Paul Marsh Posted February 4, 2018 Share Posted February 4, 2018 Although done loads of 4 stroke engines - replacing bearings. Replacing the bearings on my OS 95 FS-V, but can't remove the piston/con rod, as the con rod can't go any further back to warrant removal. How do they (OS Engines) get it in the first place. Don't know if anyone has done, so,but looks like a scrapper - can't replace the bearings, by getting the con-rod out. On normal 4 strokes, there is no problem, but this design is different... Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted February 4, 2018 Share Posted February 4, 2018 There is a lad does a rebuild on YouTube Paul OS FS-V 95 engine Quote Link to comment Share on other sites More sharing options...
bert baker Posted February 4, 2018 Share Posted February 4, 2018 Take the liner out Quote Link to comment Share on other sites More sharing options...
David Ovenden Posted February 4, 2018 Share Posted February 4, 2018 I think this could be the video you need. **LINK** Quote Link to comment Share on other sites More sharing options...
Paul Marsh Posted February 4, 2018 Author Share Posted February 4, 2018 already did. anyway, did manage to do it. just need a set of bearings. Although going to get a set on Friday, does anyone know of a on-line source, with the correct size? Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted February 4, 2018 Share Posted February 4, 2018 Modelfixings.co.uk Quote Link to comment Share on other sites More sharing options...
Paul Marsh Posted February 4, 2018 Author Share Posted February 4, 2018 Thanks, but they are closed for a week, until 9th Feb. Bit rubbish, really. How can anyone stay in business when they shut down for a week! crazy...! Quote Link to comment Share on other sites More sharing options...
CARPERFECT Posted February 4, 2018 Share Posted February 4, 2018 Not sure where you live Paul ? but look for a local bearing shop. there are loads. I got front, rear and a cam bearing for £12. and they are good ones. Just engines wanted £32 plus postage. i got mine from Huddersfield Bearings 01484 515054 but you will need to tell them the exact size, mine were for a ASP 70 FS. Quote Link to comment Share on other sites More sharing options...
Paul Marsh Posted February 4, 2018 Author Share Posted February 4, 2018 There is local bearing supplier, which I can only go next friday, which I will now. I'll take the removed ones in and at least it will help identification. Quote Link to comment Share on other sites More sharing options...
cymaz Posted February 4, 2018 Share Posted February 4, 2018 Quality bearings online.com. Had a couple of orders , very pleased. I even got a free pen and Christmas card . Any numbers on the bearings? That should make it easy to get the correct size. Edited By cymaz on 04/02/2018 22:27:48 Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted February 7, 2018 Share Posted February 7, 2018 Any bearing supplier will be able to get bearings for you. Measure outside diameter ,inside diameter and width with a Vernier gauge. Simply bearings are very good ,do a range of differing price / quality for each bearing size. Excellent despatch times,bearings usually arrive the next day if ordered before me afternoon. Edited By Engine Doctor on 07/02/2018 09:42:13 Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted February 7, 2018 Share Posted February 7, 2018 Try Simply Bearings on line, very fast delivery, select your preferred brand. They even sent them over the Christmas period once. Cheap too, Quote Link to comment Share on other sites More sharing options...
