Exhaust dent removal
John Minchell
The pipe part should be easy if you can get a rod along to the  dent. The canister is a bit of a problem though . The dent shouldn't affect its performance though just looks ugly . My only suggestion would be to drill a hole to pull or push the dent out then fill the hole with low temp Ali brazing rod the grind down the filling and polish . You can anneal the earea first by heating with a smear of soap on the area and when it turns black plunge it into cold water. This will soften the ally and make it easier to reshape.
OK - assuming the pipe is straight and with no baffles up to the point of the crease, then you only need a mandrel with a reach of, say, 180mm.  A 300mm length of 15mm dia steel rod with the end rounded to a hemisphere and mounted in a bench vice should give you enough overhang to get at the crease.  I'd try working the pipe over the mandrel by hand to start with and if it proves too stiff, then resort to the hammer.
If the pipe is baffled, then you've got no means of working the outlet dent, other than major surgery.  Rotate the pipe so it's facing the airframe 😉
Edited by Mike T
missing dims.
