Martin Dance 1 Posted January 19, 2023 Share Posted January 19, 2023 I use the Titebond range of adhesives both for model making and conventional woodworking (furniture making). I've tried most ready to use adhesives and find that Titebond overall is the best, certainly the most reliable. Sources in the UK Axminster Tools, Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted January 19, 2023 Share Posted January 19, 2023 Something that isn't a daft price, don't care if it's 20 stronger than the wood, stronger and a little flex does it for me, mostly Evo green bottle. 1 Quote Link to comment Share on other sites More sharing options...
Ace Posted January 19, 2023 Share Posted January 19, 2023 Evo-stik blue (waterproof) on a Wot 4 kit that may be used as a float plane. Good performance but ever so slightly rubbery when sanded. 5 Star Aliphatic (yellow tint) which soaked well into end grain on pre treated joints and sanded better than PVA. Someone recommended Gorilla wood (off white) as it was supposed to sand better than std PVA's - have some but not yet tried, anyone tried it yet? Quote Link to comment Share on other sites More sharing options...
Eric Robson Posted January 19, 2023 Share Posted January 19, 2023 I always used Evo stick but none of the local shops keep it now, they all stock Gorilla wood glue. I used some a while ago and was not impressed, however I tried again and on two pieces of 1/4" balsa I clamped together left overnight, a senior moment, I glued them in the wrong place. Despite all efforts they were only parted by destroying the smallest piece. I have found the Gorilla wood glue sands well when planking. Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted January 19, 2023 Share Posted January 19, 2023 Consistent good results using Gorilla Glue white and clear but the latter hasn’t got a fast grab time. Excellent sanding results and the white dries clear so good for canopies and ‘glassing’ dials on an instrument panel. For smaller models it’s Super Phatic and an occasional bit of CA.. Quote Link to comment Share on other sites More sharing options...
dave parnham Posted January 20, 2023 Author Share Posted January 20, 2023 interesting Ron about the canopies, I've never gotten on well with canopy glue funny that ! Quote Link to comment Share on other sites More sharing options...
Ace Posted January 20, 2023 Share Posted January 20, 2023 @Ron Gray Quote white dries clear so good for canopies and ‘glassing’ dials on an instrument panel Are you referring to the Gorilla White wood glue or the Clear ? Have not tried the White for glazing although I have found the clear a good replacement for canopy glue, only issue its not as easy to see where its placed being clear when wet. Quote Link to comment Share on other sites More sharing options...
John Lee Posted January 20, 2023 Share Posted January 20, 2023 So many Gorilla products! I tried this & did not like it, I found the consistency too thick. With 4/5ths of the bottle left I went back to Titebond. Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted January 20, 2023 Share Posted January 20, 2023 The easiest way to apply GGW is not from the container! I squeeze out an amount into a small plastic cup or even onto a plastic lid then apply using a spreader (ice lolly stick). That way you get an even, thin, layer of glue exactly where you want it. The GGW dries clear so that is what I use for a canopy glue or instrument glass. Quote Link to comment Share on other sites More sharing options...
Ace Posted January 20, 2023 Share Posted January 20, 2023 Cheers Ron 👍 Quote Link to comment Share on other sites More sharing options...
dave parnham Posted January 24, 2023 Author Share Posted January 24, 2023 Final one from me on this topic, i have never gotten on well with Canopy glue but thinking about Ron's advice i put some in a saucer and left it for about 10 mins or so while i masked up the airframe on the Beast 60E and made sure glue didn't run everywhere. Then i applied it to the airframe with a paint brush, its always seemed too runny to stick to anything in the past, but turns out the best Canopy I've ever stuck in place. Shame i put the job off last summer. 1 Quote Link to comment Share on other sites More sharing options...
Trevor Crook Posted January 24, 2023 Share Posted January 24, 2023 Another vote for Gorilla wood glue, as said above you don't have to apply it from the bottle. I often use a combination of wood glue and cyano. I run a bead of wood glue, leaving small gaps into which I put drops of medium cyano. If held together briefly this avoids using pins. Using purely cyano is expensive and I find the joints a bit brittle. I too haven't had much joy with canopy glue, so I use UHU Por, which seems to grab and stick much better. It is a bit stringy, but cleans off of acetate nicely using meths. It's also foam friendly if that's relevant to the job. Quote Link to comment Share on other sites More sharing options...
