Paul De Tourtoulon Posted November 19, 2022 Share Posted November 19, 2022 I through it together this morning, only the pilot and cockpit to put in place, 4 Kilos 400, and the balance point is at 12.5cm "maybe" a 100 grams for the first flight although there will be 300 grams of fuel in it, any thoughts ?. Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted November 20, 2022 Share Posted November 20, 2022 (edited) No pictures as I am ashamed to say that for once I am not painting the decoration on it 🤐 anyway the cockpit isn't the right one, not forgetting it isn't very scale.,,, On second thoughts,,, Stick the SX336 on the bottom of the wing before the roundels and the 'Royal Navy and 105 ones also before the roundels, or you will end up like me a bit squeezed up. Not the original pilot, and a perfectly balanced APC 14x 8 for the Saito. Edited November 20, 2022 by Paul De Tourtoulon second thoughts. Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted November 21, 2022 Share Posted November 21, 2022 I saw somewhere that you could give your model a mat finish using wire wool and / or wet and dry, You Can't, it's a complete waste of time, I will wet and dry it to key in the mat varnish. Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted November 21, 2022 Share Posted November 21, 2022 (edited) Try Scotch Brite or a pan scourer, it does work but does take some time and you have to remember that you are scratching the surface! Edited November 21, 2022 by Ron Gray Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted November 22, 2022 Share Posted November 22, 2022 A real rubbish finish, so I sprayed it with a mat varnish yesterday with my new 100€ 220v compressor ad 2 spray guns with it a really good buy, and what a difference !🥳 compressor kit, https://www.manomano.fr/p/kit-compresseur-airbrush-professionnel-avec-2-pistolets-731105?model_id=731103 3 Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted November 22, 2022 Share Posted November 22, 2022 Looks a lot better now! Quote Link to comment Share on other sites More sharing options...
Jon H Posted November 22, 2022 Share Posted November 22, 2022 Dont go too mad. Most carrier aircraft had gloss paintwork as it was easier to wash the salt off them. Quote Link to comment Share on other sites More sharing options...
Ace Posted November 22, 2022 Share Posted November 22, 2022 Looking much nicer after the rub down 👍 Quote Link to comment Share on other sites More sharing options...
David Ovenden Posted November 22, 2022 Share Posted November 22, 2022 Nice work Paul. What matt varnish did you use in the end? Quote Link to comment Share on other sites More sharing options...
Eric Robson Posted November 22, 2022 Share Posted November 22, 2022 1 hour ago, Jon - Laser Engines said: Dont go too mad. Most carrier aircraft had gloss paintwork as it was easier to wash the salt off them. I went to Fighteraces for the paint for my Seafury and asked Phil for matt, he told me to use the satin as the carrier aircraft were not matt. As the Seafury's were post war I am not sure that the Seafire's would be gloss. A few months operating from a carrier would take the shine off them. Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted November 22, 2022 Share Posted November 22, 2022 (edited) Yes I agree Eric, sitting on a sea sprayed deck I am sure that it would be mat in a couple of days if not hours, Plenty left if you need some David. Edited November 22, 2022 by Paul De Tourtoulon Got the varnish next to Leclerc Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted November 24, 2022 Share Posted November 24, 2022 All thrown together the cowling is now touching the cone for some morbid reason so a 3mm aluminium spacer was made up, balance point 12.5mm,, I will be running the engine in the garden with an APC 14 x 8 prop as I don't want to fiddle with it on the model field in front of my admirers,,🤣 as they expect me to give it a flick or two and take off with my usual big-headedness,,,🥳 3 Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted November 24, 2022 Share Posted November 24, 2022 Looking good Paul. Quote Link to comment Share on other sites More sharing options...
Ace Posted November 24, 2022 Share Posted November 24, 2022 Followed the saga - hopefully the swan fly's as good as it looks 🤞 Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted November 24, 2022 Share Posted November 24, 2022 I roughly worked out that my 12cm back balance point came to 'around' 35% of the cord, so I am going with the 10 cm on the plan it is 9cm and I read 'somewhere that it was 11cm, and with loads of lead at J Perkins they announce 4 kilos, maybe the Fairies believe them but not me, so tomorrow "Lead" and 250 grams of fuel in the tank with some engine running for the neighbours,,, Quote Link to comment Share on other sites More sharing options...
David Ovenden Posted November 24, 2022 Share Posted November 24, 2022 We should get my Seafury and your Seafire flying at the same time. The 2 Saitos would sound good together. 1 Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted November 25, 2022 Share Posted November 25, 2022 Rough maths, 10cm = 26% good enough for me, now for the lead,,, Quote Link to comment Share on other sites More sharing options...
leccyflyer Posted November 25, 2022 Share Posted November 25, 2022 Very nice - love that colour scheme with the big red spinner. 🙂 Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted November 25, 2022 Share Posted November 25, 2022 It should be black, maybe I will change it later on. Taped and elastics holding the piece of triangular balsa on the balance point, a couple of buckets no 100€ balancer for me 🤣 a tape measure ( 160 grams ) to compensate for half a tank of fuel and 310 grams of lead to get it right, announced weight 4 kilos, but nearer the 5 kilos,, Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted November 25, 2022 Share Posted November 25, 2022 Not Einstein's work or Salvador Dali but it does the job, all steel with a 130g lead sandwich easy to remove a bit at a time if needed. Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted November 27, 2022 Share Posted November 27, 2022 Well that was an anti climax, a couple of clicks here and there for the trim, it is slightly nose heavy but really fly's well so other than reducing the servo throws not much to say except a real Helicopter landed on the model field, and did a couple of low passes after taking off. It's in the background spinning up,, 2 Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted November 27, 2022 Share Posted November 27, 2022 Good to hear it went well Paul. Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted November 27, 2022 Share Posted November 27, 2022 Thanks Ron the Saito 100 with the OS .70 surpass silencer is perfect, performance and sound. Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted January 7, 2023 Share Posted January 7, 2023 My one pot polyurethane is coming off of the bottom of the engine cowling end the centre of the wing, so I will clean the bottom off revarnish it with 2 pot polyurethane and matt it down with wet and dry, still looking for a cheap 75/100 Laser to fiddle with. Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted January 8, 2023 Share Posted January 8, 2023 My Saito 100 has been throwing props when starting and even warm translating from a fast idle to about 5.000 rpm, I shimmed the cylinder with 0.3mm aluminium printing plate, it did the job, 2 tanks and both times dead stick landings as I was having so much fun, I also plugged in the second electric retract to canal 7 with a '20' servo delay mixed with canal 5 to make them retract like a real plane. Quote Link to comment Share on other sites More sharing options...
