Tubes for Servo Leads
I spray paper tubes with shellac, varnish, if they need it. But normally a paper tube is fine.
One point, paper does exist in heavier and tougher than the standard 90gsm stuff.
Mick Reeves Models does 0.2mm epoxy glass sheet, ProSkin. It will roll into tubes. I once made a wing, used a proskin tube for the main spar, and passed the servo wires through it. All jobs done.
Be aware, varnished rubes and epoxy sheet are sharp. Don’t get a cut wire.
Nigel, don’t know about High Street presence, but still going as a internet company. I believe Mick’s son does the manufacture nowadays. ProSkin is still available. Useful stuff for all sorts of jobs. I think it’s from the USA, used in electronics, so there might be alternative sources.
My memory is fuzzy these days - the model shop I used to visit wasn't Mick Reeves, it was Mick Charles (oops!).
