EarlyBird Posted November 22, 2023 Author Share Posted November 22, 2023 Moving to the front. Tank tray made and fitted. Checking how to fit the undercarriage. Steve Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted November 22, 2023 Share Posted November 22, 2023 I do hate aluminium undercarriages. They have no backward "give" and so can simply rip off. Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted November 24, 2023 Author Share Posted November 24, 2023 Top view bottom view Now there are options for the undercarriage that the owner can make a decision on.☺️ Steve Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted November 24, 2023 Author Share Posted November 24, 2023 One engine being test fitted. It fits and the petrol CDI has plenty of cable length to give options for it's location and loads of room for the batteries. Amazing what makes us happy. ☺️ Steve 2 Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted February 2, 2024 Author Share Posted February 2, 2024 I have been working on the tail and here it is. All dry fit, of course. Now back to the front. Unless I fit the wing servo trays.🤔 Steve Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted March 5, 2024 Author Share Posted March 5, 2024 Tail wheel fitted and rudder fitted. Next, I will finish the wings. Steve Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted March 10, 2024 Author Share Posted March 10, 2024 Ailerons liberated and one servo box installed. Aileron hinged also. 2 Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted March 13, 2024 Author Share Posted March 13, 2024 Repeated on the other side. Next servo wire extensions which require holes to be cut in the central bottom balsa sheet. I have previously drawn around a washer and cut out with a sharp knife, but this time I made an aluminium cutter from an old handle and used the drill and file to sharpen it. Bright idea was to leave it in the drill and test on a pice of scrap. Looks good to me and also works on the bench. Then on the first hole, disaster. Learning not to press down on the drill the secon hole looks good. Resisting the temptation to scrap the wing and start again, I teased the damaged balsa up and glued it into place. Good result for a first try. The reason for my change of method is that on the Mighty Barnstormer I have to cut all of the holes in the wing ribs, fortunately they will be cut on the bench. Next is to make up the extension leads. Steve 1 Quote Link to comment Share on other sites More sharing options...
GrumpyGnome Posted March 13, 2024 Share Posted March 13, 2024 You could try filing some teeth into your hole cutter...... 1 Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted March 14, 2024 Author Share Posted March 14, 2024 Thanks GG, By adding four slots it does seem to work better, more experiments on the way.🙂 Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted March 15, 2024 Author Share Posted March 15, 2024 I intended to use servo extension leads but The holes aren't big enough. So, I have to make up the extension in-situ. First thread the wire through, a bit of fishing with the aid of a thin wire. Then solder and heat shrink the joints, at this point brain fog took over and I forgot to take pictures. Next fit maxlock connector and take pictures. Steve Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted March 15, 2024 Share Posted March 15, 2024 I always make up paper tubes and fit them. It makes installing things so much easier and also later servicing and repairing things. It is better engineering if you like. Quote Link to comment Share on other sites More sharing options...
John Rickett 102 Posted March 15, 2024 Share Posted March 15, 2024 Steve, its easy to detach a shroud from a plug. There is a small plastic tab holding the shroud onto the plug, a flat blade screwdriver inserted at the back will lift the shroud from the plug. The tab is only on one side which will be at the top if you lay the cable as in the picture. It will snap back on afterwards. Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted March 16, 2024 Author Share Posted March 16, 2024 Thanks, John, for the excellent tip that works a treat. I could now combine this tip with Peter's paper tube method.👍 Yesterday I managed to take a picture. and not a lot more. Steve Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted March 16, 2024 Author Share Posted March 16, 2024 Made up the MaxLoc connector. What's next I wonder. Steve Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted March 17, 2024 Author Share Posted March 17, 2024 Working on the servo covers. I am thinking of fixing them in place with the film covering as I have never had to replace a wing servo. Is this a good idea? Steve Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted March 17, 2024 Share Posted March 17, 2024 Fix with countersunk screws, then film over ? 1 Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted March 18, 2024 Share Posted March 18, 2024 17 hours ago, EarlyBird said: I have never had to replace a wing servo. Oh dear, now you know what’s going to happen don’t you? 🥴 1 Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted March 18, 2024 Share Posted March 18, 2024 39 minutes ago, Ron Gray said: Oh dear, now you know what’s going to happen don’t you? 🥴 I was thinking....If you can't get at something you will need to. 1 Quote Link to comment Share on other sites More sharing options...
