GrumpyGnome Posted July 18, 2023 Share Posted July 18, 2023 Brilliant! Looking forward to the painting posts...... Quote Link to comment Share on other sites More sharing options...
Outrunner Posted July 18, 2023 Share Posted July 18, 2023 That looks awesome! Well done Dirk, fantastic model. Sounds like a gas turbine. Looking forward to seeing the model painted. Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted July 18, 2023 Share Posted July 18, 2023 Well Done. You could not of asked for a better maiden than that. Congratulations all your hard work has paid off. 👍 Steve Quote Link to comment Share on other sites More sharing options...
Murat Kece 1 Posted July 18, 2023 Share Posted July 18, 2023 Well done Dirk.. What a mater build and what a plane.. It flies like the real one.. Congratulations.. Quote Link to comment Share on other sites More sharing options...
Phil Cooke Posted July 19, 2023 Share Posted July 19, 2023 A superb result Dirk, was never in doubt - truly a masterpiece and I cant wait to see it painted and detailed! Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted August 31, 2023 Author Share Posted August 31, 2023 Hello all ! After the first flights it's time for the detailing ! Before the paint job , i need to make all the little things that "dress"the model like the elevator mass balancers , scoop, cooling air intakes, antennas... I started with the balancers. Made up the bases from aluminium scraps and the rest from epoxy plate. Everything has to be trimmed but i'm happy so far . 4 Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted August 31, 2023 Author Share Posted August 31, 2023 Note that the red elevator is a test piece that was too heavy... Glad i didn't bin it 5 Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted September 3, 2023 Share Posted September 3, 2023 Looks and sounds fantastic well done Dirk, mammoth effort! Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted September 8, 2023 Author Share Posted September 8, 2023 Thanks Danny ! The mass balancers are ready to sand and mount .The screws will be replaced by epoxy pins glued in. The bases will be screwed. 2 Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted September 14, 2023 Author Share Posted September 14, 2023 After the mass balancers it's time for the coolers on the motor hatch (pic). New technique: I changed a round pvc plumming tube into a flat plate by heating with a paint stripper, Next , i formed a flat piece into a half rond tube on a 11mm round Metal bolt. Next is a flat piece for the base , glued together gives a perfect cooler! 1 Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted September 25, 2023 Author Share Posted September 25, 2023 More plane jewelry ! X 7 1 Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted October 21, 2023 Author Share Posted October 21, 2023 Hey guy's Next on the (long) list are the gunports. I've chosen the El Salvadorian paint livery wich use two guns in the nose. Most Fouga's dont have them so they are not in the moulds. I found a way to make them without opening the fuse too much! First i made a little mould of the fuse nose section Then added two pieces of Metal tube wich have the exact form i needed.( it's a tube that holds the hangers in an old closet. When sanded and painted , i'm going to mould this part on the inside wich gives me the perfect gunports...i hope ! 2 Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted October 21, 2023 Author Share Posted October 21, 2023 Hey guy's Next on the (long) list are the gunports. I've chosen the El Salvadorian paint livery wich use two guns in the nose. Most Fouga's dont have them so they are not in the moulds. I found a way to make them without opening the fuse too much! First i made a little mould of the fuse nose section Then added two pieces of Metal tube wich have the exact form i needed.( it's a tube that holds the hangers in an old closet. When sanded and painted , i'm going to mould this part on the inside wich gives me the perfect gunports...i hope ! 7 Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted October 21, 2023 Author Share Posted October 21, 2023 not sure what happened ?? Sorry for the dubbel post... Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted October 22, 2023 Author Share Posted October 22, 2023 This is how it is supposed to look x 2 1 Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted October 26, 2023 Author Share Posted October 26, 2023 Hi all ! as in the last photo , my chosen version has the big antennas upfront. While the paint on the new little mould drys , i took a shot at replicating these. I started to glue 3 layers of 1.5mm epoxy plate together , cut it to the desired shape , and sanded the rest off with a dremel and sandpaper. I'm not sure yet , how to fix them to the fuse but they do look good !! 4 Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted October 27, 2023 Share Posted October 27, 2023 They make good carrying handles. Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted November 4, 2023 Author Share Posted November 4, 2023 Hello all ! Today i cutted out the two gun ports and presented them to the fuse. It won't be easy to get them in because of the formers inside the fuse. I opened up the fuse and after a while sanding with the dremel i got them in.Satisfied with the fit , i glued them in with 30 min epoxy They stil need some sanding and filling but overall i like them.with the guns in place it will look good ! 4 Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted November 5, 2023 Author Share Posted November 5, 2023 Hello again , no time to waste ! Today i sanded the gunports , not filled yet , but made some guns from 2 different diameters plastic tube . Looks fine to me ! 8 Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted November 13, 2023 Author Share Posted November 13, 2023 Hello all ! Gun ports , nose antennes, de-icer , done ! Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted November 13, 2023 Author Share Posted November 13, 2023 De icer sanded 10 Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted November 23, 2023 Author Share Posted November 23, 2023 Hello all ! Thanks for the likes on previous posts ! Last on the accessoires list are the mass balancers on the aileron trim tabs. They are not functional and the balancers will be glued in. First pic is the real stuff. 6 Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted November 25, 2023 Author Share Posted November 25, 2023 Hello all , Another great scale item , and very much needed to slow this bird down on landings are the speed brakes. Flying buddy Ben Van Raemdonck , also 3D printing enthousiast made the moving parts for the brakes. It's Just a test print and a lot of time will be spent adapting them to the wings and form 4 complete drop-in brake units .The wiring is already inplace in the wings up to the receiver . 5 Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted December 1, 2023 Author Share Posted December 1, 2023 First prototype of the speedbrakes . 6 Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted December 8, 2023 Author Share Posted December 8, 2023 Hello all ! The speed brakes are going to take some time i'm afraid... I made the servo support from alu T profile .It took a lot of fitting before i was happy with it ! It will be screwed on the hard wood support but the screws (M2 )will go into the little back-up plate under the wood for better grip . The little pin on the end goes into a wing rib. The gap on the right is to let the servo wire trough. I love this kind of Jobs! The brakes are next ! 5 Quote Link to comment Share on other sites More sharing options...
