Ian Jones Posted January 23, 2017 Share Posted January 23, 2017 Well Tony what can we do to help? Have you had a look at the layers (slices) that will be printed prior to actually sending it to the printer? Might help to see what is going wrong if you haven't: As you move the slider up and down you can see how the layers will be built up. If that doesn't help then perhaps you would like to send me the .stl file that is failing. I don't claim to be an expert but I'd be happy to have a look if I can spot anything. Ian Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted January 23, 2017 Author Share Posted January 23, 2017 if i lay it flat in cura. and go through the layers it is solid. if i stand it on its end and go through the layers the holes are there. i am lost and about to kick the cat... if we had one. Tony B Quote Link to comment Share on other sites More sharing options...
Colin Bernard Posted January 23, 2017 Share Posted January 23, 2017 Tony- clutching at straws but what is the thickness of the panel? Could it be less than the layer height? e.g. a .2mm thick panel with a .3mm first layer. I had something similar with text not printing and that was due to the fact that I had not extruded the letters beyond the layer depth . This would explain why you only see the holes when the panel is vertical. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted January 24, 2017 Author Share Posted January 24, 2017 the panel is 2mm thick. i am going to try once more and then if i get no where i think alcohol will be needed. Tony B Quote Link to comment Share on other sites More sharing options...
Andy Meade Posted January 24, 2017 Share Posted January 24, 2017 At least let the sun get over the yard arm old chap! Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted January 24, 2017 Author Share Posted January 24, 2017 gave up with holes. prototype printed, now for the big one. Tony B Quote Link to comment Share on other sites More sharing options...
Geoff Gardiner Posted January 24, 2017 Share Posted January 24, 2017 Hi Tony. Looks like you are getting the hang of it. After reading one of your postings on another thread, I had a look at the GearBest website and after lots of indecision I hit the buy button on the Anet A8. I believe this is the same as yours. According to the website, it will be coming from China so I hope I don't get stung for import duty. Did yours come from the UK? At the moment I am playing with Fusion 360 which is quite a learning curve. Geoff... Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted January 24, 2017 Author Share Posted January 24, 2017 mine came from the uk, the midlands and took 14 days. yes mine is the Anet A8. you have to build it yourself, but it is not too hard. Thanks Tony B Quote Link to comment Share on other sites More sharing options...
Mannyroad Posted January 24, 2017 Share Posted January 24, 2017 Posted by Colin Bernard on 22/01/2017 01:20:44: Fusion 360 is currently free to hobbyists. The licence runs for a year and you can then renew it. Colin, that sounds pretty interesting as long as its renewable. Do you know if its renewable over and over, or just the once? Edited By Mannyroad on 24/01/2017 20:46:26 Quote Link to comment Share on other sites More sharing options...
rcaddict Posted January 24, 2017 Share Posted January 24, 2017 Fusion 360 just watch, Im pretty sure you need window 8 or 10 as well Quote Link to comment Share on other sites More sharing options...
Colin Bernard Posted January 24, 2017 Share Posted January 24, 2017 Fusion will run on Win 7, 8 or 10 so long as you have a 64 bit CPU. Details here. As to renewal, ask me in 10 months? Can't find anything in the terms and conditions, and when you look at the forums, some say they just renew every year with no problem, and others say they are asked to take out a subscription. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted January 25, 2017 Author Share Posted January 25, 2017 leg braces for the Ensign. still working on the instrument panel, added dial mounts and mounting screws today. finally starting to get the hang of this, still cant get the wheel right yet. Tony B Quote Link to comment Share on other sites More sharing options...
Colin Bernard Posted January 25, 2017 Share Posted January 25, 2017 Great progress Tony. Guess it's not going out of the window any more! Quote Link to comment Share on other sites More sharing options...
Ian Jones Posted February 4, 2017 Share Posted February 4, 2017 Oops, nearly missed noticing your excellent progress Tony, well done. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted February 4, 2017 Author Share Posted February 4, 2017 Tony B Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted February 4, 2017 Share Posted February 4, 2017 Excellent stuff Tony. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted February 23, 2017 Author Share Posted February 23, 2017 70mm and 35mm diameter 3D printed seven cylinder radials under construction. need to print the heads and front covers next. we print on Tony B Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted February 23, 2017 Share Posted February 23, 2017 Ah printing your own money then...you'll cop it if they find out Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted February 26, 2017 Author Share Posted February 26, 2017 Still playing with these. collector rings and push rods now designed and waiting for the printer to become free. Tony B Quote Link to comment Share on other sites More sharing options...
Geoff Gardiner Posted February 26, 2017 Share Posted February 26, 2017 I am still yet to build my Anet A8 but in the meantime I have been getting to grips with Fusion 360. I have designed these bits for my TN Mosquito that I am currently building. Not sure how they will print. Geoff... Quote Link to comment Share on other sites More sharing options...
David Holland 2 Posted February 26, 2017 Share Posted February 26, 2017 Geoff.......? I'm sure I am about to say something really silly, but the Mossie used Merlins which are V12s and you have 5 exhaust stubs. What am I missing? David Quote Link to comment Share on other sites More sharing options...
cymaz Posted February 26, 2017 Share Posted February 26, 2017 Posted by David Holland 2 on 26/02/2017 19:31:18: Geoff.......? I'm sure I am about to say something really silly, but the Mossie used Merlins which are V12s and you have 5 exhaust stubs. What am I missing? David That got me thinking, so I had a look on the interweb. Some mossies have 5 stubs, some have 6. So it must be to do with plane/ engine variants Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted February 26, 2017 Author Share Posted February 26, 2017 "WOW" Geoff that is some great designing. Lets hope they print well as my stuff tends to need a few tweeks before i can get them printed. Tony B Quote Link to comment Share on other sites More sharing options...
cymaz Posted February 26, 2017 Share Posted February 26, 2017 All you need to know about the Mosquito B Mk IV Series II Here Quote Link to comment Share on other sites More sharing options...
Mowerman Posted February 27, 2017 Share Posted February 27, 2017 Thanks cymaz I had often wondered about why the Hornet only had 5 stubs each side. This despite being an engine fitter in the RAF and training on Merlins then later working on Griffons. Quote Link to comment Share on other sites More sharing options...
