toto Posted November 16, 2023 Share Posted November 16, 2023 Hi ..... I have bought a new motor for my Tiger 60 ..... but have an issue that i think I know the answer to but want to check first .....   there it is ..... pretty normal motor ...   four machined holes to hold the fire wall attachment thingy on .....   like so ......   and the front end ...... where does the proppy thingy go ????   and a bag of screws.....   now there is a collet screw at each end with a hex head. It looks like you could slacken both and try to push the spindle through towards the front. I have had a go at slackening them but when I try to push it .... its very tight so I did not want to force it ......  any advice would be appreciated. I'd like to get this on tonight and get the Watt meter onto it .... so the sooner the better please if possible.  many thanks  toto Quote Link to comment Share on other sites More sharing options...
Keith Berriman Posted November 16, 2023 Share Posted November 16, 2023 You might have to revert to long threaded bar back to bulkhead Quote Link to comment Share on other sites More sharing options...
Learner Posted November 16, 2023 Share Posted November 16, 2023 (edited) I take it you didnt get a prop driver that fits the other end, so you have 3 choices. Get a prop driver that fits the 3 bolt holes, probably not as easy as it sounds. Fit the motor the other way round shaft through the bulkhead and use as is but no good if the bulkhead isnt at the very front of the plane. Or loosen all the grub screws and knock shaft through with a pin punch being careful not to round them off as there probably soft. Or 4 As Keith said but will need to be done well to cope with 6 cells Edited November 16, 2023 by Learner Quote Link to comment Share on other sites More sharing options...
toto Posted November 16, 2023 Author Share Posted November 16, 2023 It's one of those compression type fittings and definately needs the spindle to bite onto as will the prop.   and ....   it just looks like the spindle is hanging out the wrong end. I'm a bit against trying to knock it through with a toffee hammer or anything ...... is this normal for this type of motor as any images online show it the same ..... got me lost.  toto Quote Link to comment Share on other sites More sharing options...
toto Posted November 16, 2023 Author Share Posted November 16, 2023 Can't find anything for this on the internet.  There are 3 machined holes in the front ..... just wondering if there is some kind of adaptor missing. Any image for this shows exactly the parts that I have. What am I missing ?????  The only thing I can think of is that the shaft needs knocked through .... but I ain't going there.  The motor should come ready to fit as it is .... am I thick or something ? very possibly.  toto Quote Link to comment Share on other sites More sharing options...
GrumpyGnome Posted November 16, 2023 Share Posted November 16, 2023 Get on to the retailer - you should have a piece of metal that screws into those three holes (prop adapter - e.g. https://www.robotbirds.co.uk/catalog/product/view/id/31092/s/prop-adapter-8mm-shaft-power-46-60-e-eflm1934/). The prop then fits on to this and is retained by a washer and nut. You probably won't need that collet... 1 Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted November 16, 2023 Share Posted November 16, 2023 (edited) You should have this,,, too late but £17 for something that should be supplied with the motor ?. Edited November 16, 2023 by Paul De Tourtoulon too late 1 Quote Link to comment Share on other sites More sharing options...
Learner Posted November 16, 2023 Share Posted November 16, 2023 Some motors arent supplied with that style prop driver. Multiplex didn't for most of their artfs the motor was mounted the other way round with the mount at the front so the shaft was in the right place. Quote Link to comment Share on other sites More sharing options...
toto Posted November 16, 2023 Author Share Posted November 16, 2023 Thanks chaps ..... all makes sense now ....... thank god I did not start attacking it with a hammer .....  problem solved .... back onto RC world.  cheers  toto Quote Link to comment Share on other sites More sharing options...
toto Posted November 16, 2023 Author Share Posted November 16, 2023 Just double checked their website .... clearly says prop adaptor included.  No email address just phone number so it looks like a call tomorrow.  hopefully it wont be any issue with them.  cheers  toto 1 Quote Link to comment Share on other sites More sharing options...
Learner Posted November 16, 2023 Share Posted November 16, 2023 15 minutes ago, toto said: Thanks chaps ..... all makes sense now ....... thank god I did not start attacking it with a hammer .....  problem solved .... back onto RC world.  cheers  toto It shows what you've got in the picture on rc world, no additional prop driver Quote Link to comment Share on other sites More sharing options...
