Artto Ilmanen Posted November 25, 2015 Share Posted November 25, 2015 Posted by Jon Harper on 25/11/2015 08:41:24: Hi Artto. The rings and cylinder are lubed by the oil left after combustion. It clings to the cylinder wall and also lives in the gaps behind the piston rings. The lower piston ring pumps the oil from this gap into the crankcase where the rotating parts splatter it all over the place! In short, its unlikely to make any difference at all Thanks Jon! Quote Link to comment Share on other sites More sharing options...
Artto Ilmanen Posted January 21, 2016 Share Posted January 21, 2016 Hi folks! I wonder how you guys mount the tank vent? Here is how I have mounted mine but I would like to see other solutions maybe less exposed than mine.. Quote Link to comment Share on other sites More sharing options...
Jon H Posted January 22, 2016 Share Posted January 22, 2016 They are only exposed if you knock off the undercarriage. If you manage that, the well being of those pipes is likely to be low on your list of concerns Quote Link to comment Share on other sites More sharing options...
Artto Ilmanen Posted January 22, 2016 Share Posted January 22, 2016 Posted by Jon Harper - Laser Engines on 22/01/2016 08:48:27: They are only exposed if you knock off the undercarriage. If you manage that, the well being of those pipes is likely to be low on your list of concerns Very true! Not that there was a problem I was more after ideas of a more (maybe) elegant solution! -Artto Quote Link to comment Share on other sites More sharing options...
Former Member Posted January 22, 2016 Share Posted January 22, 2016 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Artto Ilmanen Posted March 9, 2016 Share Posted March 9, 2016 My GP Super Chipmunk with Laser 150 requires a custom silencer as the stock one does not fit inside the cowling. My field is not very noise conscious so I could use straight pipe, too. However, I'm tempted to try to make one by myself although I'm aware of the possible challenges. I think if I test an absorption type silencer or one without any baffles just like the stock one I should be in safe waters. At least I think if try a solution which is less restrictive than the stock one I won't break anything! However, I appreciate any hints on the topic. Such as if Lasers require a small backpressure or are they happy with just a free flowing silencer? -Artto Quote Link to comment Share on other sites More sharing options...
Artto Ilmanen Posted March 16, 2016 Share Posted March 16, 2016 As Aerosave oil seems to be discontinued I bought a litre of Klotz Original Techniplate for testing. I know Klotz, EDL, ML-70 do the job as good lubricant in the fuel mix for Laser engines. However, with respect to smooth idle or anti-corrosion abilities is any of these oils superior than the others as experienced by Laser engine enthusiasts? thanks, Artto Quote Link to comment Share on other sites More sharing options...
J D 8 Posted April 29, 2017 Share Posted April 29, 2017 Just run my first Laser purchased from an elderly club member who was moving away. Some parts were not with the motor but Jon at Laser identified it as a 150 and sent the missing bits to me in no time. Started second flick with chicken stick and ran just fine, lovely sound.Well pleased. One more thing to sort. What to put it in? Quote Link to comment Share on other sites More sharing options...
Former Member Posted April 29, 2017 Share Posted April 29, 2017 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Jon H Posted April 29, 2017 Share Posted April 29, 2017 Good to hear everything working well John. As for a home for it, they are just as happy in something sporty as something floaty. As long as the tank is in the right place it should be as happy as a clam Quote Link to comment Share on other sites More sharing options...
J D 8 Posted April 29, 2017 Share Posted April 29, 2017 I did notice that the needle setting is not at all critical. Could not get a normal tick over low but put that down to the low level of the tank on my test stand. Cheers. Quote Link to comment Share on other sites More sharing options...
Jon H Posted April 29, 2017 Share Posted April 29, 2017 Check for end float in the carb barrel. The old Irvine carbs wear over time so that could be it. Aim for 2000rpm or below for idle and about 8300 on a 16x8 Quote Link to comment Share on other sites More sharing options...
J D 8 Posted April 29, 2017 Share Posted April 29, 2017 OK will do thanks. Quote Link to comment Share on other sites More sharing options...
Jon H Posted June 16, 2017 Share Posted June 16, 2017 I was led to this imposter by a customer earlier and am staggered by the price it has reached. These were clones of laser engines and according to my boss were made in Africa somewhere about 20 years ago. They were absolutely useless and conrod failures were common. The item description did amuse me though **LINK** Edited By Jon Harper - Laser Engines on 16/06/2017 12:28:05 Quote Link to comment Share on other sites More sharing options...
Former Member Posted June 17, 2017 Share Posted June 17, 2017 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted June 17, 2017 Share Posted June 17, 2017 Collectors want them because they exist, no other reason, hence the high prices for rare POS. Quote Link to comment Share on other sites More sharing options...
Former Member Posted June 18, 2017 Share Posted June 18, 2017 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Jon H Posted June 18, 2017 Share Posted June 18, 2017 I am just waiting for it to appear on my desk for service Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted June 18, 2017 Share Posted June 18, 2017 Posted by Jon Harper - Laser Engines on 18/06/2017 09:55:44: I am just waiting for it to appear on my desk for service Quote Link to comment Share on other sites More sharing options...
Broken Prop Posted September 14, 2017 Share Posted September 14, 2017 I have just run in a Laser 100. It was a deeply moving experience. (sigh) Pete Quote Link to comment Share on other sites More sharing options...
Manish Chandrayan Posted September 14, 2017 Share Posted September 14, 2017 Pete How about sharing that experience with us? May be it would move us a little too Quote Link to comment Share on other sites More sharing options...
Tim Flyer Posted September 14, 2017 Share Posted September 14, 2017 My Laser 100 seems run in now too. After 8 x15 minute flights and the normal 20 min home set up run it should be too . A surprising motor . Seems very happy revving on my Seagul P47 on a 15x8 and powers it very very well. It seems to have a lot more torque than my OS95v. It must be the long stroke helping. A great engine . If I can fit another in my 63 in LA 7 I'm building this winter I will . Quote Link to comment Share on other sites More sharing options...
Broken Prop Posted September 14, 2017 Share Posted September 14, 2017 Hi Manish I am afraid that I did not take a video so I cannot share the experience with you. However it was somewhere on a level with transcendental meditation, only with a delicious noise...... Seriously, what a lovely engine! Started on the first swing and never missed a beat. Clean and with no oil leaks it made me wonder why I ever bother with Japanese engines. It is swinging a 15x8 at present but I may see if I can get a prop with less pitch. The engine is going in a very large vintage model so I don't need all out performance. Pete Quote Link to comment Share on other sites More sharing options...
Jon H Posted September 14, 2017 Share Posted September 14, 2017 after some time oh a 15x6 a 16x6 should not phase the 100 on your vintage model. As you aren't after max power if you can find a 17x5 that would even do the job I am sure. Quote Link to comment Share on other sites More sharing options...
Manish Chandrayan Posted September 14, 2017 Share Posted September 14, 2017 Pete, thank you for sharing your experience Quote Link to comment Share on other sites More sharing options...
