Irvine 46 MK4 Silencer leaking
PDB
I've minimal experience with glow engines so this might be obvious to some.
I was using an OS46AX2 which between the two halves of the silencer had a gasket and all the crud came out of the end of the silencer.
Following a crash the AX got some mud in it so is being stripped and now I've got a new Irvine 46 MK4 which is now run in. I've noticed a lot of the exhaust crud is coming out of the join between the two silencer parts. There is no gasket in there and I've tried nipping up the bolt that runs through it without much effect.
Would it be worth getting the surfaces machined true, could a gasket be available but I've not yet found one or is it something to put up with?
Get a sheet of gasket paper, Flexoid is good brand, E bay., also a smear of silicone sealer, leave to dry for av couple of minutes to get a “skin” on it, and screw it up to  clamp. Leave to cure, screw tight.
But just the paper will work.
Unfortunately the self amalgamating tape didn't last long, I ensured the surfaces were clean and stretched it 50% as per the instructions but after a couple of runs it slipped down the silencer.
Got a tube of Granville Instant Gasket, disassembled the silencer for a good clean before applying so see if that solves the issue. 👍
Edited by PDB
I would advise applying the silicon, finger tightening, allowing it to cure for a few hours and then fully tightening.
Don't forget to do the ends of the machine screw.
  • Like 3
One thing I’ve noticed is a tendency for people to tighten the lock nut without having fully tightened the screw first. The lock nut stops the screw from loosening further in the end cap but any slight movement between the two silencer halves will cause fretting and obvious leakage - look for black oily residue for confirmation.
5 minutes ago, steve too said:
I would be tempted to put a bit of hose on the outlet to try and stop crap ending up on the wing. IIRC the stuff that I use is car radiator hose from ebay.
The OS 46 previously used had a groove around the outlet into which you could secure a silicon pipe with a cable tie. The Irvine has no groove hence I've been unable to secure an extension onto the outlet, anything I have tried has come off.
Interesting. There is no grove on this exhaust and the hose has been there for a while.
(This exhaust was sealed up with some black Loctite stuff...)
