The Big Question ?
RICHARD WILLS
Graham . I will start weathering the FW190 this week and document how to do it without having any special tools or skills . The point of this pair is to try and break down barriers for those that fancy stepping over from ARTF world . Our existing gang really needs this to protect our future .
To that end I want to keep the thread simple and the build fast and cheap .
Ive designed and built the 190 in about two months from a standing start and already have most of the Tempest on paper . Equally I have an obligation to make both models as good as I can to be respectful to our lads . So if the Tempest doesnt get under the Christmas tree but arrives in January , it will be for a good reason .
Both models will take retracts for sure . But I want them to be retrofitted as far as the thread is concerned . It will not be difficult and for those that want to , I will provide all the tricky bits but make it simple .
However , and this is important . When we all started getting into warbirds , we all had fixed undercarriage or no undercarriage . That meant that the effort of build , balancing and making fly , were all we had to deal with as a first proper scale model .
Our prospective newbies may already have a warbird with flaps , retracts , panel lines and a cuddly toy and feel that they have to cover the same hurdles in the first attempt .
No wonder they find it daunting .
Equally the fitting of IC engines will muddy the water . It can be done , of course , but both subjects previously had horrible long , non scale noses to make them balance .
These two , by mounting the battery pack vertical , can comfortably be built with scale noses .
I'm glad you asked the questions , because it is significant . In some ways these models are large , entry level fun fighters . The advantage being, light wing loading so easier launch and landing plus more realistic flying speeds .
The other thing is , you can buy a TN Fw190 for £250 if you want a "full fat " version or an RBC Tempest for £199 .
Or you can buy a very slick build kit of one of the above and join the gang above .
Something for everyone I guess 😄
  • Like 4
Cheers for the response, i didn't mean for yourself to document/ produce an i/c version of either kit, as you say it's simple quick build  entry level warbird with no complications.
I would make the necessary alterations to fit engine/ retracts.
I really wanted to know if the airframe, firewall would take a i/c fit.
Wrt TN stuff- over priced, not exactly scalish looking enough for me, yes i'm picky, and as you know I like you kits, back up service,, etc 😉
No , I'm glad we could clarify Graham . Later on there will be a special plug in unit to convert to retracts for those that want to .
The IC conversion means making the nose longer which is not difficult , but will spoil the looks .
From my point of view , an IC option just makes designing a whole lot harder for the few who want to go down that route .
I like the long nose 190 , which is more suited to IC but most don't .
For those that really want to go IC , have a look back in the thread at my original 190 and Tempest . They were both stretched for IC .
Thats the compromise you have to make . Ballast is the other option .
Edited by RICHARD WILLS
Ive been tidying up the plan and musing on a new company strap line . I was simply going to put designed by Muppets .
But Chris came up with a better one a few pages back .
"Designed by Puppets , flown by Muppets "
I am a little concerned by the offence this might cause . I ran this by green Graham and he pointed out that both he and sweep are described on their Equity cards as performing puppets . Although he didnt agree with the category in general (and nor did his friends, Basil Brush and Lamb Chop ) , he had come to accept it over the years.
As far as the humans are concerned . I am honest enough to consider myself a grade one , top drawer muppet . How about you guys ?
A step too far ?
With Yuletide approaching, Mrs Lipo Man has once again asked if I am hoping for some sort of gift this year. Having reviewed the year in detail, I have concluded that I have been an extremely good boy indeed. Put me down for an FW190. Mrs Lipo Man will deal with the necessaries vis a vis payment in due course. I’ll need to choose a colourful scheme for visibility - think I’ll do the one attached.
  • Like 2
Right , now here comes the exciting bit . This is where we elevate the 190 way beyond its ARTF competition .
We have a "proper " skin , not crocodile skin , so we might as well make the most of it .
First thing to point out is that my surface finish is pretty rough . Reason is - you wont see it . (I dont do stuff unless its needed , ask my wife 😕
In my opinion the next section gives the biggest uplift for the least effort .
Apart from the silver and the black lines , all the rest could be removed if we cock it up . So you're not risking anything . If you're still not sure , start on the underside .
If you print off a three view of an Fw190 , you will notice some prominent lines on the tailplane . We don't have to get them dead right , so I just put the lines on with a thin black permanent felt pen . Also , without two much thought I added some little "C" shapes in pairs either side of the joint . You dont have to do them all . In fact skip a few now and then , it looks better . I got a white gel pen from WH Smiths , and lightly skimmed in some more panel lines . The white represents , light catching the edge of a panel or light shining on bare metal on a rivet . In general , it gives a three dimensional impression .
  • Like 2
The next step requires some black and white chalk and some low tack masking tape and a finger .
The way shadows and different shades appear on any vehicle is due to the angle of the panel and the airflow dragging muck over it .
So lets create some variation . Lets assume that the leading edge will get a strong clean blast of air , but the panel behind it , after the joint will suck muck down onto it .
To keep the edge clean , mask it . Then work some of the black chalk (or charcoal )  onto the green tape .
Next step , get a circular motion going with your finger to create a round black smudge .
Finally whip off the tape .
The same technique can be applied in white chalk on the dark painted areas .
The main thing is create variation , which importantly would not cross panel lines .
The elevators are fabric covered on a 190 . So to keep it simple I use the width of the green tape as my spacer . I then just work my way along with dark shade on one side of the dips between "ribs" (not really there ) , and light shade on the other side . That is how we see a ribbed wing . The sun will light up one side of the valley and the other will be in shadow .
After doing the white and black shading , I get a silver shaker pen and create a little blob on a piece of paper . You could also dry brush silver paint .
I dip my finger in and wipe from front to back (like the airflow ) on the leading edges . I also do wing tips and other wear areas .
  • Like 2
Now lets make a comparison between the previously considered "finished" tail plane and the weathered one.
Keep in mind that it took way longer to write this up than do it .
If I was left alone to do it , that would be 30mins work .
Feel free to ask questions if I didnt explain it . Maybe I should run a course like Rick Stein ?
  • Like 2
