Lindsay Todd Posted November 29, 2015 Author Share Posted November 29, 2015 Getting towards the end of the painting work now, got the fuselage roundels done at last which always seem to take ages due to multiple paint masks so that just leaves the red white and blue strips on the fins left to do. Also decided I had better get on and sort out the battery location and fixing. their were a number of ways to do this but I wanted something that was serviceable and therefore could be removed easily for maintenance to either motor, esc or more likely the steerable nose wheel linkage. I settled on a ply box design that will screw down onto two ply plates, one fixed within the cowl area at the rear and another actually located onto the motor mount assembly. With the motor and mount in position this gives a nice study mounting bracket for a ply box to house the batteries neatly and securely above the nose wheel linkages and just aft of the motor. With a 3cell 5000mah lipo in place there is still loads of room to increase to 4 cells if required with plenty of cooling air around everything. Next job is finish off the battery box and then a few more detail bits and pieces, paint the stripes on the fins and hope the weather improves so I can finally get the acrylic resin finishing coat down that will finally seal the paint work. Not too much more to do now, maiden flight looming over Christmas it seems. Linds Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted November 29, 2015 Share Posted November 29, 2015 well you have done a fantastic job of it so far . Looking forward to the maiden Steve Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted November 29, 2015 Share Posted November 29, 2015 Looks terrific Linds, you have done a cracking job Cheers Danny Quote Link to comment Share on other sites More sharing options...
Tim Hooper Posted November 29, 2015 Share Posted November 29, 2015 Have to second what the others have said. Looking forwards to seeing this aberration in the air! tim Edited By Tim Hooper on 29/11/2015 21:59:41 Quote Link to comment Share on other sites More sharing options...
Lindsay Todd Posted November 30, 2015 Author Share Posted November 30, 2015 Much appreciated chaps. I have really enjoyed this one, whilst other larger projects are on going albeit slowly, the next design is a lot simpler, drawings done, parts cut and building commenced but will just hold back posting a blog till this one is complete but it is again something different for me. Linds Quote Link to comment Share on other sites More sharing options...
Simon Chaddock Posted December 1, 2015 Share Posted December 1, 2015 Lindsay That;s a very impressive build indeed with a spectacular finish. Hope it flies as well as looks! Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted December 1, 2015 Share Posted December 1, 2015 Have to agree with the others, not so ugly after all and a superb job Job Quote Link to comment Share on other sites More sharing options...
Lindsay Todd Posted December 12, 2015 Author Share Posted December 12, 2015 Well still fiddling about with some details. I have been wanting to make a dummy landing light but was looking around for something for the lens and was really struggling to track anything down although I was tempted to go with Danny's method on his Chipmunk until by blind chance I came across some jewellery parts in a craft shop. Perfect size and with the aid of some balsa dowel I found a good compromise and the lenses only cost £2.99 When finished this was glued into the cut out and a piece of clear acetate was cut to size to wrap around the leading edge with a 2mm overlap around the cut out area. I also cut a section of paint mask film and applied this to the outside face. The acetate was then glued and taped down onto the wing with rc modellers glue and masking tape and left to dry. Once dry I added some rivet glue droplets and then a coat of paint to match in with the wing Also took the opportunity to cut out the windshields and get these glued into a slot cut into the fuselage with a hacksaw blade and again glued in place with rc modellers glue. Few other bits still to do but should get some work done this weekend now including looking at the power set up and checking the cg ready for the maiden flight. Linds Quote Link to comment Share on other sites More sharing options...
onetenor Posted December 12, 2015 Share Posted December 12, 2015 glad to see you used the proper undersurface paint .It's proper designation is Sky type " S " Not an ugly bird to my eyes .If you want ugly have you seen a Wiek W1. Here is a pic or two... https://uk.images.search.yahoo.com/search/images;_ylt=A9mSs2FAemtWG6YAbRxLBQx.;_ylu=X3oDMTE1aGhudHRmBGNvbG8DaXIyBHBvcwMxBHZ0aWQDVUlVS0NDMDFfMQRzZWMDc2M-?p=Wecik+W1&fr=mcafee There is also an Ercoupe which might remind you of something LOL Quote Link to comment Share on other sites More sharing options...
onetenor Posted December 12, 2015 Share Posted December 12, 2015 Sorry that link isn't working . But Google for Weick W1 Quote Link to comment Share on other sites More sharing options...
