Martin Harris - Moderator Posted April 29, 2023 Share Posted April 29, 2023 To save re-inventing the wheel, I don't suppose you have uploaded it [or would upload it] to Thingiverse or similar? Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted April 29, 2023 Share Posted April 29, 2023 And for those difficult to reach ones: 1 1 Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted April 29, 2023 Share Posted April 29, 2023 (edited) 10 minutes ago, Martin Harris - Moderator said: I don't suppose you have uploaded it No problem Martin, I’ll put them on the ITAT forum. But for those without printing facilities I can sell them for a £1 for the pair, plus P&P. It would be far more cost effective if a club placed a ‘bulk’ order as that would substantially reduce the cost per unit. Or if anyone who wants some and are going to Old Warden I can take some with me. Edited April 29, 2023 by Ron Gray 1 Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted April 29, 2023 Share Posted April 29, 2023 Link to the STL https://itat-forum.bmfa.uk/share-your-3d-printing-files/clevis-tool#post-490 1 2 Quote Link to comment Share on other sites More sharing options...
Graham Bowers Posted April 29, 2023 Share Posted April 29, 2023 29 minutes ago, Ron Gray said: Well we are a community and there are 3D printer owners, me being one! As a result I just knocked up this one for either 2 or 3mm clevis: Neat, I was planning to do the same as I always have screwdriver near misses and this thread has been a revelation. (I didn't fancy paying out for the Nexus ones). Is yours printed in PLA? Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted April 29, 2023 Share Posted April 29, 2023 PETG Quote Link to comment Share on other sites More sharing options...
Graham Bowers Posted April 29, 2023 Share Posted April 29, 2023 Thanks. Not tried that yet. Quote Link to comment Share on other sites More sharing options...
Graham Bowers Posted April 29, 2023 Share Posted April 29, 2023 26 minutes ago, Ron Gray said: Link to the STL https://itat-forum.bmfa.uk/share-your-3d-printing-files/clevis-tool#post-490 Thanks, very kind. I'll give it a go. I'll probably find out for myself however will ask a question about it's use. It's easy to see how the clevis is opened however quite often, if the clevis pin is a neat fit in the hole, I find it necessary to lever the clevis off the control horn when using the improvisation methods I've used up to now. Is there a sleight of hand trick that one uses with this, or any of the other tools for that matter, to pull the pin out of the horn if it's not a rattling good fit? Quote Link to comment Share on other sites More sharing options...
Peter Jenkins Posted April 29, 2023 Share Posted April 29, 2023 4 hours ago, Bruce Collinson said: £45 seems a bit steep. Paul d T, I have tried with a ground down screwdriver but it can slip too readily. At $3 US, if I get my son to bring a handful back from L.A. in June, is there an appetite for the proper Sullivan ones? BTC Count me in Bruce. When I used to visit the USA regularly on business I always dropped by the Hobby Shops to see what useful low cost gizmos there were. There was a plastic gizmo that you could use to help wind plastic ball joints onto the threaded shaft. If he could get some of those I'd be up for one. Can't find the one I bought and I miss it sorely! Quote Link to comment Share on other sites More sharing options...
John Lee Posted April 29, 2023 Share Posted April 29, 2023 1 hour ago, Peter Jenkins said: There was a plastic gizmo that you could use to help wind plastic ball joints onto the threaded shaft. If he could get some of those I'd be up for one. Can't find the one I bought and I miss it sorely! I think that would be the Great Planes 4-in-1 tool Peter. Again they seem to be mostly out of stock but it is listed on Amazon UK, albeit it will come from Amazon EU so it carries a premium & 4-6 weeks delivery. I'm keeping both of mine! 1 Quote Link to comment Share on other sites More sharing options...
John Lee Posted April 29, 2023 Share Posted April 29, 2023 These could be another candidate for 3D printing. Here is an idea of the dimensions: Quote Link to comment Share on other sites More sharing options...
