leccyflyer Posted July 16, 2021 Share Posted July 16, 2021 Ron - I like the look of those 3D printed servo mounts - do you have the stl online anywhere? Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted July 16, 2021 Share Posted July 16, 2021 I don’t but only because they are specific to the servo and model. Happy to send one to you though. 1 Quote Link to comment Share on other sites More sharing options...
leccyflyer Posted July 16, 2021 Share Posted July 16, 2021 Thanks Ron - when I eventually get to my Schnellbomber that would be super helpful. ? Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted July 16, 2021 Share Posted July 16, 2021 Or, if you’d prefer, let me know the servos you will be using and I’ll produce the stl for them. Quote Link to comment Share on other sites More sharing options...
leccyflyer Posted July 16, 2021 Share Posted July 16, 2021 Just as they are would be fine Ron - I could modify the file once I decide on the servos to use, it would be a good learning point for me, as I've only dabbled in design for 3D printing so far. Modifying files is a great starting point. Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted July 16, 2021 Share Posted July 16, 2021 Here you (and anyone else) go. Servo_mounting_and_top_plate_Corona339_56x56.stl 1 Quote Link to comment Share on other sites More sharing options...
Glynn Posted July 16, 2021 Share Posted July 16, 2021 Here is one for the MG90 servo's. Remember to mirror if using for ailerons.Servo Hatch MG90.stl 1 Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted July 21, 2021 Share Posted July 21, 2021 Slow progress, but progress none the less! Having decided that the tail servos can be mounted in the tail I then had to make sure that they were going to be accessible for maintenance etc. This meant mounting them in front of the rear bulkhead. And at this point all was well and ready to forge ahead with mounting the fixed rear gear. But then I had an idea, why not make it a retracting rear wheel, after all I've used lighter servos for the tail than I was going to use so I can afford the extra weight. Why oh why did I decide to do that? I knew that I had a small retract unit in my parts box but the leg was too long, so that had to be remade, cutting it to length wasn't a problem but trying to cut a circle groove, by hand, in a 2mm wire?? In the end I threaded the end of the wire and put a nyloc nut on it which then meant having to file out some of the insides of the retract unit to allow the nut to pass. Of course then I had to mount it so that it was the correct depth and didn't interfere with the servo pushrods which will go underneath (on top) of it and so that it would also be hidden by the fuselage covering, which also had to be made removable for maintenance etc. Oh boy, maybe I should have stuck to the fixed gear option. I cut the fuselage foam under deck to give me the 'access hatch' which is attached with a nylon thumbscrew threaded into a cyano hardened balsa block (sitting between the servos in the photo above) With the rear end sorted I could close up the underside of the fuselage Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted July 21, 2021 Share Posted July 21, 2021 And the retract in action 1 Quote Link to comment Share on other sites More sharing options...
Eric Robson Posted July 21, 2021 Share Posted July 21, 2021 Hi Ron, good progress, I like to keep it simple the tail wheel is not to prominent , mainly in side view if the plane is banked slightly the tail plane hides it. On my OD Seafury I used a 14 swg skid that is almost invisible in the air, but I fly off grass. Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted July 21, 2021 Share Posted July 21, 2021 Yes, I know Eric and that is exactly what the mind said, keep it simple like I did with the BF110, but then the heart kicked in and the mind was swept along in the ensuing enthusiasm! But I have drawn the line at doors, after all the mains haven't got them! Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted August 8, 2021 Share Posted August 8, 2021 Having covered the tail with lam film so that I could glue the tailplane and fin to the fuselage (in order to sand the various fillets etc) I thought that it was time to assemble it again to do another C of G check to make sure I haven't overdone it with the tail mounted servos and retract! Didn't need to worry as it balances exactly as the plan! 7 Quote Link to comment Share on other sites More sharing options...
Murat Kece 1 Posted August 8, 2021 Share Posted August 8, 2021 Looking really good Ron.. Engines are awesome..? Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted August 8, 2021 Share Posted August 8, 2021 Thanks Murat, fingers crossed that the engines perform! Quote Link to comment Share on other sites More sharing options...
RICHARD WILLS Posted August 16, 2021 Share Posted August 16, 2021 That will go like the clappers Ron . Hold on to your hat ! Quote Link to comment Share on other sites More sharing options...
Chris Walby Posted August 16, 2021 Share Posted August 16, 2021 Would be really interested in the electric and ic AUW's, as most of my models "of a reasonable size" are IC conversions to electric so I end up shifting everything forward and sometimes adding weight to get C of G hence it ends up the same weight. As this is a bit of reverse engineering I wonder what he impact will be? Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted August 16, 2021 Share Posted August 16, 2021 52 minutes ago, RICHARD WILLS said: That will go like the clappers Ron . Hold on to your hat ! Hoping so Richard but am really looking forward to the sound! Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted August 16, 2021 Share Posted August 16, 2021 39 minutes ago, Chris Walby said: Would be really interested in the electric and ic AUW's, as most of my models "of a reasonable size" are IC conversions to electric so I end up shifting everything forward and sometimes adding weight to get C of G hence it ends up the same weight. As this is a bit of reverse engineering I wonder what he impact will be? I’m getting towards the end of the build so should be in a position to weigh it all up fairly soon (by the end of the month). Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted August 20, 2021 Share Posted August 20, 2021 A couple of 'final' build bits completed so that covering of the main surfaces can commence. Underwing fairing constructed Triangular balsa wet and pre-bent to wing profile. Glued and pinned in place. Cowl fixing tabs epoxied in place and the whole of the nacelle section given an initial coat of thinned epoxy. Just final sanding to do before I start covering with lam film. 1 Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted August 29, 2021 Share Posted August 29, 2021 Covering all done so as it's Sunday, let's spray All the waggly bits And the hot bits 3 Quote Link to comment Share on other sites More sharing options...
martin collins 1 Posted September 17, 2021 Share Posted September 17, 2021 Not a Warbirds kit but well worth the watch, so much detail, a bit of inspiration for us with the JU88 kits, sorry to those of you that don`t do Facebook........... https://www.facebook.com/dean.coxon.568/videos/403737121167967 Quote Link to comment Share on other sites More sharing options...
martin collins 1 Posted September 17, 2021 Share Posted September 17, 2021 (edited) Video may be up elsewhere for those without facebook, if i find it i will post the link. Edited September 17, 2021 by martin collins 1 Quote Link to comment Share on other sites More sharing options...
RICHARD WILLS Posted September 17, 2021 Share Posted September 17, 2021 Nice video Martin , The 88s always look great in the air . Much more fighter like than expected . Ron , I am likeing the red cowls . What a racy number you are putting together ! Quote Link to comment Share on other sites More sharing options...
martin collins 1 Posted October 9, 2021 Share Posted October 9, 2021 Any more progress Ron, i am considering my JU88 kit as the winter build this year, it could be started within the next two weeks. Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted October 10, 2021 Share Posted October 10, 2021 Lost my mojo Martin, but I think it’s coming back so watch this space. Quote Link to comment Share on other sites More sharing options...
