Nigel R Posted October 27, 2020 Share Posted October 27, 2020 I wanted; quick easy build (so no fancy shapes or tricky techniques or whatever) sized for a .46 or .60 two stroke, or a .70 ish four stroke, or thereabouts. Or, potentially, a 4S5000 electric. be able to some 3d type manoevers like hover and harrier minimal new wood use - scrapbox / leftovers / foamboard, etc. radio and servos from the drawer easy to transport Many moons ago I made an own-design fun fly type called FlapJack. This was in the early 90s when the 'monowheel and carbon tail boom' fun fly were appearing. I made one with a very basic box fuselage and conventional U/C, although it was like the contest fun fly types, all in one piece. I rather fancied having another similar model again. However that small fuselage wouldn't do a knife edge for toffee and the wing would need to be removable. As another thing to chuck in the mix, around a year ago I made a Bigga Bit from a mix of foamboard and liteply and balsa, which has worked out really well, so some of the construction from that was to be copied/re-used/etc. So. I ordered some 1/16 to sheet the wing with, and a couple of sheets of 1/8 to make a fuselage with. Everything else is scrapbox or leftovers. Ribs are all from foamboard. I stripped some balsa spars from some hard 1/4 and the LE / TE components from medium 1/4, and stuck the lot together with a standard D Box from 1/16 sheet. All quite conventional so far. 48" plank, in one piece, so I could use 48" sheets for the LE sheeting. As I only had 36" spar stock in the scrap box, I used that, and had to scarf join it toward the tip. More 1/16 sheet makes up the TE and caps, again all no surprises. Servos are dropped in between two closely spaced ribs. Quick and reasonably tidy, avoids having them hung right out in the breeze, just the arms poke out. Then I cut out some flat tip shapes from foamboard. These have some 4 lots of 1/16 x 1/4 strips laminated around the curved outline. Ailerons are also simply slabs of foamboard with balsa around the edges. Later on I'll add some 1/32 ply to take the control horns. Bags of wing area, Note leading edge cutout for fuselage. I don't have any pictures of the fuselage under construction. The lower half is a very much conventional balsa sides + 1/32 doubler build. I didn't buy any ply for formers - I dug out some B&Q cheap ply of around 5mm. It's not as heavy as proper birch ply and not as light as lite ply. The firewall is two pieces laminated together. At the front of the wing opening is a single thickness former to receive the wing dowel. All the other formers are foamboard or built up from some scrap balsa stripwood. I made the decking up as I went along. It's from two pieces of 3/32, again, leftovers, with a chunk of soft/med 1/4 making up the windscreen and front deck, just enough to make a nice round at the corner. All the decking formers are foamboard triangles (with the top chopped off). The tailplane is all exactly like the ailerons - slabs of foamboard with balsa edges. Thin strips laminated around the board to make curved tips. All very quick and easy. Not too much more woodwork left at this point. Updates to come when I have something interesting to add! 1 Quote Link to comment Share on other sites More sharing options...
Jonathan M Posted October 27, 2020 Share Posted October 27, 2020 Excellent mix-and-match creativity with available materials! Re the foam-board, how can it be shaped to section (e.g. ailerons) and how does it compare in stiffness and density to medium/light balsa? Quote Link to comment Share on other sites More sharing options...
kc Posted October 27, 2020 Share Posted October 27, 2020 Can we expect a plan for RCME? Quote Link to comment Share on other sites More sharing options...
Nigel R Posted October 27, 2020 Author Share Posted October 27, 2020 Jonathan, no shaping involved - these are just flat plates, I'm not tapering - that's far too advanced for this build! I was skeptical of the strength of this kind of structure but having used it on the Bigga Bit it seems plenty stiff. With the edging I would say comparable to a 3/16 sheet surface. A lot of that strength comes from the balsa edge; without it the foamboard is way too weak for something this size. I guess worth remembering, a lot of fun fly just have 1/4 balsa framework and a good part of the strength of those type surfaces comes from the covering. kc I have a rough plan drawn out of the wing and lower fuselage, so who knows, never say never Edited By Nigel R on 27/10/2020 12:05:20 Quote Link to comment Share on other sites More sharing options...
Graham Davies 3 Posted October 27, 2020 Share Posted October 27, 2020 Nigel, this is really good. I really appreciate 'scrap box engineering'; it's better than worrying about what we can't do, isn't it? As you know, I'm exploring foam board, and I can see all sorts of possibilities. I like the idea of ribs as it is quite stiff in compression, and 5mm board would do away with the need for cap strips. I think the gauntlet may have been firmly thrown down! As long as I have enough stock for my promised (to me) 3/4 sized baronette, I may join you... Graham Quote Link to comment Share on other sites More sharing options...
