PatMc Posted July 19, 2014 Share Posted July 19, 2014 Mine still has both timers on the opening screen. Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted July 19, 2014 Share Posted July 19, 2014 What version are you using PatMc? I can only see timers like this Quote Link to comment Share on other sites More sharing options...
PatMc Posted July 19, 2014 Share Posted July 19, 2014 I'm on version 2.07. That's pretty much the same opening page I get except I have 2 timers active & still use the FrSky logo. Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted July 19, 2014 Share Posted July 19, 2014 OK, I have timer 2 switched OFF, that's why only one shows. Quote Link to comment Share on other sites More sharing options...
Craig Kane Posted August 2, 2014 Share Posted August 2, 2014 I've just taken delivery of my Taranis and I'm very impressed with its quality. I wanted to get away from my DX6i after too many "unexplained" incidents with models losing settings, RF failures and just a lack of functionality. I'd considered going for the new Spektrum DX6 but the Taranis looked like it would do more than I would ever need and I'd be hard pushed to run out of channels so in the long run, a better investment. I've also bought an Orange DSM2/DSMX module so that I can still fly all my existing models whilst i gradually replace the rx's with FrSky. Has anyone found any problems using the modules? I'm having a bit of difficulty getting the settings to copy from Companion to the Tx. I spent some time setting up each model and went to write to the tx it came up with a BAD EEPROM message and reverted to factory settings. I looked this up and it would appear that it's an issue for Win7 users (?) I've updated the driver as suggested but now it won't seem to "see" the tx when connected. If anyone could shed some light? Quote Link to comment Share on other sites More sharing options...
Dave Bran Posted August 2, 2014 Share Posted August 2, 2014 Craig, you are really in the wrong place as a 23 page single "chat" thread is not the way to travel when there is a complete dedicated forum available, so suggest you go to the openrc forum and read a lot first The software operates perfectly on both WIn 7 and XP, I know as I use computers with both. Having said that, both were less than instant in getting them going. Its easier now than it was as the latest versions have helped the setup process. Sequence is basically/:- 1. Ensure you are on the latest version of OpenTX Companion. 2. Make sure its set for Taranis 3. Make sure you load the comparable firmware to the Tx (my guess is that this is wrong). THEN worry about file set transfers. Quote Link to comment Share on other sites More sharing options...
Dave Bran Posted August 2, 2014 Share Posted August 2, 2014 Oh, and on modules, again there's a lot of that on the opentx forum, but basically the main issues seem to be some modules where the pins do not align to the Tx sockets and need tweaking or the Tx board moving......... I had hellish trouble with a RipOffMax FASST module where there was NO instructions AT ALL available from them, and no knowledge of what was required, eventually I found some in Hobbico US's "deleted product" archive. Oh, and they were wondering why JR Tx owners needed so many FASST modules all of a sudden...................You could not make it up, could you!!! Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted August 2, 2014 Share Posted August 2, 2014 This is absolutely the right place to ask for help Craig, we're a friendly bunch here, always willing to help out. One of the harder things with Taranis seems to be getting it to talk to the PC. It's nearly always a USB driver issue. To this end, a little help utility is provided. Have a look here and download Zadig. That should help get you connected. For firmware updating, you should connect the Tx to PC with the Tx turned off and leave it turned off. For copying models to and from PC, there are two ways, and how you go about connecting depends on the firmware version you're on. I'd suggest updating the firmware to 2.0.8, then come back here to ask if you need to. Quote Link to comment Share on other sites More sharing options...
AJ Posted August 2, 2014 Share Posted August 2, 2014 Well my Taranis paid for itself today. I put a model down about 1km away, beyond a river and a line of trees well out of sight in rougth undergrowth. I was able to use the rssi telemetry signal to df onto the model. Using this I was able to get to within a few meters of it from where I could see the plane and recover it. No real damage but no where near where I thought it would be. Thank goodness I was using my Taranis. A. Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted August 2, 2014 Share Posted August 2, 2014 How obvious AJ, now you mention it. Yet another nice "extra" that Taranis has. Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted August 2, 2014 Share Posted August 2, 2014 wow! I never thought of using RSSI at a direction finding system! Excellent. BEB Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted August 2, 2014 Share Posted August 2, 2014 Have you replaced the nimh in tx fella's, if so what have you gone with ? John Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted August 2, 2014 Share Posted August 2, 2014 Hi John, mine originally came with an 800mAh NiMH. I just replaced that with a 2000mAh NiMH (but I think the current ones come like that anyway now). I've not looked using Lipo or the like. TBH the 2000mAh lasts for ages! BEB Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted August 2, 2014 Share Posted August 2, 2014 I've been using the 800mAh NiMh ever since I had the Tx in January and have found that that last a very long time. I've just aquired a 2000mAh NiMh because a clubmate double purchased. I'll stay with NiMh's because the internal charger is for NiMh's. I have carried a 800mAh 2S lipo in the past, just in case. The balance lead plugs in to Taranis and works fine, with a tweak of the battery alarm. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted August 2, 2014 Share Posted August 2, 2014 Cheers lads, I will stay with the nimh then. Mine has the 800mah in bought from BRC John Quote Link to comment Share on other sites More sharing options...
John Privett Posted August 3, 2014 Share Posted August 3, 2014 Mine had the 800mAh battery when I bought it. I got the Overlander 2000 mAh shortly after while buying a couple of sensors from T9. I'm sure the 800 would last well enough for me, but a review somewhere had pointed out how stiff the wires were on the original and although there would never be much movement of the wires I just felt they were possibly prone to fracturing. Quote Link to comment Share on other sites More sharing options...
