Ripmax Chris Foss trainer help please
andy paterson
You are sure the CG is correct ? Changing to a smaller engine won't cure problem Can you trim out the ballooning with the elevator trim? If not it could be either engine thrust line is wrong or the wing incidence is wrong. Without seeing the model it's difficult to diagnose . Do you belong to a club ? If you do I'd get an experienced builder/ flyer to look at it as it could be a combination of faults .We did have a member who bought one a couple of years ago and the fitting of the wings was so bad due to poor manufacture that it kept ballooning , he returned it and got a replacement . That was totally different and flew fine. Let us know how you get on .
andy-i don't have the model -I've seen one flying...the 53 is a pretty powerful motor for the model also..i may need the motor mount packed to give some down thrust-or the tail plane packed to remove the tendency to climb....wait until a owner of the model comes on to the forum with some info for you or try - Google..there may be some advice about the model etc...
ken Anderson...ne....1..... ballooning dept.
I don't know the model either, but how is the wing held on?
I do know that the UnoWot - which was an earlier version of a trainer from Chris Foss - (and a very good one, IMHO), had the wing held on with rubber bands.
More than once I saw beginners turn up with just 2 crossed bands to hold the wings on, and they exhibited a similarly bad behaviour...
If it is a banded on wing, make sue you have 2 crossed, then 2 parallel, then another 2 crossed.
Otherwise I would think the Irvine 53 is a tad too big for the model - I have one in a DSM Contact 140, which is a serious, old school pattern plane, around 56" span, and that goes unlimited vertical on an 11x9 prop - not what you want on a trainer!
I fly many of these as i am responsible for training at my club and they do have a large pitch change with airspeed. the 53 is much too powerful for the model and frankly a decent 36 would do it as they are just big old gliders at the end of it.
The best one i have flown so far is 52 4 stroke powered and has a ton of lead on the tail for c/g. the additional weight helps settle the model and its quite nice to fly now.
Andy, its a long time since i had one, cant remember anything about engine except it floats forever when landing. but engine fitting should be same as any other. Try this place a spirit level on vertical stab at tail and lift tail up until its level, then look at front of plane - point the prop towards the ground and you should be able to see if it has any down thrust. " yes there should be some....
Posted by Jon Harper - Laser Engines on 10/04/2017 11:03:45:
I would echo this , my least favourite model to train people on. The Irvine 53 is a gutsy performer for a small two stroke, I too would dowsize it to a 52 size four stroke.
I would also replace the airframe with a Seagull Boomerang whilst I was at it😉.
Edited By Justin K. on 10/04/2017 17:24:39
Posted by andy paterson on 10/04/2017 17:03:49:
Just had a look at the engine mount, and they have been put on below the original mount points, would this give me the ballooning effect when throttle is increased
A low crankshaft centre line would increase pitch up with power - the resulting elevator trim for level flight at cruise power will then drop the nose excessively with power reduction. More downthrust would reduce this effect...but it wouldn't hurt to put the engine where Chris specified.
If you limit the servo throw to about 60 percent of an open full throttle position most of the ballooning will go away, i.e. You will have less power. And when it balloons, ease in a bit of down elevator, to keep the nose from rising, the excess speed will bleed away, and as it slows, ease off the down elevator.
I would not be too quick to blame the tools, that is a fine, if overlarge motor, and a well respected trainer. But it flies in real air, it has its quirks, as they all do, and a thousand circuits cures your inability to fly it, as long as you address your problems. You fly it, it does not dictate what it does.
I wish my dogs would learn that lesson. Had one timid creature in the river this afternoon.
Surely any badly set-up model is going to add greatly to the pilot workload and make flying - especially if you're still a learner - so much harder.
From my free flight scale experience (as well as setting up DLG gliders and most recently my Acrowot, which certainly had a few ARTF issues!) I'd suggest that, in addition to considering downsizing the engine or at least limiting its throttle, I'd assume nothing and:
1. Ensure the centre of gravity is in the correct place (say the mid-point of the suggested range). Its possible that the extra weight of your big engine the CG is putting this too far forward. Thus, to achieve normal level flight you might have elevator up-trim dialled in, so any blast of power will then cause ballooning. A dive-test will soon tell whether the CG is correct.
2. Have a good look at sorting out down-thrust and possibly side-thrust. The greater the power, the greater the need for this. The possibility of this being a culprit is increased as the design/factory-setting for side and down thrusts will assume a smaller motor is being used. Washers, correctly sized to your mounting screws, can be inserted between the bulkhead and the engine-mount (or between the engine and the bearers) to increase these.
2. Take a close look at whether the tailplane (horizontal stabiliser) is parallel to the datum line (assume this, for your purposes, to the mid line between the tailplane leading-edge and the engine) and also what incidence the wing is set to. If the incidence of the tailplane is negative relative to the datum line, then you've got built-in up-elevator. If the incidence of the wing is excessively positive, then you're going to have similar issues.
Hope this helps,
Jon
PS I've just realised that this all repeats various bits of advice above.  But I'd reiterate my advice to assume nothing and check everything.  My Chris Foss Ripmax Acrowot ARTF came out of its box missing its elevator completely and I then discovered the wing had a 1deg NEGATIVE incidence.
Edited By Jonathan M on 11/04/2017 20:56:36
Posted by Jonathan M on 12/04/2017 08:35:07:
I always understood 'stab' to be an abbreviation of 'stabiliser', its usage originating in America.
+1 to what he said....
Also, is this model at all related the old Uno Wot that CF used to sell as a trainer?
I used to do a lot of instructing and that was my favourite trainer, and yes, it essentially had a glider wing and flew well on a decent 32 or cooking 40 - if its the same model an Irvine 53 is way over the top.
I used to have one with a Irvine 40 and it went like stink for a trainer, also when the sun came out it was difficult to land due to heat coming off the patch. A slight breeze made it difficult to taxi could do with a steerable wheel on the back for a tail dragger.
Edited By trebor on 12/04/2017 13:33:40
