Andrew Bourne Posted February 11, 2011 Share Posted February 11, 2011 I bought a dinky little motor M1406/16 from GC and fitted into an indoor “Introvert” having first bench tested it with 5x3 prop(sourced a 1.5mm propo adapter from Robot Birds) 2s lipo and 10A ESC (all from GC). It failed on the maiden flight and would not run at all. I returned it to GC with a covering letter, and was delighted when a few days later a replacement motor arrived in the post from GC. Proceeded to test the new motor as before! It was tight, but did turn, in addition there were solder blobs on the leads which seemed to indicate that this motor had been connected before. As soon as connected and began to run the armature floated free of the end bearing and would have come right out! I returned the motor to GC with another covering letter in the confidence that it would be replaced as before. WRONG! GC said that their “tester” had examined the motor, and that it had been damaged by me. After exchanging several emails with GC I still have not received a replacement for the second motor which was clearly already damaged – and used!>> Bad service GC to a good customer! Alternative motor sourced elsewhere thankyou!>> Quote Link to comment Share on other sites More sharing options...
kc Posted February 11, 2011 Share Posted February 11, 2011 Perhaps you should consult your local Trading Standards Dept to get help with enforcing the laws on retailers. Quote Link to comment Share on other sites More sharing options...
001 Posted February 11, 2011 Share Posted February 11, 2011 I had a similar thing with a small outrunner. During its first flight, after about ten seconds of running there was a click and the motor just stopped. Luckily I was able to land safely. When I looked, there were about twelve of the fourteen magnets that had come unglued jammed against the stator. So I sent it back to Giant Cod and after a good few days they sent me another. Which is OK, but in their letter it said 'Our engineer has examined the motor and as it has not been in a crash we will replace it.' So, I wondered what would have happened if the defect had caused a crash, bent the shaft or scraped the outside of the motor. Not very satisfactory. Quote Link to comment Share on other sites More sharing options...
Kozmyk Posted February 11, 2011 Share Posted February 11, 2011 I never use them. I was warned off early on. Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted February 11, 2011 Share Posted February 11, 2011 Can't say I've ever had a problem - good prices and quick delivery in every case... Quote Link to comment Share on other sites More sharing options...
Kevin Fairgrieve Posted February 11, 2011 Share Posted February 11, 2011 Posted by Martin Harris on 11/02/2011 19:51:05: Can't say I've ever had a problem - good prices and quick delivery in every case... Likewise. But I have only ever used them for servo`s and the like. Always posted promptly and with me within 49 hours. Quote Link to comment Share on other sites More sharing options...
Pat (rActive) Harbord Posted February 11, 2011 Share Posted February 11, 2011 May I suggest the personal touch? I have found it's always best to make a phone call to talk through problems before resorting to email, all kinds of misinterpretation is applied to the written word especially when written by the common man. If you have to resort to "good will" you may find your mileage increases over the phone.I must add that I have had no dealings with giant cod specifically. Thanks for flagging up a less than scrupulous internet trader.You do raise an interesting point on where the consumer stands in relation to goods and services bought and their fitness for purpose. Quote Link to comment Share on other sites More sharing options...
Old Geezer Posted February 11, 2011 Share Posted February 11, 2011 Always had good, prompt service and no problems with anything I've bought. Quote Link to comment Share on other sites More sharing options...
andy watson Posted February 11, 2011 Share Posted February 11, 2011 I know many people have had no problems with them, but I have been put off by their "terms and conditions" which appear to contravene statutory requirements. Quote Link to comment Share on other sites More sharing options...
r6dan Posted February 11, 2011 Share Posted February 11, 2011 I have had only good things to say about them, infact I need to order some stuff from them for the webbit Quote Link to comment Share on other sites More sharing options...
Pete B Posted February 11, 2011 Share Posted February 11, 2011 I've been very happy with the service and products - they've made the hobby much more affordable for many people. They were last year's winners of the RCM&E Mail Order category and are probably well in the running this year, so they must be pleasing some customers........... Pete Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted February 11, 2011 Share Posted February 11, 2011 More than in the running Pete - they win again in 2011 Quote Link to comment Share on other sites More sharing options...