Nigel R Posted October 27, 2020 Author Share Posted October 27, 2020 Thanks Graham, although somewhat bizarrely I started this before I knew of the balsa shortage! In this instance the foamboard is perfect - the ribs are 12" long and you don't get many of those out of a 36" sheet of balsa... I would use caps by preference as the edge of the board is a bit fragile - when it comes to covering with film I found the caps really pay off. Quote Link to comment Share on other sites More sharing options...
Nigel R Posted October 27, 2020 Author Share Posted October 27, 2020 For reference my Bigga BIt build thread is here: Bigga Bit in which I took quite a few more pictures as I went, it shows the wing structure a better than this thread does. Quote Link to comment Share on other sites More sharing options...
Nigel R Posted October 29, 2020 Author Share Posted October 29, 2020 Some photos of the gear install work on the fuselage, whilst it is still open on the underside and everything is easy to access. The motor mount is recycled from something else, hence the two sets of holes. It was included with a 1.20FS I bought from the popular auction site. It is the first time I have used one of these T mounts, I have to say, they're very easy to set up. It is all M4 hardware (which came with the mount!) which matches up nicely with the lug holes in the 70FS I'm fitting. As is visible, for throttle duties, I simply poked a length of bowden cable through the FW. I'm using one of those screw connectors on the throttle arm. First time I've used these and can't believe I haven't before - it made the motor install a piece of cake. Much, much easier than the rocker arm setup I used on my last four stroke install, and it takes less space compared to a soldered on M2 extension + ball link. The other end of that cable has to be waggled by something - a lonely old standard servo at the back of the wing saddle area, resting on several 1/2" wide strips of B&Q 5mm ply. The wing blocks are also (surprise) some small rectangles of B&Q 5mm ply laminated together to make a 10mm thick lump, tapped M5 for several nylon bolts. Seeing as there aren't any other servos inside the wing area... they must be at the back end: I made the "box" first, from some hard 1/8 balsa, with (yet more) 1/2" wide strips of B&Q ply glued underneath, to take the screws. The whole lot was then carefully sunk into the side. It looks neater than just plonking some ply on the outside of the fuselage and doesn't take very much longer to do, just cut a few strips of balsa, cut them to length, and glue it up. The two servo holes needed a bit of careful planning to avoid clashing: but avoid clashing they do. There is also some extra lengths of longeron added around the openings to compensate for the big holes in the fuselage side. My no-expenses-spared foamboard formers are also clearly on show there. They were a time saving dodge, over my usual method of fitting balsa crosspieces. Incidentally, the fuselage longerons were all cut from the same 1/8 sheet that the fuselage side was cut from, waste not want not. I'm away from home (while we still can) for a few days now, then it is time to attack the undercarriage, the tailplane mounting, close up the fuselage underside, and then it will (practically) be ready for covering. Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted October 29, 2020 Share Posted October 29, 2020 Crackin' Stuff Nigel. D.D. Quote Link to comment Share on other sites More sharing options...
Nigel R Posted November 5, 2020 Author Share Posted November 5, 2020 Thanks DD Another week on and a few more jobs done, starting to get down to the little bits now. Fitted torque rod supports for some 8g wire gear, added some wing saddle triplers, reinforced the wing dowel hole, plus added a bunch of triangular stock jammed in the corners around firewall and "F2": Made a tailskid and stitched it to a piece of ply: Nearly forgot - put a paper tube in the fuselage to make servo install easier: And these untidy lumps of soft 1/4 will hold the fin in place. A little carve and sand to indulge in: Not much to go now. Get the fin support blocks shaped, then time to fuelproof inside the tank bay and FW, and close up the fuselage underside. Last two things, need some cowl cheeks, and a basic belly pan. Then it is covering time - must check on my film supplies and see what I have left! Quote Link to comment Share on other sites More sharing options...
Nigel R Posted November 13, 2020 Author Share Posted November 13, 2020 The belly pan done... another good use for foamboard - the thin side pieces were easy to squish around the airfoil, then I could neaten up the lower edge with the sanding block before the sheet went on. Tail end finished up and stuck on: And I stuck some cowl cheeks on to improve looks at the front end. I think they could do with a bit more of a curvy shape, they're a bit square as things stand: Total bench time, 45 hours. Total weight so far, 2lb (as pictured including all five servos and the engine mount). The Surpass 70 is a fair old lump - although they do run nice - and I think the finished product is looking like 4-3/4lb. This should give a wing loading of 14 oz/sqft, or the CWL for those that like it (I do) of 5.5, which is right down there in the slow and floaty end of things. Whilst this is not quite as light as a dedicated contest fun fly type she is more of a sport model than a contest thing. Not many jobs left - fit a strake, sort out the RX switch, cover up a few whoopses with wood filler and then get her covered. Might even have it polished off in time for the end of lockdown! Quote Link to comment Share on other sites More sharing options...
