Terence Lynock Posted August 30, 2014 Share Posted August 30, 2014 Got all the 'paperwork' done for the Ta152 but have had a load of bits arrive at long last to convert all my airbrushes over to 1/8th BSP with quick release fittings on the hoses so I can change brushes in seconds rather than unscrewing things and particularly with a couple of them changing hoses as they have 5mm fittings. Why some airbrush manufacturers persist with 5mm and other fits when it would be so easy for them to standardise on 1/8 BSP I dont know, 1/8 BSP means a larger bore hose and delivers more air faster than those small bore 5mm things and your compressor doesnt have to work so hard either. The air receiver is about 4 litres and made from an old Co2 fire extinguisher bottle so good thick steel, I tapped and fitted three 1/8th BSP male/male fittings on the side with the input where the outlet used to be at one end of the bottle, the centre fitting has a 3 way adaptor so plenty of outputs,saves having to stop to clean brushes when you want to change colour. The hoses can be left connected to the bottle as the quick release fittings on the other end have a screw valve to stop the air flow when the brush is disconnected which again is a great help and time saver. Quote Link to comment Share on other sites More sharing options...
Terence Lynock Posted September 4, 2014 Share Posted September 4, 2014 Two mates are sitting by the canal fishing when a funeral courtage' passes over a bridge, one of the blokes stands up,removes his cap and bows his head, after the cars have passed he replaces his cap,sits down and carries on fishing. His mate says'you know Fred that is the most respectful thing I have ever seen you do' and Fred just says 'well its only right really, we were married for 35 years...........' Quote Link to comment Share on other sites More sharing options...
GrahamWh Posted September 4, 2014 Share Posted September 4, 2014 Very good. How about this one.. A duck goes into a bar and up to the barman. "Have you got any ham sandwiches?" he askes. "No we don't do them" is the reply and the duck leaves. The next day, at lunch time, the duck returns and says to the barman "I'd like a ham sandwich please." "I told you, we don't have ham sandwiches, get out." the barman replies, so the duck leaves. The following lunchtime, duck is hungry and goes back to the pub. He waddles up to the bar, gets the barman's attention and asks "Have you got any sandwiches - I'd like a ham one?" The barman retorts angrily "I've told you we don't do them. If you ask for ham sandwiches again I'm going to get a hammer and nail your webbed feet to the floor." The duck is a little disconcerted and leaves the establishment. The next day duck is passing again, and it being lunchtime is somewhat hungry, so he goes into the pub and up to the bar. He askes the barman "have you got any nails?" The barman is puzzled and replies "No, I haven't" "Well can I have a ham sandwich please?" Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted September 4, 2014 Share Posted September 4, 2014 Quack John Quote Link to comment Share on other sites More sharing options...
cymaz Posted September 5, 2014 Share Posted September 5, 2014 A piece of string enters a pub. Strolls up to the barman and orders a whiskey. Soon after another rpiece of string enters, goes to the bar and asks the barman for a double whiskey. An hour later a third piece of string walks in and ,again ,orders a whiskey. Two hours pass by a fourth piece of string walks in and goes up to the bar. The barman says," I suppose you want a whiskey as well?" The string replies, "Er, no, I'm afraid not!" Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted September 20, 2014 Share Posted September 20, 2014 this is how to check your prop blades etc--- we were out for a walk the other evening and came across these two lads......look close at the blade-bet he isn't on the minimum wage? ... some idea of the height can be gained from looking at the van parked at the base....no nerve's..... ken Anderson...ne...1.....spot the man dept. Edited By ken anderson. on 20/09/2014 18:40:14 Quote Link to comment Share on other sites More sharing options...
John Privett Posted September 20, 2014 Share Posted September 20, 2014 The harbour at Blyth, unless I'm mistaken? Didn't somebody tell me those wind turbines were being scrapped? Or is that a new one? Quote Link to comment Share on other sites More sharing options...
brfc7 Posted September 21, 2014 Share Posted September 21, 2014 Posted by John Privett on 20/09/2014 21:35:13: The harbour at Blyth, unless I'm mistaken? Didn't somebody tell me those wind turbines were being scrapped? Or is that a new one? Yes Blyth harbour. Their were originally 9 smaller turbines along the outer pier that have now been took off over a year ago and supposedly they were to be replaced with 7 new ones the same size as the one in the picture above but so far nothing????????????? baz Quote Link to comment Share on other sites More sharing options...
