Cliff Bastow Posted January 15, 2019 Share Posted January 15, 2019 I use a Futaba 8FG super. I have been copying my models from the transmitter memory to a memory card so I have a copy of them but for some reason some of the controls come out reversed from the original. Does anyone know why this should happen please? Edited By Cliff Bastow on 15/01/2019 16:54:58 Quote Link to comment Share on other sites More sharing options...
Cliff Bastow Posted January 16, 2019 Author Share Posted January 16, 2019 No ideas anyone? Quote Link to comment Share on other sites More sharing options...
The Wright Stuff Posted January 16, 2019 Share Posted January 16, 2019 Do the controls that come out reversed happen to be ones that were reversed in servo direction to start with? Think we need a bit more to go on, Cliff! Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted January 16, 2019 Share Posted January 16, 2019 Ha ha Cliff, as soon as we comment, a Cavalier will come sweeping in and tell us how wrong we are. Also, we are not all Futaba savvy. With my Spekrum SD card, if I drag and drop to copy, some parts are reversed ! ! But when I use the drop down menus to copy, then all is well I really down know why as this action is quite rare, not being a regular routine I may copy once a year Quote Link to comment Share on other sites More sharing options...
SR 71 Posted January 16, 2019 Share Posted January 16, 2019 Hi Cliff, this is one of the thing with futaba that i dont like, they reverse the throttle on their own at times I have the 14sg and it caused me an injury, switched on with throttle closed and it flew of the bench and took a 75mm x 10 x 5mm chunk out of my upper arm, another foot higher and it would have been my face So always check the throttle before switching on, had it happen the other day this time with a 50cc but it was tethered, and i had had the engine running a few minutes before, all normal So take care Tony Edited By SR 71 on 16/01/2019 10:54:58 Quote Link to comment Share on other sites More sharing options...
Allan Bennett Posted January 16, 2019 Share Posted January 16, 2019 Posted by SR 71 on 16/01/2019 10:54:22: Hi Cliff, this is one of the thing with futaba that i dont like, they reverse the throttle on their own at times. . . Just the throttle -- no other channel? I'm aware that the Futaba throttle channel has to be reversed compared with most other brands, but I've never heard of a channel changing direction without human intervention. Certainly it hasn't happened to me in 30+ years of Futaba ownership. Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted January 16, 2019 Share Posted January 16, 2019 Posted by Cliff Bastow on 15/01/2019 16:53:54: I use a Futaba 8FG super. I have been copying my models from the transmitter memory to a memory card so I have a copy of them but for some reason some of the controls come out reversed from the original. Does anyone know why this should happen please? Edited By Cliff Bastow on 15/01/2019 16:54:58 Lads, the OP, COPYING Is when reversal occurs Quote Link to comment Share on other sites More sharing options...
John Stainforth Posted January 16, 2019 Share Posted January 16, 2019 I think the radio manufacturers set up their gear so that a "normal" servo setting corresponds to (what they regard) is a "normal" mounting orientation of the servo. When we mount a servo in the opposite direction we then have to set "reverse" on our TX's. So the manufacturers regard this as an idiosyncrasy of a particular model/servo set up and not something worth copying to another model, which may have the servos mounted in the conventional orientations. Quote Link to comment Share on other sites More sharing options...
Cliff Bastow Posted January 16, 2019 Author Share Posted January 16, 2019 Thanks for the replies lads. I have checked and it is the channels that were reversed in the original model set up. They seem to have reverted to default settings in the copy's. Something to be aware off in future. Many thanks. Quote Link to comment Share on other sites More sharing options...
jrman Posted January 16, 2019 Share Posted January 16, 2019 There are no "conventional" or "normal" orientations of servo mounting. If you decide to connect the moving surface to one side of the servo arm or the other side (i.e. @ 180 deg.) you may have to reverse the servo direction in order to get correct surface direction. No manufacturer can forecast ( guess) which side you will use. Quote Link to comment Share on other sites More sharing options...
The Wright Stuff Posted January 16, 2019 Share Posted January 16, 2019 Posted by jrman on 16/01/2019 13:13:50: There are no "conventional" or "normal" orientations of servo mounting. If you decide to connect the moving surface to one side of the servo arm or the other side (i.e. @ 180 deg.) you may have to reverse the servo direction in order to get correct surface direction. No manufacturer can forecast ( guess) which side you will use. This is only true because we DO NOW HAVE the option to reverse the servo direction at the transmitter. Hence the designer or builder pays no regard to convention. Before the option to reverse at the transmitter became widely available (admittedly a few generations ago now), then there would have been a convention, and one would be wise to follow it... Quote Link to comment Share on other sites More sharing options...
jrman Posted January 16, 2019 Share Posted January 16, 2019 I'm going to disagree. There is no convention. Most combo's would be provided with some c/w servos and some anti c/w to enable the most appropriate to be used in a particular installation. Just imagine the following scenario: servo mounted in the left side of the tail end of a/c connected to elevator horn on the underside of surface. If the servo link is made from the " top" of the output disc then for up elevator the servo must rotate c/w. Put the same servo in the other side of the fuselage and the situation is reversed and the output must be from the "bottom" of the disc for up elevator or use a reverse direction servo .What convention would you use? Quote Link to comment Share on other sites More sharing options...
