Fuel proofer for glow fuel?
This has probably done to death but the threads i looked at were a number of years old, maybe there is something new to use since Clearcoat is no longer available? I am refurbing an old model and giving it a new coat of acrylic paint, i have some Rustoleum clear lacquer spray here but not sure if that will resist the fuel on the painted covering. I don`t want to get into a two pack type system that requires specialist breathing equipment, i just want to stick on a B&Q type mask to keep something less lethal out of my lungs. Anyone had some success with something that is easy to use and easily available in the UK?
3 hours ago, Nigel R said:
Have you tried to get a more matt finish by gentle rubbing down or whatever? Very high gloss doesn't always suit the subject and they don't appear to have a flatting agent available. Looks to be good stuff though.
I haven't. TBH I've only used this for engine / tank bays and similar, I rather missed the OP's point...
2 hours ago, martin collins 1 said:
I am not concerned about the engine bay area, warmed 30 min epoxy should do that, it is an exterior finish i am looking for, preferably matt or satin.
The reason for my post above was because the specs for Rustin's states for internal only so I was wondering about its use outside.