Bruce Collinson Posted April 29, 2023 Share Posted April 29, 2023 All, I have a couple of PMs in addition to the above. When LA wakes up I'm hoping to hear that three I found in Hicksville at under $2 are ordered, then in a week or so I'll place another order for the rest and see if the boy is up for posting them. If not he's back in June. I have a pair of those ball drivers Peter, different sizes, bought from MS Leeds I recall. If you (or anyone else) wants to specify the item, ideally a hyperlink to a US source, I'll add them to the list. Pro tem, Ron, I'd like one of each of yours but I'll rustle round the boys at the Fun Crash on Monday and try to bulk up the order a bit. Many thanks in advance. BTC Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted April 29, 2023 Share Posted April 29, 2023 3 hours ago, Graham Bowers said: Is there a sleight of hand trick that one uses with this, The ones that I've 3D printed open the clevis even if they are 'clicked' together. However, if the clevis pins is a tight fit in the control horn then you will still have to ease it out. I don't think that any clevis tool can do that unless it uses the control horn as a leverage point. 1 1 Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted April 29, 2023 Share Posted April 29, 2023 6 minutes ago, Bruce Collinson said: Pro tem, Ron, I'd like one of each of yours but I'll rustle round the boys at the Fun Crash on Monday and try to bulk up the order a bit. Many thanks in advance. 👍 Quote Link to comment Share on other sites More sharing options...
Peter Jenkins Posted April 29, 2023 Share Posted April 29, 2023 5 hours ago, Bruce Collinson said: All, I have a couple of PMs in addition to the above. When LA wakes up I'm hoping to hear that three I found in Hicksville at under $2 are ordered, then in a week or so I'll place another order for the rest and see if the boy is up for posting them. If not he's back in June. I have a pair of those ball drivers Peter, different sizes, bought from MS Leeds I recall. If you (or anyone else) wants to specify the item, ideally a hyperlink to a US source, I'll add them to the list. Pro tem, Ron, I'd like one of each of yours but I'll rustle round the boys at the Fun Crash on Monday and try to bulk up the order a bit. Many thanks in advance. BTC Hi Bruce Found what I was looking for here at £9.12 plus P&P. However, I'd still like the Sullivan metal clevis opening tool that is shown here if your son/you is/are able to sort out a supply. Happy to wait till June as I know that US post sometimes gets deeply stuck into customs clearance. Thanks Peter Quote Link to comment Share on other sites More sharing options...
Basil Posted April 30, 2023 Share Posted April 30, 2023 On 29/04/2023 at 11:01, Ron Gray said: Well we are a community and there are 3D printer owners, me being one! As a result I just knocked up this one for either 2 or 3mm clevis: have you considered selling them Ron? Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted April 30, 2023 Share Posted April 30, 2023 31 minutes ago, Basil said: have you considered selling them Ron? I am at £1 a pair plus P&P! 1 Quote Link to comment Share on other sites More sharing options...
Basil Posted May 1, 2023 Share Posted May 1, 2023 16 hours ago, Ron Gray said: I am at £1 a pair plus P&P! PM sent Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted May 1, 2023 Share Posted May 1, 2023 Thanks for your order Bas! Quote Link to comment Share on other sites More sharing options...
Basil Posted May 2, 2023 Share Posted May 2, 2023 23 hours ago, Ron Gray said: Thanks for your order Bas! I look forward to receiving them Ron. Bas Quote Link to comment Share on other sites More sharing options...
Bruce Collinson Posted May 2, 2023 Share Posted May 2, 2023 Got first 3, working on more and may have them shipped prior to June if the numbers stack up. BTC Quote Link to comment Share on other sites More sharing options...
Steven Hurd Posted May 3, 2023 Share Posted May 3, 2023 Ron Thanks for the STL file, just printed a set and they work fine. Hopefully it may save a nail or 2 in the future Steve Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted May 3, 2023 Share Posted May 3, 2023 Great news Steve, I don’t know why I didn’t do it before! Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted May 3, 2023 Share Posted May 3, 2023 Printed a couple of pairs yesterday - one for the flight box and another for the workshop. Used both my workshop ones today - the long arm version was particularly useful for working on a throttle clevis - and they are really effective and worked even better than expected! For the workshop pair I modified the stl to add a 6mm hole in the tip of one arm of each to hang them on a hook for easy location. Thanks Ron. Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted May 4, 2023 Share Posted May 4, 2023 Glad you like them Martin, thanks. Quote Link to comment Share on other sites More sharing options...
