john stones 1 - Moderator Posted May 13, 2023 Share Posted May 13, 2023 Top job Peter. 👍 Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted May 13, 2023 Share Posted May 13, 2023 Cracking, look forward to seeing it at the Sherlow aerotow. Quote Link to comment Share on other sites More sharing options...
Trevor Posted May 14, 2023 Share Posted May 14, 2023 Well done Peter! Wishing you many more happy flights with the Petrel. Trevor Quote Link to comment Share on other sites More sharing options...
MikeQ Posted May 19, 2023 Share Posted May 19, 2023 Well done Peter. Looks fantastic. Hope the ribs etc are all sorted and you get out to fly it. Cheers. Mike ps. I’ll probably be starting mine soonish and will take all your tips on board 😀 Quote Link to comment Share on other sites More sharing options...
Chris Williams Posted May 19, 2023 Share Posted May 19, 2023 Good job, Peter, trouble is...you now have an empty workbench! 1 1 Quote Link to comment Share on other sites More sharing options...
Peter Garsden Posted May 21, 2023 Author Share Posted May 21, 2023 Well I have just returned from a more or less windless PSS weekend at the Orme. I took the Petrel because I wanted to try it out in light winds, which we had in abundance - no good for PSS heavies but OK for the Petrel. I arrived on Friday evening to Sun and about 8 to 10mph on the NW slope. I quickly assemble and Stevie chucked her off. She soared effortlessly as though on rails. She does dive a bit so I think I will remove 2 chunks of lead from the cockpit I flew her for about an hour, so delightful was the experience. The wind dropped to about 6mph and she seemed to cope with it easily rising even in that wind. I also flew her the following morning on the North East Pier slope which was equally rewarding and idyllic. This one will be flown a lot. I must go, however to find some accomodation for the Shrelow Aerotow next weekend. 5 Quote Link to comment Share on other sites More sharing options...
John Minchell Posted May 26, 2023 Share Posted May 26, 2023 Peter, here is one option for B&B right next to the Sherlowe airfield ready for the next one in August. https://www.ercallmill.co.uk/ Regards John M Quote Link to comment Share on other sites More sharing options...
MikeQ Posted May 28, 2023 Share Posted May 28, 2023 Hi Peter ... what two sizes of piano wire did you use on the AMT? Cheers mike Quote Link to comment Share on other sites More sharing options...
Peter Garsden Posted August 26, 2023 Author Share Posted August 26, 2023 On 28/05/2023 at 22:46, MikeQ said: Hi Peter ... what two sizes of piano wire did you use on the AMT? Cheers mike Sorry Mike, didn't see this. In answer to your question I went to my local engineering shop and bought some concentric sizes of tubing that all fit effectively inside each other. Unbeknown to me I bought mild steel, which I recently had to replace with piano wire and the sizes are 1/8" and 3/32, but you could use the metric equivalent of say 3mm and 2.5mm or 2mm I am sure. Quote Link to comment Share on other sites More sharing options...
Graham Donaldson Posted May 7, 2024 Share Posted May 7, 2024 Has anyone put a motor into the Petrel? Am thinking of doing this and some guidance would be great.8 Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted May 8, 2024 Share Posted May 8, 2024 Nice job, I don't know what your multiplex tow hook is like, but I had something like it, and it needed a 3+kilo servo for a safe release. Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted May 8, 2024 Share Posted May 8, 2024 1 hour ago, Paul De Tourtoulon said: Nice job, I don't know what your multiplex tow hook is like, but I had something like it, and it needed a 3+kilo servo for a safe release. This is the MPX One, very simple and as it only needs a very short movement you use the innermost hole in the servo arm to get max pull from standard 3+kg-cm servo Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted May 8, 2024 Share Posted May 8, 2024 1 hour ago, Frank Skilbeck said: This is the MPX One, very simple and as it only needs a very short movement you use the innermost hole in the servo arm to get max pull from standard 3+kg-cm servo Mine failed to release on a 4.5k 3m75 Asw 19 and a 2.5 metal geared servo, on the inner hole and 135°/135° servo throws, good luck with yours. Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted May 8, 2024 Share Posted May 8, 2024 8 hours ago, Paul De Tourtoulon said: Mine failed to release on a 4.5k 3m75 Asw 19 and a 2.5 metal geared servo, on the inner hole and 135°/135° servo throws, good luck with yours. Used a few of them on 1/4 scale gliders inc Pat Teakle HP18 plus a few 1/5 and 1/4 scale woodies. I do use a 3300 mah 5 cell battery though. Quote Link to comment Share on other sites More sharing options...