Zflyer Posted November 13, 2020 Share Posted November 13, 2020 Have you considered using the Graupner foam board for skinning. I have used it on a delta and it works a treat as it is very flexible. Comes is a variety of thickness Quote Link to comment Share on other sites More sharing options...
Nigel R Posted November 30, 2020 Author Share Posted November 30, 2020 Hi Zflyer - sorry didn't see you post earlier. I have not tried using foam board for skinning yet. I think it could be a good option especially on electrics. Quote Link to comment Share on other sites More sharing options...
Nigel R Posted November 30, 2020 Author Share Posted November 30, 2020 The last two weeks have been taken up with a lot of small finishing jobs, filling and sanding, fuel proofing, hinging, reinforcing for control horns, that kind of thing, nothing big. But also, the main film covering event: The orange is a bit more red in real life. Underside is an orientation-friendly dark colour: Need to add a couple of white flashes to the top side to break up that orange. Plus some dark bits for a pretend canopy. Quite pleased with how it has come out given the simple & quick nature of the build. My original plan was to use up covering in the scrapbox - some leftover yellow and the dark blue seen on wing underside. Problem was I didn't have enough blue to do the underneath. That meant the yellow wouldn't stretch to the whole airframe which mean I either had to buy more blue or more yellow. Then I couldn't find either colour again... so ended up buying a roll of orange, which turned out to be about a foot too short to cover the thing without buying a second... Hey ho. One tries. Jobs left - trim scheme, refit all gear... and go fly... so probably another month left then! Quote Link to comment Share on other sites More sharing options...
Nigel R Posted December 1, 2020 Author Share Posted December 1, 2020 Most gear in place. All pushrods to make up, battery to stow, trim flashes to add. Quote Link to comment Share on other sites More sharing options...
Graham Davies 3 Posted December 1, 2020 Share Posted December 1, 2020 Fantastic Nigel, looks like you nailed the brief. Of course, after 3 1/2 weeks of light winds, the start of which coincided with the start of lockdown 2.0, it's picking up nicely in time for the end! Good luck with the maiden; I am sure it will fly really well. Graham Quote Link to comment Share on other sites More sharing options...
Nigel R Posted December 1, 2020 Author Share Posted December 1, 2020 Many thanks Graham I have no doubt it'll be 2021 before she leaves the ground! Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted December 1, 2020 Share Posted December 1, 2020 Cracking job Nigel, looks like It'll fly up It's own backside, should be fun. Mini Jazzish. Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted December 1, 2020 Share Posted December 1, 2020 And it's my favourite colour Nigel, ................ apart from the blue bit. D.D. Quote Link to comment Share on other sites More sharing options...
Stuart Quinn-Harvie 1 Posted December 1, 2020 Share Posted December 1, 2020 That's fantastic! Looks a bit like a Funfly Chilli Breeze Great work Nigel. Edited By Stuart Quinn-Harvie 1 on 01/12/2020 18:26:28 Quote Link to comment Share on other sites More sharing options...
Nigel R Posted December 1, 2020 Author Share Posted December 1, 2020 Thank you gents Stuart, you've spotted my styling inspiration! DD, got to love the orange, it's grown on me. Maybe I should put some orange checks on the blue bit!? john, I must get that maneuver on camera Quite pleased with how quick it has come together... must be because it has been built in my study instead of out in the workshop (which is still under construction - although nearing completion now). I've been able to put in a half hour here and a fifteen minutes there every day since starting it two months ago. Quote Link to comment Share on other sites More sharing options...
Stuart Quinn-Harvie 1 Posted December 2, 2020 Share Posted December 2, 2020 You were dead helpful with my Chilli Breeze so it makes sense Are you going to submit the design to the mag? It's make a brilliant plan. Quote Link to comment Share on other sites More sharing options...
Tom Gaskin 1 Posted December 2, 2020 Share Posted December 2, 2020 Looking good! Do a search for 'super hots' for a 1980's doppelganger. Tom Edited By Tom Gaskin 1 on 02/12/2020 13:21:34 Quote Link to comment Share on other sites More sharing options...
Nigel R Posted December 5, 2020 Author Share Posted December 5, 2020 No worries Stuart. Not sure how I'd submit? Thanks Tom yes super hots has similar triangular decking lines for sure 👍 Last pic... finished bar pushrods, which are in the post... put some white flashes on to break up the orange: C of G has come out spot on at 5" back, which was nice. The battery needed to be stowed right at the back of the wing saddle. That 70 is a weighty lump! Final weight is 2.25kg / 5lb. A few oz over the expected. Only way to drop any weight that I can see is a smaller and lighter power plant. Quote Link to comment Share on other sites More sharing options...
DaveyP Posted December 5, 2020 Share Posted December 5, 2020 Hi Nigel, that looks really good and fairly simple to build, I have a question though. I've never used foamboard, so where do you buy it and what specification is it ? also what glue do you use ? Tia, Davey Quote Link to comment Share on other sites More sharing options...
