Diamond Geezer Posted November 26, 2021 Share Posted November 26, 2021 Hi guys should I wrap my 2.4 rx some at the club say yes others say no what’s your opinions please. Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted November 26, 2021 Share Posted November 26, 2021 Wrap it in what? In my electric models and gliders I just mount them with velcro, for my IC models I put them in foam (unless the receiver has soft mounts) Quote Link to comment Share on other sites More sharing options...
Diamond Geezer Posted November 26, 2021 Author Share Posted November 26, 2021 Thx Quote Link to comment Share on other sites More sharing options...
J D 8 Posted November 26, 2021 Share Posted November 26, 2021 With 2.4 rx's I was told that they should not be wrapped in foam or bubble wrap as they produce more heat [for their small size] than old 35 type's. Not sure how true this is but have velcro pad mounted all mine both IC and electric. Quote Link to comment Share on other sites More sharing options...
Diamond Geezer Posted November 26, 2021 Author Share Posted November 26, 2021 JD see what I mean you Don’t butFrank does I don’t know what to do. Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted November 26, 2021 Share Posted November 26, 2021 the crack was,they do generate more heat,so in electric...no wrap,ic wrap in loose foam ken anderson..ne..1..wrap dept. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted November 26, 2021 Share Posted November 26, 2021 I don't wrap mine, bind light being the reason, in old days they were big lumps and had inertia in a crash, not so much now being tiny and I don't crash. ? 1 Quote Link to comment Share on other sites More sharing options...
Diamond Geezer Posted November 26, 2021 Author Share Posted November 26, 2021 Thanks Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted November 26, 2021 Share Posted November 26, 2021 1 hour ago, john stones 1 - Moderator said: not so much now being tiny and I don't crash. ? Tempting fate or what !? Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted November 26, 2021 Share Posted November 26, 2021 2 minutes ago, Engine Doctor said: Tempting fate or what !? Yep. ? Quote Link to comment Share on other sites More sharing options...
John Lee Posted November 26, 2021 Share Posted November 26, 2021 If your receivers have built in gyros/stability they will need to be mounted securely using double sided dense foam tape. Otherwise Velcro is a good option. Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted November 26, 2021 Share Posted November 26, 2021 2 hours ago, J D 8 said: With 2.4 rx's I was told that they should not be wrapped in foam or bubble wrap as they produce more heat [for their small size] than old 35 type's. Not sure how true this is but have velcro pad mounted all mine both IC and electric. That was the case with some very early 2.4 receivers, from Futaba I think, but the problem only arose in warmer climates where there was a big cockpit letting the sun heat the model internally. From Multiplex's receiver installation notes - "Protect your receiver from vibration, especially in models powered by internal combustion engine (e.g. pack it loosely in foam)" they make no mention of making sure it doesn't overheat. Just checked Futaba's instructions for their R3008SB and they specifically mention protecting the receiver from vibration "The R3008SB receiver should be protected from vibration by foam rubber, Velcro or similar mounting methods. Protect from moisture" again no mention of overheating. So basically do what ever your manufacturer instructs. Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted November 26, 2021 Share Posted November 26, 2021 Receivers are very different these days. Earlier ones had larger components atop wobbly legs which could fracture through vibration or impacts, often ripping out chunks of copper tracks as they attempted to get further into the crash than the PCB. Modern surface mount components have much smaller mass and are soldered directly to theIr PCBs. Given space, on both IC and electric models, I like to clip them into 3D printed mounts which I either foam or Velcro mount to the fuselage structures. P.S. I’ve just remembered that the advice not to foam wrap receivers seemed to stem from some reports of Futaba receivers overheating in the early days of 2.4 GHz where the models were being left in direct sun in 100+ degree temperatures in the southern USA. Quote Link to comment Share on other sites More sharing options...
