Jason Channing Posted May 1 Share Posted May 1 36 minutes ago, Don Fry said: From memory, I sold mine 30 years ago, but I remember the design was a machine without ailerons. A rolling circle would be difficult I think. The beginner is DocPrinter, who started the post. quite easy to do a rolling circle with a junior 60, rolls beautifully and is quite responsive. Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted May 1 Share Posted May 1 This is a great one, one of the wings has an extra rib, the Do-it from Robbe, the first picture 20 years ago, (me on the left ) and my 'new' one built in 2017. Great fun. Quote Link to comment Share on other sites More sharing options...
Don Fry Posted May 1 Share Posted May 1 2 hours ago, Jason Channing said: quite easy to do a rolling circle with a junior 60, rolls beautifully and is quite responsive. How do you do a rolling circle with a plane without ailerons Quote Link to comment Share on other sites More sharing options...
GrumpyGnome Posted May 1 Share Posted May 1 I'd love to see a J60 doing a rolling circle...... Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted May 1 Share Posted May 1 I’ve certainly seen a similar rudder/elevator model performing fairly axial rolls so it’s not an impossible scenario. Quote Link to comment Share on other sites More sharing options...
GrumpyGnome Posted May 2 Share Posted May 2 I wasn't being sarky, dismissive, or disbelieving, I genuinely would like to see it........I've seen J60s take off and fly around at speeds the original designer probably thought impossible, and do loops that made me think an unplanned disassembly was imminent, but not consecutive rolls...... I've also seen them take off and fly at speeds slower than I can run, and just waft about, like BBQ smoke.... Quote Link to comment Share on other sites More sharing options...
Jason Channing Posted May 2 Share Posted May 2 (edited) 11 hours ago, Don Fry said: How do you do a rolling circle with a plane without ailerons Rudder and elevator, secondary effect of controls, The rudders' primary effect is yaw and secondary is roll and with the correct dihedral it produces a lovely smooth roll. I can also quite easily fly a B test with a junior 60 as its quite an axial roll, Its not actually that difficult just timing and power as well. Demonstrated quite often at Ramsey MAC. I'll even try and get some video next time we go out. Edited May 2 by Jason Channing photo added 2 Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted May 2 Share Posted May 2 3 hours ago, Jason Channing said: I can also quite easily fly a B test with a junior 60 The outside loop sounds challenging with all that dihedral. Quote Link to comment Share on other sites More sharing options...
Jason Channing Posted May 2 Share Posted May 2 1 hour ago, Martin Harris - Moderator said: The outside loop sounds challenging with all that dihedral. It doesn't like being inverted and you need to fly it all the way around, once at the bottom an Os 52 gets it to the other side quite easily, Inverted circuits can be done but it wobbles constantly trying to right itself. Quote Link to comment Share on other sites More sharing options...
Nigel R Posted May 3 Share Posted May 3 On 02/05/2024 at 07:20, Jason Channing said: Rudder and elevator, secondary effect of controls, The rudders' primary effect is yaw and secondary is roll and with the correct dihedral it produces a lovely smooth roll. Agreed. I only had one of the gutless HP25 four strokes in mine, outside loops were off the menu, but rolls are easy, loops are easy, and I used to fly it inverted a fair amount. That said, it's "a bit" twitchy when upside down. Rolling circle is messy, but end of day, with something like this, you're "just" dabbing in course corrections with the elevator, while rolling. "Trainers" can be a lot of fun. I keep one in the hangar now as a go-to if I haven't flown for a while. 1 Quote Link to comment Share on other sites More sharing options...
Jason Channing Posted May 3 Share Posted May 3 1 hour ago, Nigel R said: Agreed. I only had one of the gutless HP25 four strokes in mine, outside loops were off the menu, but rolls are easy, loops are easy, and I used to fly it inverted a fair amount. That said, it's "a bit" twitchy when upside down. Rolling circle is messy, but end of day, with something like this, you're "just" dabbing in course corrections with the elevator, while rolling. "Trainers" can be a lot of fun. I keep one in the hangar now as a go-to if I haven't flown for a while. But once you've achieved a full inverted circuit with out it rolling out you feel quite accomplished, Bit like flying a plane on the edge of a tip stall except its not. The OS is a nice match for the plane regarding power, nice smooth slow wing overs relying on power for the climb rather than speed. Quote Link to comment Share on other sites More sharing options...
Eric Robson Posted May 3 Share Posted May 3 Not many now will have heard of Howard Boys, his designs regular featured in the Aeromodeller. He was quite elderly when the A test was introduced and amazed everyone by passing it on a single channel high wing model. There was a modeller in the first club I joined who could do more with rudder and elevator including rolling circles than most could do with full house as it was referred to back then. Quote Link to comment Share on other sites More sharing options...
Keith Billinge Posted May 3 Share Posted May 3 (edited) Dont forget the Swizzle Stick. A design by Peter Miller on these very forums. Easy to build and great fun to fly. Edited May 3 by Keith Billinge Quote Link to comment Share on other sites More sharing options...
Jason Channing Posted May 3 Share Posted May 3 3 minutes ago, Eric Robson said: Not many now will have heard of Howard Boys, his designs regular featured in the Aeromodeller. He was quite elderly when the A test was introduced and amazed everyone by passing it on a single channel high wing model. There was a modeller in the first club I joined who could do more with rudder and elevator including rolling circles than most could do with full house as it was referred to back then. I remember Howard Boys. Two channel Tomboys is nearly as much fun as Jet flying. Quote Link to comment Share on other sites More sharing options...