Josip Vrandecic -Mes Posted September 21, 2014 Share Posted September 21, 2014 Good day Ken, : '' this is how to check your prop blades etc--- we were out for a walk the other evening and came across these two lads......look close at the blade-bet he isn't on the minimum wage? ... some idea of the height can be gained from looking at the van parked at the base....no nerve's.....'' Jo : I wonder which kind of prop balancers used by installers ?? .... Cheers Jo Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted September 21, 2014 Share Posted September 21, 2014 clever stuff-this one is supposed to generate more electric than the 9 that were along the pier...when it was first installed/running the nearby residents were complaining about the noise from the blade's.... modern time's .... ken Anderson...ne...1...... eco dept. Quote Link to comment Share on other sites More sharing options...
brfc7 Posted September 21, 2014 Share Posted September 21, 2014 Not sure if it's been put on here before but here's a nice short 7 minute video from Guy Martin talking about his Merlin engine that came out of a Lancaster. http://www.channel4.com/programmes/guy-martins-passion-for-life/on-demand/59514-002 baz Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted September 22, 2014 Share Posted September 22, 2014 going along with the new changes that are been made to the car tax disc........check out this---to see if a car is taxed etc...you can find out if you old car is now a paper weight(no longer roadworthy) .. ken Anderson ne..1 ...... tin box dept. Quote Link to comment Share on other sites More sharing options...
Craig Carr Posted September 22, 2014 Share Posted September 22, 2014 Posted by ken anderson. on 22/09/2014 09:33:43: going along with the new changes that are been made to the car tax disc........check out this---to see if a car is taxed etc...you can find out if you old car is now a paper weight(no longer roadworthy) .. ken Anderson ne..1 ...... tin box dept. Didn't spot it at first Ken (down the bottom) Here is a more direct link Edited By Craig Carr on 22/09/2014 18:21:12 Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted October 4, 2014 Share Posted October 4, 2014 some foam for the next project...still need some for the wing's..... ken Anderson...ne...1 large model dept........ Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted October 4, 2014 Share Posted October 4, 2014 and bargain fuel at the Nat's.....buy one and get one free etc... ken Anderson...ne...1 bargain dept. Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted November 6, 2014 Share Posted November 6, 2014 the jungle telegraph is singing like a goodin in our area-NE-1 land- saying that J Carr's.......fellow forumite has won a power panel in the latest draw....... talk about the devil looking after his own etc..... .... well done JC from me..... ken Anderson ...ne....1 comp winner's dept. Quote Link to comment Share on other sites More sharing options...
Jimbo565 Posted November 6, 2014 Share Posted November 6, 2014 Cheers Kendo Thanks to RCM&E JC ne23 ----- well chuffed dept. Quote Link to comment Share on other sites More sharing options...
Mowerman Posted November 6, 2014 Share Posted November 6, 2014 Hi This Sunday Nov 9th is the 100th anniversary of the birth of Hedi Lamarr, the inventor of Spread Spectrum Technology. I think we should all raise a glass in her memory or If you are not aware of the facts about her try 'google' Quote Link to comment Share on other sites More sharing options...
i12fly Posted November 7, 2014 Share Posted November 7, 2014 Has anybody else noticed a lack of flying insects this autumn? Here in mid Derbyshire it was rare to get a moth or daddy long legs on the window of a late evening. No wasps, few mozzies. Similar (I guess related to the lack of insects) no swallows. 4 years ago there were lots squealing and reeling about, last year only about half a dozen and this year there were 2 in late spring but after a few weeks disappeared. Quote Link to comment Share on other sites More sharing options...
John Privett Posted November 7, 2014 Share Posted November 7, 2014 Very few wasps this year here in Surrey, but I'd say we've had the usual number of spiders and daddy-long-legs - possibly more than usual of those. Not sure about swallows, as I don't think I've ever really noticed many of them, but we seem to have an awful lot of (noisy) crows these days. Quote Link to comment Share on other sites More sharing options...
Phil Claridge Posted November 7, 2014 Share Posted November 7, 2014 almost no wasps or flies down here in boggy regis this year. we have got a butterfly keep apppearing around the eaves of our second floor flat, it was about again this morning. this happens every year so i dont think it can be the same one very odd, the wind is gusting quite hard so he must be having a hard time getting about Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted November 17, 2014 Share Posted November 17, 2014 that time of the year warning...the bin men have started to say good morning etc..... .. ken Anderson...ne...1 bin watch dept. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted November 17, 2014 Share Posted November 17, 2014 Evening Ken John Quote Link to comment Share on other sites More sharing options...
Josip Vrandecic -Mes Posted December 6, 2014 Share Posted December 6, 2014 Hi All ,want to share this **LINK** with you.... Enjoy. Quote Link to comment Share on other sites More sharing options...
kevin b Posted December 6, 2014 Share Posted December 6, 2014 Very nice Josip. I can enjoy a good waltz as well as Def Leppard !!! What i want to know, is who did he eat afterwards ? Quote Link to comment Share on other sites More sharing options...
