Erfolg Posted January 18, 2015 Share Posted January 18, 2015 Those are big sheets, and who delivers them, not the LMS, or builders merchants I would b guessing. As for eye rolling, I find it is shortly followed by a tongue lashing, eventually becoming something akin to Tiinnitus, and I will do anything to relieve the discomfort. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted January 18, 2015 Author Share Posted January 18, 2015 **LINK** works out at £3.00 a sheet delivered. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted January 18, 2015 Author Share Posted January 18, 2015 just to give you an idea of the wing size. if anyone is watching that is. Quote Link to comment Share on other sites More sharing options...
Steve T Posted January 18, 2015 Share Posted January 18, 2015 I'm watching, and imagining her indoors face if I left a wing that size in our porch, awesome! I would love to see it, and then tell her it's the tailplane......😡 Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted January 18, 2015 Author Share Posted January 18, 2015 oh i forgot to say. that is the tailplane. size for the next one. Quote Link to comment Share on other sites More sharing options...
Dave Hopkin Posted January 18, 2015 Share Posted January 18, 2015 BTW Tony, have your tried B&Q Dial brand carpet spray? Works perfectly in conjunction with UHU POR on the opposite face, I used it on the underside of the wing skins to make sure I covered all the joints - and a damm sight cheaper than POR! Quote Link to comment Share on other sites More sharing options...
Ian101 Posted January 18, 2015 Share Posted January 18, 2015 I think a lot of people are watching this Tony, but very quietly like me! Dave, that sounds interesting. Haven't come across that before but looks worth a try. Marking out all of the contact points is always difficult. Ian Edited By Ian101 on 18/01/2015 16:35:17 Quote Link to comment Share on other sites More sharing options...
Dave Hopkin Posted January 18, 2015 Share Posted January 18, 2015 If you use it, for the sake of domestic harmony, spray ir over the lawn - as it comes out is a sort of very fine strings, that float about a bit, great for getting an even coating, but a sod when it comes to overspray - I have probably spend about 6 hrs on my knees in the kitchen working on the floor with a stanley blade..... lets say I lost a lot of brownie points with that little stunt Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted January 18, 2015 Author Share Posted January 18, 2015 oh Dave Ha Ha Ha. what i do is to run por over the ribs and then just press the 3mm skin onto the surface and then remove. that way you can see where to run the fresh glue ready to re stick it when tacky. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted January 18, 2015 Author Share Posted January 18, 2015 been cutting ribs and more ribs and more ribs. can't put the centre ones in until i have positioned the fuselage and worked out where the edge of the fuselage runs in relation to the wing. Quote Link to comment Share on other sites More sharing options...
Dave Hopkin Posted January 18, 2015 Share Posted January 18, 2015 Yep that will work to, what I did, was put a slug trail of POR on the ribs, smear it out with a bit of offcut 3mm foam, then spray the skin inside - make a brew, consume no more than 2 Ginger Nuts and then press down Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted January 18, 2015 Author Share Posted January 18, 2015 got to be chocolate hob nobs sir. Quote Link to comment Share on other sites More sharing options...
reg shaw Posted January 18, 2015 Share Posted January 18, 2015 A very pretty aeroplane, and a rather large one at that! What are the spars made up from Tony, any wood? I love the shape of the fin and rudder on this Meteor, much nicer than the squarer version. Ian. Quote Link to comment Share on other sites More sharing options...
Dave Hopkin Posted January 18, 2015 Share Posted January 18, 2015 Posted by Tony Bennett on 18/01/2015 16:47:31: got to be chocolate hob nobs sir. Heathen Edited By Dave Hopkin on 18/01/2015 19:10:38 Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted January 18, 2015 Author Share Posted January 18, 2015 Hello Ian. the spars are a balsa depron composite and seem to be quite strong. i have some carbon tubes to fit into the wing yet to add some more strength. yes i like the MK1 shape. lets just hope it all works out ok. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted January 19, 2015 Author Share Posted January 19, 2015 yes i will say no more. Quote Link to comment Share on other sites More sharing options...
Dave Hopkin Posted January 19, 2015 Share Posted January 19, 2015 Can I draw your attention to one of these - **LINK** I think you may be needing it...... Edited By Dave Hopkin on 19/01/2015 16:43:26 Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted January 19, 2015 Author Share Posted January 19, 2015 ooh i could build something bigger if i had one of them. Quote Link to comment Share on other sites More sharing options...
Dave Hopkin Posted January 19, 2015 Share Posted January 19, 2015 1/2 scale Bristol Brabazon maybe? Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted January 19, 2015 Author Share Posted January 19, 2015 hmmmmmmmmmmmmmmmmmmmmmm Quote Link to comment Share on other sites More sharing options...
Martian Posted January 20, 2015 Share Posted January 20, 2015 Hmmmmm indeed Tony ,here is a subject Russia K7 Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted January 22, 2015 Author Share Posted January 22, 2015 where i am today. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted January 23, 2015 Author Share Posted January 23, 2015 working on the tailplane. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted January 23, 2015 Share Posted January 23, 2015 Love it John Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted January 25, 2015 Author Share Posted January 25, 2015 elevators getting worked on. Quote Link to comment Share on other sites More sharing options...
