White plastic like squeeze bottle
Edgeflyer
  • 4 weeks later...
How about a piece of a PET fizzy drink bottle?  If you abrade the face which will be against the model until it is opaque, then clean it with isopropyl alcohol or meths, it should stick with something like Foam 2 Foam adhesive.  If you want double curature, use a piece from near the top of the bottle.
Failing that, plastic toothpaste tube material appears to be very tough and flexible.