Cliff Bastow Posted January 16, 2019 Author Share Posted January 16, 2019 This is all very interesting, but I am not sure how relevant it is to my question? That is why have some of my settings become reversed when copying from my tx memory to an SD card? I would think a copy ought to be the same? Everything else such as rates etc seem to be the same. Edited By Cliff Bastow on 16/01/2019 16:19:22 Edited By Cliff Bastow on 16/01/2019 16:19:51 Quote Link to comment Share on other sites More sharing options...
John Stainforth Posted January 16, 2019 Share Posted January 16, 2019 There seems to be some disagreeing here for the sake of disagreeing, when all I see in the above discussion is agreement that there is no single convention: that the manufacturers set their gear to a more or less arbitrary conventions, which they call "normal", so that whenever we place servos in ways that do not comply with these we have to set "reverse" in our TX's. Quote Link to comment Share on other sites More sharing options...
CARPERFECT Posted January 16, 2019 Share Posted January 16, 2019 Just my ten pennith. Been a Futaba man 30+ years.i have a 8j and 10 j. you can transfer from one to the other wireless, some times copies perfect, others not, some servos reversed, no idea. but copying one model to create another both copy perfect. they do not have a memory card though. Quote Link to comment Share on other sites More sharing options...
Stephen Smith 14 Posted January 16, 2019 Share Posted January 16, 2019 Did you put the SD card in upside down? Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted January 16, 2019 Share Posted January 16, 2019 Posted by CARPERFECT on 16/01/2019 19:29:38: Just my ten pennith. Been a Futaba man 30+ years.i have a 8j and 10 j. you can transfer from one to the other wireless, some times copies perfect, others not, some servos reversed, no idea. but copying one model to create another both copy perfect. they do not have a memory card though. Quote Link to comment Share on other sites More sharing options...
The Wright Stuff Posted January 18, 2019 Share Posted January 18, 2019 Posted by Cliff Bastow on 16/01/2019 16:18:38: This is all very interesting, but I am not sure how relevant it is to my question? That is why have some of my settings become reversed when copying from my tx memory to an SD card? I would think a copy ought to be the same? Everything else such as rates etc seem to be the same. Well, I think we have established and agreed that the differentiator is whether the channel was 'reversed' or 'normal' in the tx memory. Thus although it doesn't actually answer the question 'why', it does at least take away the mystery or the apparent randomness of it. As to 'why'? Well, because someone working at Futaba decided to do it that way. We can only speculate regarding their logic, hence the inevitable differences of opinion. It's sufficiently on topic. It's civilised. I see no problem! jrman, I wasn't implying that any convention was universal, merely that manufacturers had their convention, and thus the definitions of 'normal' and 'reversed' are historical in origin. While there were certainly manufacturers that offered opposite servos, I think this was the exception rather than the norm. there is a nice description in this earlier thread. Quote Link to comment Share on other sites More sharing options...
John Tee Posted January 18, 2019 Share Posted January 18, 2019 Not Futaba but when I tidied up my Hitec Tx by deleting some models and the moved a model to one of the vacant spots it reversed some controls, so maybe they all reset any reversed channels. Not really any the wiser why it should happen. John Quote Link to comment Share on other sites More sharing options...
kc Posted January 18, 2019 Share Posted January 18, 2019 Could be a good idea to experiment with a spare memory and see if you can make it happen again, noting what you did or did not do. Maybe there is more than 1 memory with the same name - not in the Tx perhaps it was already on the memory card from previous use. Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted January 18, 2019 Share Posted January 18, 2019 Not just Futaba. I copied a fun fly model from one JR to another similar Tx. Well, the ailerons waggled but I did not check the direction. Ouch. Quote Link to comment Share on other sites More sharing options...
jrman Posted January 18, 2019 Share Posted January 18, 2019 Strange. I recently copied 8 models between two JR DSX9 Txs and everything copied perfectly including all servo directions, sub trims, mixes etc. Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted January 19, 2019 Share Posted January 19, 2019 I was copying from a DSX9 to a PCM9X2 which is supposed to be identical but maybe there are small differences other than the module on one. Quote Link to comment Share on other sites More sharing options...
jrman Posted January 19, 2019 Share Posted January 19, 2019 Martin, I've done that as well previously with no problems. Just make sure you set one Tx to "Transmit" in the transfer screen and the other Tx to "Receive " in its transfer screen. This step is easily missed. Pages 20&21 of the manual explain it but not as clearly as could be. Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted January 19, 2019 Share Posted January 19, 2019 At one time I had two DSX9`s and no problem copying from one to the other. Must try again with the 9X2 sometime. Quote Link to comment Share on other sites More sharing options...