Lindsay Todd Posted December 12, 2015 Author Share Posted December 12, 2015 Yep the Weick W1 is pretty weird, one for Tim perhaps he tends to go for those type of things. I actually think the Owlet its quite a pretty aircraft now I have spent a little time putting her together, bags of character and that's what I generally go for in a design. Linds Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted December 12, 2015 Share Posted December 12, 2015 It was a great choice to start with Lindsay and you've brought to our attention one of those planes that didn't make it, even though probably being just as good as some that did. It gives us the chance to see in the air a plane that we never would by any other means. I'm all for that and realise what a long way I'm still off from doing anything as good. Can't wait to see it flying, I can't see it doing anything other than fly very well. It's a plane that I was aware of, but you've brought it back to life. Quote Link to comment Share on other sites More sharing options...
Lindsay Todd Posted December 12, 2015 Author Share Posted December 12, 2015 Thanks Colin very kind of you, hope I have done it justice not quite finished yet but very nearly there and sort of off the building bench now - what next, well underway actually. Linds Quote Link to comment Share on other sites More sharing options...
Lindsay Todd Posted December 19, 2015 Author Share Posted December 19, 2015 New battery and not spending the time and effort soldering the replacement leads for connection results in one outcome. Yup allowing the genie to escape from your brand new 60amp esc doh! new one ordered, I am stupid after all and slightly poorer as a result of laziness. Linds Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted December 19, 2015 Share Posted December 19, 2015 Oh no! Polarity reversed? Quote Link to comment Share on other sites More sharing options...
Lindsay Todd Posted December 19, 2015 Author Share Posted December 19, 2015 yup stupid , stupid , stupid etc, etc me Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted December 19, 2015 Share Posted December 19, 2015 So easy to do though. When I was building the XB42 I wrecked my first contra-prop motor unit by messing up the connections to the ESCs. An obvious stupid mistake, but when it's done, it's done sadly. Quote Link to comment Share on other sites More sharing options...
Lindsay Todd Posted January 1, 2016 Author Share Posted January 1, 2016 Well the weather has delayed any thoughts of flying but I realised still a few bits and pieces to update starting with the exhaust stubs which are made from cut lengths of ABS tube simply glued into holes on the underside plate of the cowl. Little paint to detail and looks ok I think Still more surface detail bits I can add over time but back to the main radio and esc installation. A new Turnigy plush 60amp esc has been fitted alongside the battery plate made from 3mm light ply which is screw fixed to ply rails fitted to the rear of the motor mount and spanning the fuselage at the rear of the hatch opening. This gives a huge space for up to 5000mah 4s packs. I did some power tests and due to prop size have decided to go for a 4cell lipo set up to keep the prop diameter down to 11 inch max to maintain reasonable ground clearance and get the 550-600 watts I am looking for so two new 4000mah 4cell 25c packs on order. flight tests soon I hope. Linds Quote Link to comment Share on other sites More sharing options...
Lindsay Todd Posted January 9, 2016 Author Share Posted January 9, 2016 Well its a pilot and will do for now, also got a chance to set up the cg and do a final power check. A bit heavier thanks to the added detail work and comes in at 5.5lb exactly but should be fine and balanced perfectly on my estimated cg point with a 4cell 4000mah lipo so that was a result. With the Turnigy 3548/4 1100kv motor on a 11x8 apc I am getting 600watts at 40amps so well within the 60amp esc and gives room for further experimentation so just over 100watts per pound model weight an should be quite sufficient for a scale performance. now just need the weather. Finished and ready for maiden flight Linds Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted January 9, 2016 Share Posted January 9, 2016 Well worth the bit of extra weight, that looks very good..enjoy the maiden John Quote Link to comment Share on other sites More sharing options...
Chris Barlow Posted January 9, 2016 Share Posted January 9, 2016 Looks 20 years old and well used already. Excellent work on the details and finish! Quote Link to comment Share on other sites More sharing options...
Tim Hooper Posted January 9, 2016 Share Posted January 9, 2016 That's stunningly ugly. I'm very proud of you! tim Quote Link to comment Share on other sites More sharing options...
Lindsay Todd Posted January 9, 2016 Author Share Posted January 9, 2016 Cheers guys nice to be different sometimes looking forward to seeing how she flies now, darn weather. Quote Link to comment Share on other sites More sharing options...
Bob Bertram Posted January 10, 2016 Share Posted January 10, 2016 Impressed! Quote Link to comment Share on other sites More sharing options...
mightypeesh Posted January 10, 2016 Share Posted January 10, 2016 Thats a great looking model, nice patination top job! Good luck with the maiden Cheers, Simon Quote Link to comment Share on other sites More sharing options...