Pete B Posted February 11, 2011 Share Posted February 11, 2011 Whoops, so they did, Timbo, - just goes to show that there's still more to be found in the mag even after it's been here a week! Well done, GC! Pete Quote Link to comment Share on other sites More sharing options...
Shane Sunday Posted February 11, 2011 Share Posted February 11, 2011 Honestley I've nuthing but high praise for GC. Fast delivery and a very good product with friendly service. Although the odd dud does show now and then. It's just too bad it happened to you twice. Could it be the make of motor? Quote Link to comment Share on other sites More sharing options...
moorer Posted February 11, 2011 Share Posted February 11, 2011 geat service and NO problems, i wouldnt use anyone else,unless i want to pay twice the price for the same thing and no, i have no association with them. Quote Link to comment Share on other sites More sharing options...
Bill_B Posted February 11, 2011 Share Posted February 11, 2011 I've also had great service from GC and have no complaints so far. Quote Link to comment Share on other sites More sharing options...
Roby Posted February 11, 2011 Share Posted February 11, 2011 I agree, excellent service and good products! Quote Link to comment Share on other sites More sharing options...
Keiran Arnold Posted February 12, 2011 Share Posted February 12, 2011 Remember guys a company is only as good as its last delivery: so if it fails the last consumer are you next? Quote Link to comment Share on other sites More sharing options...
Mike Rolls Posted February 12, 2011 Share Posted February 12, 2011 I'm another satisfied customer of GC Mike Quote Link to comment Share on other sites More sharing options...
BalsaBasher Posted February 12, 2011 Share Posted February 12, 2011 Posted by Keiran Arnold on 12/02/2011 00:58:56:Remember guys a company is only as good as its last delivery: so if it fails the last consumer are you next? That is a pretty harsh line to take as we all make mistakes and even more so if you are a business as many other's i.e. your suppliers , delivery companies etc are extensions of your business. Quote Link to comment Share on other sites More sharing options...
Andrew Bourne Posted February 12, 2011 Author Share Posted February 12, 2011 Thanks guys for all your comments. I agree with all the good things - good prices, fast reliable service. But I did expect better treatment from a genuine complaint! Happy to put this thread to bed now. Quote Link to comment Share on other sites More sharing options...
i12fly Posted February 12, 2011 Share Posted February 12, 2011 Don't forget there are alot more rogue customers than rogue traders out there. Innocent customers can easily fall into being treated like rogues as good traders try to protect themselves (as the law leans towards supporting the customer). The personal touch, ringing up as rActive above suggests gives you the best chance to either get the response you want, or to realise you are dealing with people you don't want to trade with again. Quote Link to comment Share on other sites More sharing options...
Andy Harris Posted February 12, 2011 Share Posted February 12, 2011 I reckon GC are tough but fair. With their prices this is a position I will accept. For a little more money you could use Robotbirds. I like these chaps because if you blow anything up they do a thorough analysis. Most posts here point out its a balance. I've blown up two motors on a Panic, one GC and one Robots birds. The underlying problem was the ESC, GC didn't replace the motor but Robotbirds did - I bought the replacement ESC from Robotbirds just because of their analysis. I recently wrecked 2 servos before my AddX was even maidened, again Robotbirds replaced them (and then I wrecked them again - this time I decided the recommended servos for the AddX were wrong). I made clear notes about where I think I went wrong and why it would be acceptable to charge me for replacements -- slightly off topic but what I'm getting at is that we should be good customers as well. I like GC a lot, and I accept that they state their policies and see them through. Quote Link to comment Share on other sites More sharing options...
andy watson Posted March 15, 2011 Share Posted March 15, 2011 I did read a while ago (but never check out whether it was true) that they weren't VAT registered. I can't believe their turnover is below that requiring registration- so I would not be entirely surprised if this were the case. Of course, it could be a load of rubbish! Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted March 16, 2011 Share Posted March 16, 2011 Guys - just had to delete a post that was making a statement without reference to source. If you're going to make a statement about the trading status of a company then please refrain from using gossip and 'the grapevine' as a reference source. Thanks. Quote Link to comment Share on other sites More sharing options...
