29, 2022 Share Posted October 29, 2022 That's really bad practice - an expensive lesson learnt. Hopefully damage was limited to just the model..... Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted October 29, 2022 Share Posted October 29, 2022 26 minutes ago, GrumpyGnome said: That's really bad practice - an expensive lesson learnt. Hopefully damage was limited to just the model..... Pride and temper,,,I was told at the model field today that in the week he was flying his 800 class electric helicopter inverted, the motor stopped and he did a half flip and suddenly the motor re started nothing broken not enough of a lesson, 😮 I flew my Enya 120 4c 3 flights and way too much power so I think that I am going to settle foe a Saito 82b at 300€ over here The 100 seems as powerful as the Enya so probably overkill..,,, Sorry but Brexit is too much hassle for a Laser,,, sorry Jon. Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted October 29, 2022 Share Posted October 29, 2022 Opps already too late to Edit, It is a warbird and I will be fitting the carb with a proportional servo so It will be a Saito 100 329€ here post free,, Looking at my other 2 Spitfires one with the Enya 120 4c the other with an Enya 90 4c the 90 does fly well. Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted October 31, 2022 Share Posted October 31, 2022 (edited) 😵Look before you leap !🤢, I jumped the gun 'again' and cut the wheel fairings on the lines, as you can see 'if' I had left another 4mm I could have fixed ( with some reinforcement ) to the screw on the bottom of the leg, the so call fixations for them are four crude lumps of wood, I have a lump of plastic ( no 3D printer ) so a bit of cutting work to be done. Edited October 31, 2022 by Paul De Tourtoulon think carefully before answering Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted October 31, 2022 Share Posted October 31, 2022 28 minutes ago, Paul De Tourtoulon said: the screw on the bottom of the leg, Isn't that on the lower part of the oleo which moves up and down? 1 Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted October 31, 2022 Share Posted October 31, 2022 Yes Ron, obviously you haven't been asleep,,, Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted November 1, 2022 Share Posted November 1, 2022 A bit messy, I reinforced the wheel fairings inside down the leg and a bit at the top where the screws are with some f/glass and epoxy and then drilled and tapped out the legs, 2 x 3mm screws to hold them in place, and the oil radiator ducts are glued in place with cockpit glue. Quote Link to comment Share on other sites More sharing options...
Eric Robson Posted November 1, 2022 Share Posted November 1, 2022 Hi Paul, should that detail not be on the inside of the leg? The Spitfire was plain on the outside of the fairing. Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted November 1, 2022 Share Posted November 1, 2022 It is, go back 5 posts,,, Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted November 1, 2022 Share Posted November 1, 2022 I picked up a Saito FA 100 for a 100€ as usual he couldn't start it so I said I would have it for 100€, he took it out of the plane on the spot, It has been repaired my me a few ( 3 ) times in his crashes and it doesn't have a silencer,,, Here is the french modiste at work,🤣 I flew my Skyraider today, Marine K & B with the pylon racing Perry carb. Quote Link to comment Share on other sites More sharing options...
Eric Robson Posted November 2, 2022 Share Posted November 2, 2022 This is what I meant by the detail on the other side, the side opposite the wheel is smooth Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted November 2, 2022 Share Posted November 2, 2022 Yes but it's an artf, I just can't be bothered,,, I am Stripping the Saito down, the main needle valve was really bent obviously from another crash and full of 'bits', straightened out on my small lathe with the help of a blowlamp and cleaned out, valve gear next and a trip to a friendly neighbour model friend to open out my OS silencers to the 12 x 1 thread for the Saito. Quote Link to comment Share on other sites More sharing options...
