Warbird Replicas Ju88 Night Fighter build
Ady Hayward
I personally - if WR or should that be RW ,were to produce another twin, would prefer a beaufighter for a pair of lazers, which would obviously have to be slightly larger size, but we've been down this road before on another forum.
Ron, following your thread with interest , being i/c. ?
Thanks @gillyg1. To get something bigger I think we would have to look elsewhere, Richard has a knack of producing this size ‘planes that not only build quickly and really look the part they also fly extremely well, changing his formula may well upset things. Personally I would dearly love a larger Mosquito that I could fit 2 Laser 200i with gearbox in as that would truly be something else. But if Richard was to bring out his version of a Mossie you, and everyone else, would have a hard job preventing me from being at the head of the queue to buy it!
As Richard has eluded to all along its about sufficient numbers of people wanting to build affordable well flying models. IMHO if you want a mossie then there is the SG one already available. If fails to meet Richards criteria both in electric or IC formats regarding set up cost, but looks ok and flies well with a pair of Laser 70's. My point is that it has already stolen a number of potential buyers and its numbers of kits Richard needs to make it worth while. Almost everything else is niche and doesn't get the numbers.
I would have to say if it was a mossie then I would have one but it would be electric with a sound unit.
Just looking at photos of the full size, in particular the ailerons which seem to hinge below the surface against a pronounced airfoil section on the wing false TE. Anyone care to explain the advantages of hinging them this way?
Interesting ‘stop’ on the outer, wingtip edge
@Bob Cotsfordthey're ailerons Bob, and I think that David has got it, they are Frise ailerons. Tempted to try and replicas them but don't think I will!
Of course, this is the problem when looking at full size photos, I noticed that the couple of fill size ones I've been studying don't have elevator balancers at the tips, whereas Richard's kit has them. So I merrily went away and redesigned the tailplane and elevators. Later on this afternoon I downloaded a couple of books on the JU88 and having flicked through the pages I suddenly came across line drawings for the G-6 variant and guess what, it has balancers on the elevators.The model is the G-6 variant so I will have to adjust them back!
Edited by Ron Gray
Continuing the redesign of the nacelles involved a lot of time measuring and remeasuring then offering up the dry assembly to the wing to make sure that the orientation of the motors allowed the exhaust to exit as close to the full size exhaust stack as possible. Then it was a case of epoxying the framework together.
As I showed earlier, the side plates for the nacelles needed to be trimmed back due to the extra length of the I/C motor.
They actually needed 20mm cut off but first I cut out the middle section to leave 2 tongues
Then I cut out mounting slots in the new firewalls.
So when dry assembled
After final measuring I was able to determine the orientation of the engine and then fitted the flanged nuts
I then assembled both nacelles using epoxy and trimmed back the nacelle side tongues
Motor mount loosely attached. Note that I cut out a section of the top of the motor mount to allow the motor to fit tight against the firewall (thanks for the tip Richard).
Whilst all that was going on I also assembled the tail feathers
And these are the tip ends which will need to be cut and reformed due to my mistake in building the wrong model (see above)
Edited by Ron Gray
A little bit more done, although it has taken a bit of time to do it!
Tank/throttle servo tray added (screwed to bearers)
4" drain pipe cowl (thanks Richard) cut out for cylinder, main needle and fuel pipe
Front cowl cut out for engine
Loosely assembled
Just got to do it all again for the other nacelle!
  • Thanks 1
Just seen this highly interesting build article for the kit build for the Ju88.I have an old electric/pss 72” one but could do with the canopy renewing.Would anyone know if it’s possible to buy a spare bomber canopy to fit?my original mould has seen better days!many thanks
I remember your model well from the early noughties - here's  a wee clip from the Blackpool Fly-in. The video quality that could be uploaded then was pretty low res, but it gives a good impression of how well the model flew. Aces High March by Vale Royal Schools Band.
Happy days. ?
So surprised that anyone remembered my Ju88 after all these years!Then it was powered by two speed 600 motors and nicads and it's still set up to fly both as electric or pss but now mainly as pss.It's now nearly 28 years old and still gives a lot of fun but the canopy now could do with replacing.Thanks for the video,I never knew it existed after all these years!Hear's a couple of brilliant photos taken by patmac in it's present Sicilian camo colors at my local cliff soaring site.
I haven't gone to sleep or got bored with the build (yet???) but I promised to only post stuff to do with the I/C 'differences', so, whilst photos have been taken of the normal build parts of the tailplane , fin etc, here is the work that I've done to the cowls. These cowls have taken up a lot of building time but it doesn't show in the finished item!
I decided to fit the ply cowl covering before fitting them to the wings as I felt that it would be easier to do that now rather than later. I drew up a template on paper and then transferred that to the ply which was cut using scissors. I then stuck it to the cowl framework using cyano which will be reinforced on the inside when I fuel proof / epoxy the cowls. I've also added an additional thin strip of the same ply to the rear edge which will provide a 'seat' for the plastic rear cowl covering.
I did add a strip of balsa to the back of the firewall to provide a wider surface to stick the ply to. I've also added strip balsa to the top edge of the ply to give it some lateral support. Notice the angle of the ply which is due to the down thrust built into the firewall.
Drain pipe motor cowling attached, all lines up.
@Piers Bowlanthank goodness there’s someone else out there apart from @leccyflyer! In answer to your question, I will be mocking up the aileron later on today as I want to make sure it’s going to work (I’m sure it will). The unknown is what it will fly like with Frise ailerons, it’s OK on the full size but not all things transfer in the same way to models, so do I risk it? Those who know me probably already know the answer to that!
