Martin McIntosh Posted April 28, 2017 Share Posted April 28, 2017 Wow. That looks something else. Quote Link to comment Share on other sites More sharing options...
ChrisB Posted April 28, 2017 Share Posted April 28, 2017 OOh, thats a lovely Stearman! Superb detail and I like the colour scheme! What weight did it come out at? Quote Link to comment Share on other sites More sharing options...
Kevin Wesley Posted April 28, 2017 Share Posted April 28, 2017 Quote Link to comment Share on other sites More sharing options...
Kevin Wesley Posted April 28, 2017 Share Posted April 28, 2017 Thank you for all your kind comments, here's some detailed pictures. The model hasn't been weighed as yet because i have to check the CofG. but it'll definitely be over 20kg. It's colour scheme is based on a real example registered in the states. The model has the nose shortened to true scale length (the kit is lengthened) It has four ailerons, and up-rated rigging points, undercarriage and tailwheel. Fully rib taped and scale spaced rib stitching. But it'll never be finished, you can always find more details to add! Edited By Kevin Wesley on 28/04/2017 23:03:20 Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted April 29, 2017 Share Posted April 29, 2017 That level and perfection of detal looks World Championship class Quote Link to comment Share on other sites More sharing options...
cymaz Posted April 29, 2017 Share Posted April 29, 2017 If it's over 20kg I will look at the LMA web site to see if it's registered and for more info. Quote Link to comment Share on other sites More sharing options...
Devcon1 Posted April 29, 2017 Share Posted April 29, 2017 Apart from the pic with the pilot, which is great by the way, I would not have guessed this was a model. The level of detail and "real feel" is astonishing. It's just got full size written all over it from the finish to the fire extinguisher. Marvelous craftsmanship... One of the best I've ever seen. Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted April 29, 2017 Share Posted April 29, 2017 hello Kevin...a lovely model ...worth a page or two in the mag...and deffo a comp winner ...well done from me and thanks for sharing... ken Anderson...ne...1 admiration dept. Quote Link to comment Share on other sites More sharing options...
ChrisB Posted April 29, 2017 Share Posted April 29, 2017 Posted by cymaz on 29/04/2017 08:41:33: If it's over 20kg I will look at the LMA web site to see if it's registered and for more info. I reckon it'll be about 45-50lbs, probably more like 50lbs. There nothing to say that Kevin hasn't registered the model with the LMA and had it inspected throughout its construction. Its not something that's been done overnight that's for sure. I'm led to believe that a model that ends up being over 20kg and hasn't been registered can be inspected retrospectively but it may required some invasive surgery to inspect the critical areas. Quote Link to comment Share on other sites More sharing options...
Kevin Wesley Posted April 29, 2017 Share Posted April 29, 2017 Hi, Its not the first large scale model i have built. Its registered with the LMA of which i have been a long term member thanks. chrisB i expect you are about spot on with the weight Once again thank you for all your nice comments. Its so rewarding when other model buider's appreciate the work involved Edited By Kevin Wesley on 29/04/2017 19:01:38 Quote Link to comment Share on other sites More sharing options...
ChrisB Posted April 29, 2017 Share Posted April 29, 2017 Hi Kevin, did you fancy putting a Moki 15o up front? Quote Link to comment Share on other sites More sharing options...
Flyer Posted April 29, 2017 Share Posted April 29, 2017 Finally,,,,,,, my A4 maidened this evening. Not ideal conditions, but four clicks of right and slightly forward c of g. She's a rapid ship, but seemed quite stable , even in marginal conditions. Landed out, due to flying through the available lift has resulted in a broken probe and snapped wingbolt. Apart from that, I'm happy. I did amend the mass build plan to produce the two seater, and it has worked. I've learnt so much on this journey, that I will strive to improve my next one! Quote Link to comment Share on other sites More sharing options...
trevor wood 2 Posted April 29, 2017 Share Posted April 29, 2017 42" span Antoinette weighs 7 ounces. Rudder, elevator and wing warping. Powered by small GWS geared brushed motor. Max flying speed 4 mph. Quote Link to comment Share on other sites More sharing options...
Geoff S Posted April 29, 2017 Share Posted April 29, 2017 7 ounces is really light for a 42" ws model which probably why it flies at 4mph Looks lovely but I suspect your flying was about to be interrupted by a red ball travelling at rather more than 4mph! Geoff Quote Link to comment Share on other sites More sharing options...
trevor wood 2 Posted April 29, 2017 Share Posted April 29, 2017 Well spotted Geoff. There's a group of us who have joined the local cricket club as non-playing members. This allows access to a perfectly manicured flying field and the club house every day of the week. We can even fly on weekends during the cricket season, as matches never start before 1.00pm. Quote Link to comment Share on other sites More sharing options...
Geoff S Posted April 29, 2017 Share Posted April 29, 2017 There's a model club near me that also flies from local cricket club so perhaps it's more common than I thought. Geoff Quote Link to comment Share on other sites More sharing options...
Jonathan M Posted April 30, 2017 Share Posted April 30, 2017 Trevor, that looks really lovely! But if a model ever really needed a pilot figure to finish it, it has to be the Antoinette! Quote Link to comment Share on other sites More sharing options...
Kevin Wesley Posted April 30, 2017 Share Posted April 30, 2017 Posted by ChrisB on 29/04/2017 21:30:55: Hi Kevin, did you fancy putting a Moki 15o up front? Hi chrisB, Yeah it would have been great to, but unfortunately funds wouldn't quite stretch to one Quote Link to comment Share on other sites More sharing options...
Kevin Wesley Posted April 30, 2017 Share Posted April 30, 2017 Posted by trevor wood 2 on 29/04/2017 22:10:35: 42" span Antoinette weighs 7 ounces. Rudder, elevator and wing warping. Powered by small GWS geared brushed motor. Max flying speed 4 mph. Quote Link to comment Share on other sites More sharing options...
Kevin Wesley Posted April 30, 2017 Share Posted April 30, 2017 Absolutely beautiful Trevor ! ! Quote Link to comment Share on other sites More sharing options...
ChrisB Posted April 30, 2017 Share Posted April 30, 2017 Posted by Kevin Wesley on 30/04/2017 11:27:24: Posted by ChrisB on 29/04/2017 21:30:55: Hi Kevin, did you fancy putting a Moki 15o up front? Hi chrisB, Yeah it would have been great to, but unfortunately funds wouldn't quite stretch to one I suspected that could be the case. I know Richard Rawle and Steve Holland began using MOKI radials but soon changed to twins because the power was better than the moki and the performance was better. Cheers Quote Link to comment Share on other sites More sharing options...
Kevin Wesley Posted April 30, 2017 Share Posted April 30, 2017 Posted by ChrisB on 30/04/2017 13:47:43: Posted by Kevin Wesley on 30/04/2017 11:27:24: Posted by ChrisB on 29/04/2017 21:30:55: Hi Kevin, did you fancy putting a Moki 15o up front? Hi chrisB, Yeah it would have been great to, but unfortunately funds wouldn't quite stretch to one I suspected that could be the case. I know Richard Rawle and Steve Holland began using MOKI radials but soon changed to twins because the power was better than the moki and the performance was better. Cheers Yeah i believe they also had some reliability issues and dead stick landings. These big bipes don't glide well ! Quote Link to comment Share on other sites More sharing options...
