Jonny Turner Posted September 14, 2009 Share Posted September 14, 2009 I've just recently got a Chris Foss WOT Trainer and it's got a SC52 fourstroke in it. Just wondering if anyone has had any experience with this engine and if it's going to be powerful enough for the WOT? Thanks. Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted September 14, 2009 Share Posted September 14, 2009 Without a doubt, you'll be fine with that Welcome by the way Quote Link to comment Share on other sites More sharing options...
Jonny Turner Posted September 14, 2009 Author Share Posted September 14, 2009 Was a bit worried because it's the first four stroke I've had. Got a Irvine 46 in my other Calmato trainer and if it performs aswell as that then I'll be happy! Thanks for the welcome, Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted September 14, 2009 Share Posted September 14, 2009 No prob. We've just watched Tony Nijhuis fly his new Lysander on the same engine - bags of power for a 6lb model. Quote Link to comment Share on other sites More sharing options...
Peter 'Ivanna Crashalot' Savage Posted September 14, 2009 Share Posted September 14, 2009 I've got an OS FS-48 Surpass put aside for the Lysander, hope that is powerful enough! (A small scale Rolls Royce Mercury would be nice!) Edited By Peter Savage on 14/09/2009 10:45:33 Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted September 14, 2009 Share Posted September 14, 2009 Jonny Welcome from grumpy me too. I have two SC52'4st's( except one is an ASP but the same .)I find them not to have the same" feel" for flick starting as my OS 52 4 st but once going they're great, no problem I hope with the Wot 4 'cos I'm in the process of building my own version Quote Link to comment Share on other sites More sharing options...
Diamond Geezer Posted September 15, 2009 Share Posted September 15, 2009 great in the wot 4 Quote Link to comment Share on other sites More sharing options...
Jonny Turner Posted September 15, 2009 Author Share Posted September 15, 2009 Hope so! It's just I've seen some vids on Youtube of some guys with SC52 Fourstrokes in trainer planes and they seem to be struggling, don't seem to have a great rate of climb. And I'm sure my WOT weighs a bit more than my Kyosho Calmato! Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted September 15, 2009 Share Posted September 15, 2009 Ive an SC52 4 stroke in a Flair Cub and it has loads of power,it also tick along slowly as well,an excellant engine.My Cub is 73" Quote Link to comment Share on other sites More sharing options...
the unmagnificent man Posted September 18, 2009 Share Posted September 18, 2009 Hi Jonny, all my planes have SC engines, I swear by 'em. Some tips....... Once they are run in and ticking over nicely which they do very well then you should put a tiny bit of something sticky (threadlock for eg) on the threads of the tiny low end adjustment screw. This stops it unwinding due to vibration. Put a bit of oil into the nipple on the bottom of the engine after every flight. If its been used then check the valve clearance. Its simple to do and hard to mess up. Adjust when the engine is cold. 1 get some feeler guages 2 remove the two allen bolts and lift off the rocker cover. 3 turn the engine by hand and watch the two valves go up and down. You will notice that at one point it is possible to turn the motor a little in each direction whilst both valves are closed and stay still. 4 When you have got to this point you have to loosen the nut and place a screwdriver into the slot on top of the thread. 5 Set your feeler guages to between 0.05 and 0.1mm (or 2 to 4 thou of an inch) and place it in the gap between the screw and the valve. 6 Turn the screw lightly until it just grips the guage. 7 Lock the nut back up being careful not to re adjust the valve 8 Repeat for the other valve. 9 Replace the cover. My SC 52 starts immediately every time and never misses a beat even when its been stood for ages. Look after it and it'll never let you down. Quote Link to comment Share on other sites More sharing options...
fly boy3 Posted September 26, 2009 Share Posted September 26, 2009 Hi, good advice on the SC52 f/s, have you any advice on my same engine. The nut holding the exhaust to the engine continually slackens off after a few flights. The prop is balanced,so what else could cause this.? Would a locknut do the trick ,or a spot of epoxy. Thanks flyboy3. Quote Link to comment Share on other sites More sharing options...
Peter 'Ivanna Crashalot' Savage Posted September 27, 2009 Share Posted September 27, 2009 You could try loctite, not sure if it would get hot enough to melt it, try it and see! Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted September 27, 2009 Share Posted September 27, 2009 fly boy3-what i do is- do the nut up and just before it's ready to tighten-apply some clear silicone the type used for fishtank's...any surplus-spread around the nut-it wont come undone-if your having prob's with the nut comming undone all the time i would balance your prop's and spinner's............ ken anderson... ps- make sure the thread's and nut are dry/and clean before you put on the silicone........ Quote Link to comment Share on other sites More sharing options...
DAVID CLIFFORD Posted September 27, 2009 Share Posted September 27, 2009 Hi Jonny, best engine i ever had. Even flew my 80" hanger nine cub, never missed a beat. D Quote Link to comment Share on other sites More sharing options...
batcho99 Posted September 27, 2009 Share Posted September 27, 2009 I ran up an SC52 four stroke i've had sitting around for a few years last week, put a new plug in, popped it on a home made test stand, fueled with optifuel 4 stroke mix. Started first time. If you dont think theres enough power in it to fly a trainer then you've got a serious problem! Bags of power in mine with excellent smooth throttle response Mines going in my gyro i'm building http://www.rcgroups.com/forums/showthread.php?t=1098937 Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted October 3, 2009 Share Posted October 3, 2009 All SC engines are great. The 52 is a super engine. Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted October 3, 2009 Share Posted October 3, 2009 anybody remember the rumour that was 'flying'(pun)around that some one from one company had done a runner to another and took the info with them-hence one brand of 4st is essentionally the same as the other but with a different name on?... ken anderson........ Quote Link to comment Share on other sites More sharing options...
Chris Channon Posted October 9, 2009 Share Posted October 9, 2009 Hi all, i have a SC 52 four stroke in my Kyosho Spit. It has never run nicely, i have done the tappets, stripped the engine down and honed the bore ( i thought perhaps it had got hot in the spit ) all to no avail, after a flight there was less compression than before the flight !! So, again i strip it down, i can't find anything wrong so re-built again and set the valve working clearances, lots of compression, i re-fit the cam cover and blimey, no compression ! remove the cam cover lots of compression, after looking under a glass, i found a slight lump of casting in the cam cover that was holding a valve partially open, never come across this before. So, out with the dremel, 10 minutes later, one perfect running engine !! Just thought i would let you know in case someone else has a similar problem. Out of seven S/C i own, this is the first one that i have had trouble with, seriously good engines ! Regards as always Chris. Quote Link to comment Share on other sites More sharing options...
Mick Smith Posted October 9, 2009 Share Posted October 9, 2009 i have the sc 52 in my flair baronette no problem pulling this 6lb model around Quote Link to comment Share on other sites More sharing options...
Peter 'Ivanna Crashalot' Savage Posted October 9, 2009 Share Posted October 9, 2009 Dad has a 20 year+ SC 53 two stroke, it is brilliant, it will start from bouncing it off the compression, if this is anything to go by the four strokes must be good! Quote Link to comment Share on other sites More sharing options...
