propstar Posted August 17, 2022 Share Posted August 17, 2022 Hi every one,I have a Dx7 which has been working fine until the battery ran out (Tx accidentaly left switched on) the battery is now refusing to charge. Purchased a new battery but my tranny will not show any display in the window when turned on, however the bind test/range check button on the back is flashing green. Quote Link to comment Share on other sites More sharing options...
Flying Squirrel Posted August 17, 2022 Share Posted August 17, 2022 Not my personal experience but just read this on another forum from someone with the same issue Quote "If you remove the battery with the main switch in the on position the TX loses its flash memory and has to be re-set by Horizon" Quote Link to comment Share on other sites More sharing options...
kc Posted August 17, 2022 Share Posted August 17, 2022 Welcome to the forum Propstar, there is probably someone on the forum who knows whether there is some way to reset this yourself. Quote Link to comment Share on other sites More sharing options...
propstar Posted August 17, 2022 Author Share Posted August 17, 2022 many thanks guys, i certainly hope so Quote Link to comment Share on other sites More sharing options...
Kevin Fairgrieve Posted August 17, 2022 Share Posted August 17, 2022 (edited) I had to replace a fuse in mine, many years ago. It is the "original" DX7 we are talking about. If so that could be the reason. Youtube Video. Edited August 17, 2022 by Kevin Fairgrieve Quote Link to comment Share on other sites More sharing options...
propstar Posted August 17, 2022 Author Share Posted August 17, 2022 yes Kevin, the original DX7, where would i find the fuse? the old girl has done good up to now. Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted August 18, 2022 Share Posted August 18, 2022 Watch the video. Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted August 18, 2022 Share Posted August 18, 2022 BTW in Kevin's post this is a link to the same video. I know the normal convention is for links to be highlighted with blue writing, why this forum uses the underline has always puzzled me. The old way was to use the link icon dialogue. I find the process easier and better to simple paste the copied address directly into the text editor, which is what I did above, then it's obvious it's a video link. Just trying to help with using the forum. Steve 1 Quote Link to comment Share on other sites More sharing options...
propstar Posted August 18, 2022 Author Share Posted August 18, 2022 Sorry, missed the underlined bit-must say i always look for blue. 1 Quote Link to comment Share on other sites More sharing options...
propstar Posted August 18, 2022 Author Share Posted August 18, 2022 The fuse is GOOD-Looks like a reset,!!!!!!!!!!!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
Kevin Fairgrieve Posted August 18, 2022 Share Posted August 18, 2022 Use this at your peril!!!! Reset and service mode!! https://www.rcgroups.com/forums/showthread.php?609802-Accessing-the-DX7-or-XP7202-Service-Menu Quote Link to comment Share on other sites More sharing options...
Alan Gorham_ Posted August 18, 2022 Share Posted August 18, 2022 I'd love to know how the OP would be able to follow those instructions bearing in mind he can't read the LCD display on his transmitter... Quote Link to comment Share on other sites More sharing options...
Kevin Fairgrieve Posted August 18, 2022 Share Posted August 18, 2022 24 minutes ago, Alan Gorham_ said: I'd love to know how the OP would be able to follow those instructions bearing in mind he can't read the LCD display on his transmitter... Hmmm good point. Maybe ignore my advise as I clearly know diddly.🤣 Quote Link to comment Share on other sites More sharing options...
kc Posted August 18, 2022 Share Posted August 18, 2022 Well maybe the screen would light up during the first step .......... worth a try if the Tx is useless otherwise? If it doesnt work then one would have to send it back to Horizon or scrap it! Quote Link to comment Share on other sites More sharing options...
Chris Walby Posted August 18, 2022 Share Posted August 18, 2022 If in doubt give John Norris a call at Logic RC a phone call, free advice or return it to Logic RC (him) as the Spektrum UK service agent. No connection, but a happy customer over the last few years (mostly when I break things). Quote Link to comment Share on other sites More sharing options...
propstar Posted August 19, 2022 Author Share Posted August 19, 2022 have spoken to John Norris and the problem is terminal as the parts are no longer gettable. so I'll call it a day and many thanks for all of the help. 1 Quote Link to comment Share on other sites More sharing options...
RottenRow Posted August 19, 2022 Share Posted August 19, 2022 Just a thought…. on some industrial equipment that I repair, a dead internal battery causes the LCD display contrast to go to minumum, giving a blank screen. Usually I can just make out the display by viewing in a dark room, or by viewing from a certain angle. Perhaps your tx will be similar. If you have, or can download, a copy of the user manual, it will probably describe how to adjust the display contrast. You may have to count a number of button presses if you can’t make out the display at all. Worth trying before you give up on it. Brian. Quote Link to comment Share on other sites More sharing options...
Phil Green Posted August 19, 2022 Share Posted August 19, 2022 Mike Ridley? https://modelradioworkshop.co.uk/ Quote Link to comment Share on other sites More sharing options...
Dale Bradly Posted August 20, 2022 Share Posted August 20, 2022 I had a DX7 which had the voltage reg fail. Easily swapped for an aftermarket one (like this http://www.dimensionengineering.com/appnotes/spektrum_mod/) and bought it back to life. Worth seeing if this is your issue, and assuming you have access to appropriate soldering skill, an easy job. 1 Quote Link to comment Share on other sites More sharing options...
