Foam model stands XL
Ron Gray
This is an extra large version of my foam model stands and is made out of 20mm EVA. The overall length is 750mm and is designed to not only hold larger models than the standard size stand but it can be fitted to a cheap (£15 ish from Amazon) music stand to provide a comfortable working height when at the field. As per the standard size one it comes with flat topped ends for you to cut out to suit or I can provide partially cut cut outs to make it easier. The hole and slots in the sides fit over the music stand ends, the slot allowing for height adjustment. Note that the hole and slot are cut to suit 25mm tubes but I can cut a different size to suit.
XL Stand with flat topped ends £30 inc P&P, U choose U cut ends £33 inc P&P
Shown here fitted to music stand (not included, neither is the model!)
  • Like 3
  • 3 weeks later...
Following a request from fellow forumite, @Ace, I have made extended end pieces for the stand which will allow them to be used for working on a model when on the bench. The length is sufficient to keep the fin off the bench (for most models!) when inverted in the stand but are not so big that they become 'floppy'. Shown here is my YT Mustang held in the stand.
These are available at £12 pair (inc P&P) or for an additional £9 when ordered with a stand.
Edited by Ron Gray
  • 2 months later...
Just picked up one of Ron's excellent XL stands, nice height, you could tweak it if taller or shorter.  I opted for the taller work bench end version  but also got the original end panels. Stand from amazon was £7 plus P+P.
I looked at the slec offering but £60 plus p+p for a unfinished wood jobby that looks as though it came from the early 1900's wasnt going to cut the mustard.  (was £79 when I last looked a few weeks ago, so selling well!)
Edited by Frank Day
missed something
Thanks Frank, looks good!
PS It's the HD stand (I'm not making the std or the XL one anymore due to foam supply issues plus this one will support much heavier models).
Edited by Ron Gray
  • 1 month later...
  • 3 weeks later...
This topic is now closed to further replies.
