Edgeflyer Posted September 6, 2022 Share Posted September 6, 2022 Does anyone know where a replacement shaft for the EFlite 15 size motor can be bought? It appears to be very slightly bent so that the rotation is impaired. Quote Link to comment Share on other sites More sharing options...
Simon Chaddock Posted September 6, 2022 Share Posted September 6, 2022 Phil B This looks like the shaft you want although it is on "special order" so you might have to wait a bit. Google is a wonderful tool. 😉 Quote Link to comment Share on other sites More sharing options...
John Lee Posted September 7, 2022 Share Posted September 7, 2022 Shafts are fairly generic, I'd suggest that you measure the length of existing one (I believe it's 5mm diameter) & search for similar size one. EG: https://www.rapidrcmodels.com/spare-motor-shafts-42-c.asp https://www.robotbirds.co.uk/motors/motors/motor-shafts.html Quote Link to comment Share on other sites More sharing options...
Chris Walby Posted September 7, 2022 Share Posted September 7, 2022 Best advice from SC and JL, but if you don't need a circlip groove you could try 4max (normally in stock) Quote Link to comment Share on other sites More sharing options...
Andy Stephenson Posted September 7, 2022 Share Posted September 7, 2022 I made a circlip groove in a 3mm shaft by using a cutting disc in a Dremel tool and with the shaft in a drill to rotate it. it's not particularly neat but it did the job. Quote Link to comment Share on other sites More sharing options...
Kim Taylor Posted September 7, 2022 Share Posted September 7, 2022 I made a replacement for mine using silver steel bought from Modelfixings, cut a few mil over length and used a wheel collet rather than attempt to cut a circlip groove. Kim Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted September 8, 2022 Share Posted September 8, 2022 If you have any club mates wigh a mini mill they will be able to cut neat flats on a replacement shaft very easily. Failing that som careful use of a Dremel will do the job. Quote Link to comment Share on other sites More sharing options...