Kevin Fairgrieve Posted August 3, 2014 Share Posted August 3, 2014 Mine came with the 2000mAh battery as it is the revision model with the smooth sliders etc. I will at some point change to a LiPo. I have one of these in my DX7 and have only charged it two or three times in about a year. It fits nicely in the Taranis, but will need small JR connector changing for a compatible one. Of course removing the battery from the TX for charging. Kev Edited By Kevin Fairgrieve on 03/08/2014 07:18:52 Quote Link to comment Share on other sites More sharing options...
Dave Bran Posted August 3, 2014 Share Posted August 3, 2014 Posted by Kevin Fairgrieve on 03/08/2014 07:17:59: Mine came with the 2000mAh battery as it is the revision model with the smooth sliders etc. That is not linked, mine was the better sliders, but small battery as supplied. I didn't have a problem with the small NIMH, but with increasing use planned decided to fit the 2000mAh NIMH and of course swap to the charge cct board for it. Works perfectly. NO WAY will I fit a LiPo into a Tx, its overkill and adds far too much risk on connections, etc, etc. Quote Link to comment Share on other sites More sharing options...
Craig Kane Posted August 3, 2014 Share Posted August 3, 2014 Posted by Chris Bott - Moderator on 02/08/2014 17:31:37: This is absolutely the right place to ask for help Craig, we're a friendly bunch here, always willing to help out. One of the harder things with Taranis seems to be getting it to talk to the PC. It's nearly always a USB driver issue. To this end, a little help utility is provided. Have a look here and download Zadig. That should help get you connected. For firmware updating, you should connect the Tx to PC with the Tx turned off and leave it turned off. For copying models to and from PC, there are two ways, and how you go about connecting depends on the firmware version you're on. I'd suggest updating the firmware to 2.0.8, then come back here to ask if you need to. Thanks Chris. I had a look through the other threads as suggested but thought I would ask a few genera queries on here. I'd already downloaded the Zadig file but I guess I haven't set something up correctly. I'll go back and check again. Quote Link to comment Share on other sites More sharing options...
David... Posted August 3, 2014 Share Posted August 3, 2014 Posted by AJ on 02/08/2014 17:31:41: Well my Taranis paid for itself today. I put a model down about 1km away, beyond a river and a line of trees well out of sight in rougth undergrowth. I was able to use the rssi telemetry signal to df onto the model. Using this I was able to get to within a few meters of it from where I could see the plane and recover it. No real damage but no where near where I thought it would be. Thank goodness I was using my Taranis. A. This is a brilliant piece of lateral thinking and yet another huge bonus for Taranis and its RSSI. This is what I would do: Hold the Tx in front of you with the antenna vertical and rotate yourself and determine where the minimum and maximum signal strengths are. At maximum signal strength the craft would be at right-angles to you, either left or right and the direction confirmed by the minimum. At this stage you cannot determine (but you can guess) the direction, especially if you saw it go down! Note the direction your facing. Now move yourself say 100M away from where you are and go either left or right, then repeat the direction finding exercise, you then have to determine where your new direction of maximum signal is relative to the first one and their point of intersection is where the model is. Repeat as you get closer for a better position fix. It's what's called the crooked hat approach to direction finding, it works... Try it at your local park to see how it operates. Of course if you have a GPS module fitted and it's got a signal from a clear view of the satellites (not upside down!) then you would go straight to that position. AJ - thanks for posting your discovery. I'd be interested to know if you found your model through trial and error or using the inherent directivity of the RSSI reception. Edited By David... on 03/08/2014 10:21:59 Quote Link to comment Share on other sites More sharing options...
John Privett Posted August 3, 2014 Share Posted August 3, 2014 Posted by Dave Bran on 03/08/2014 08:03:38: ...decided to fit the 2000mAh NIMH and of course swap to the charge cct board for it. Could you expand on that bit please, Dave. Did I miss something? Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted August 3, 2014 Share Posted August 3, 2014 John, I believe that early Taranii wouldn't fully charge a 2000mAh NiMh, or maybe it just took a long time. So the charge circuit was altered to suit both sizes of battery. I seem to remember, but can't find the info again, that if your charge LED flashes at the start of a charge, then you have the updated charge circuit. For those with an early one, a replacement is available. As for using a LiPo in a Tx DB, not only is the Taranis designed to take one, with the battery connector suiting a 2S LiPo balance plug, other modern transmitters come supplied with a LiPo too, I don't see the problem. Quote Link to comment Share on other sites More sharing options...
Former Member Posted August 3, 2014 Share Posted August 3, 2014 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted August 3, 2014 Share Posted August 3, 2014 From the Aloft Hobbies description of the 2000mAh battery:- Please note that early Taranis owners may need to run their charge cycle twice when first charging this battery, or when charging a deeply discharged pack. To do this, simply wait until the charge light turns off on your transmitter, then turn the Taranis on, and then off. The charge light should light back up and start charging again. Radios made from October 2013 on will not have this issue. Quote Link to comment Share on other sites More sharing options...
PatMc Posted August 3, 2014 Share Posted August 3, 2014 John, the 2000mAH charging module is listed here. If you don't have the "B" version Tx it's a good idea to upgrade to the new sliders at the same time. The new charging circuit will charge with a flashing green LED, and it goes steady when battery is fully charged. Chris, the disadvantage with Lipo & LiFe is that they can't be charged using the built in circuit. A fully charged 2000mAH NiMh lasted about 6 or 7 hours before bring up the LV alarm (set at 7.2v) when I tested mine recently. Quote Link to comment Share on other sites More sharing options...