Learner Posted November 16, 2023 Share Posted November 16, 2023 2 minutes ago, toto said: Just double checked their website .... clearly says prop adaptor included.  No email address just phone number so it looks like a call tomorrow.  hopefully it wont be any issue with them.  cheers  toto Youve got a prop adapter Just doesnt fit how you wont it! Quote Link to comment Share on other sites More sharing options...
toto Posted November 16, 2023 Author Share Posted November 16, 2023 well it looks like I'll need to purchase the 3 hole version for the front end if thats the case but I'll have a chat with them first  toto Quote Link to comment Share on other sites More sharing options...
toto Posted November 16, 2023 Author Share Posted November 16, 2023 Paul  any idea where I can buy the fitting that you have pictured just in case I have fouled up ?  cheers  toto Quote Link to comment Share on other sites More sharing options...
Learner Posted November 16, 2023 Share Posted November 16, 2023 Be aware that not all 3hole prop drivers are the same and I dont think energ list one so you may want to try and send motor back. Quote Link to comment Share on other sites More sharing options...
kc Posted November 16, 2023 Share Posted November 16, 2023 you might consider the type of mount shown here Quote Link to comment Share on other sites More sharing options...
toto Posted November 16, 2023 Author Share Posted November 16, 2023 Hi KC,  thanks for the link ..... much appreciated but I don't see any 3 hole versions on it ..... I'll keep searching.  cheers  toto Quote Link to comment Share on other sites More sharing options...
toto Posted November 16, 2023 Author Share Posted November 16, 2023 (edited) Learner ..... I really hope not .... this is for my tiger 60 and its turning into a real saga.  my own fault..... gutted  toto Edited November 16, 2023 by toto Quote Link to comment Share on other sites More sharing options...
toto Posted November 16, 2023 Author Share Posted November 16, 2023 Located one at Nexus Models and it shows the same motor as I have next to it. Â Same as the one shown in grumpy's link. Â Thanks GG Â it should be on its way ..... fingers crossed that there is no more drama's. Â toto Quote Link to comment Share on other sites More sharing options...
Graham Bowers Posted November 16, 2023 Share Posted November 16, 2023 (edited) 16 minutes ago, toto said: Learner ..... I really hope not .... this is for my tiger 60 and its turning into a real saga.  my own fault..... gutted  toto You could ways speak to J Perkins. The motor comes with threaded holes for that type of prop driver so if anybody is in a position to advise, it's them. I called them up when I couldn't find an item that was listed, but out of stock, and they sorted it out. Admittedly, the part you need isn't listed, as far as I can tell. Probably a badged up version of a motor sold under several guises.  Edited to add, just seen your latest post. Hope it fits. Edited November 16, 2023 by Graham Bowers 1 Quote Link to comment Share on other sites More sharing options...
GrumpyGnome Posted November 16, 2023 Share Posted November 16, 2023 @toto that was just an example.......... different motors seem to have different hole spacings...... Quote Link to comment Share on other sites More sharing options...
toto Posted November 16, 2023 Author Share Posted November 16, 2023 Hi Grumpy,  when I opened up the product on the Nexus website, it actually had an associated product ( my exact motor ) on the product page so it looks related.  time will tell if I've just thrown another £23 quid away.  I'll update as it comes.  toto Quote Link to comment Share on other sites More sharing options...
GrumpyGnome Posted November 16, 2023 Share Posted November 16, 2023 🤞 Quote Link to comment Share on other sites More sharing options...
Caveman Posted November 16, 2023 Share Posted November 16, 2023 (edited) Toto, this is a page from the E-Flite website for the E-Flite Power 46 motor E-flite Power 46 Brushless Outrunner Motor, 670Kv, 3.5mm Bullet | e-Flite (e-fliterc.com)  Look familiar??  Scroll down and click on 'Optional Parts', and look at the second row, middle item - that should put your mind at rest!!  GDB  PS I note that the the E-flite motor has the shaft reversed compared with the En-er-G 'variant'. Edited November 16, 2023 by Caveman Additional text Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted November 16, 2023 Share Posted November 16, 2023 It’s not uncommon (actually it’s the norm) for motor shafts to be interference fits.  It may be a bit late but confirmation from the supplier might have allowed the simpler and cheaper option.  I would never advocate hammering a shaft though - a press would be the better option but you can often use a vice and suitable spacers/supports such as sockets or old bearings etc. 2 Quote Link to comment Share on other sites More sharing options...
