Raymond Blackler Posted February 3, 2019 Share Posted February 3, 2019 Fuselage almost done ,been trimming the cowl so it fits now, just got the mounting blocks to go. now going to start on the fairings. I've got a spare ASP .91 waiting to fill the nose up, which I'm fitting sideways with a just engines in cowl muffler. Quote Link to comment Share on other sites More sharing options...
Mike Blandford Posted February 11, 2019 Share Posted February 11, 2019 It's been in the paint shop! Insignia are hand painted! At the moment the canopy is just placed in position. Mike Edited By Mike Blandford on 11/02/2019 18:50:46 Quote Link to comment Share on other sites More sharing options...
Alan Thorpe Posted February 11, 2019 Share Posted February 11, 2019 Amazing looking hurricane! Hard to choose which I prefer.....bones look fantadtic, camoflage looks fantastic!! Well done! Quote Link to comment Share on other sites More sharing options...
Mike Blandford Posted March 23, 2019 Share Posted March 23, 2019 I did some power tests today. The motor I'm using is an E-max GT 4020/07, KV=620. My plan is to use 6 cells, although at that KV value, 5 may be better to give a larger prop. Test 1 with a 11x7 master prop gave took 36.5A, so around 800W. Test 2 with a 13x6.5 APC-E prop took 52A and around 1100W. Test 3 with a 12x6 Graupner grey prop took 45A and around 950W. I hadn't got an RPM sensor hooked up, but I'd estimate test 1 at around 11000RPM. As I was using a 4-cell and a 2-cell in series (3000mAh), I didn't have a full voltage reading either, although the 4-cell (quite old) showed between 14.6 and 14 V. I'm tempted with the 11x7 and 800W at the moment, although a 12x6 may look better. Mike Quote Link to comment Share on other sites More sharing options...
Chili Pants Posted March 24, 2019 Share Posted March 24, 2019 Mike, great looking job on the Hurricane. I do not have one but I do use the E-max GT4020/07 to power a Hyperion Yak54 40E, I use a larger propeller due to the cowl on the yak on a 4000 mah 4s battery, it is "hot" set up in more ways than one! I don`t know if you are aware but there are some reports on the web of people getting some prop slip on these higher power E-max motors, due to the prop adapter back-plate/washer not having any crosshatching grip machined in. Initially all was good (first twenty or so flights) Well I thought this was happening to mine, it was great on ground testing but once under load in the air it produced a sound exactly like a propeller slipping, kind of a zipping sound. You could see the propeller slowing down exactly as if the prop was slipping (the pitch of the sound increased as the prop slowed) The first time it happened was on take off and I just managed to save her, that was when I read up on the motor and found some information on prop slipping, I rectified this by putting some cross hatching on the prop washer and some emery paper on the back plate and tightened up the prop nut as hard as I could, bench tested it and all was good. A couple of weeks later, off to fly it again and on take off the same noise and the same slowing prop, luckily I caught it just before take off this time, I rechecked he prop nut for tightness and made several more attempts with the same result, once the prop was under take off load, that zipping sound and the propeller visibly slowing down. Perplexed I did some more research and found one chap on line who described the same issue with this motor (fine on ground test but once loaded in the air problems ensued) the fix was simple, even though the motor ran great on the ground, the ESC timing was the problem and had to be set to high, once I did that the problem was solved, now pulls like a train, awesome power. Sorry for the long post but I thought it best to give as much information as possible, it was a tricky problem to pin down, myself and several of the club flyers were convinced it was the prop slipping. Greg Quote Link to comment Share on other sites More sharing options...
Mike Blandford Posted March 24, 2019 Share Posted March 24, 2019 Interesting, I wonder what the mechanical explanation is! Normally, I would expect the motor to speed up as the 'plane gathers speed. Since I'm looking to use 6S, my motor should be rotating quite a bit faster than yours already! The prop washer on mine is already hatched. I'll check to what I have the timing set anyway. Mike Quote Link to comment Share on other sites More sharing options...
RICHARD WILLS Posted March 25, 2019 Share Posted March 25, 2019 Mike , your Hurricane looks excellent and ....light ! Since you are trying to recreate a good 70Four Stroke style performance , why not have a quick look at other similar plane set ups ? On this forum is a thread by Brian on the Macchii 202 . It is of similar size and I believe it flies on 5s with a nice prop. Ive seen it fly and the performance and duration is very good . The other thought is the 1700mm FMS models . What prop/battery/motor ? Finally , the new Avios Spitfire has five cells and a large three blade that would suit the Hurricane . Good luck Richard Quote Link to comment Share on other sites More sharing options...
Mike Blandford Posted April 6, 2019 Share Posted April 6, 2019 Getting close to finished! I've still to fit the pilot and canopy, but the radio and electrics are all in. Just fitted a FrSky MLVSS (specially wired to give pack voltage only), and an FrSky RPM sensor. I already had a FrSky 150A current sensor fitted. All are mounted in the cowling area, as is the ESC. If I need some nose weight, it may as well be useful! I think I shall go with a 12x6 prop, just got a couple of Master ones and a 3" black spinner. All fitted and working. I did a quick test indoors using s 2S, 3000mAh battery. I had readings of 7.2V, 9.0A and 4450 RPM. I haven't checked the calibration of the voltage reading yet. As I intend to use 6S, I could be looking at 12000 RPM on the 12x6 and around 1000W. The next job is to check the CofG. Given I've used the larger tailplane size, I'm wondering how far back from the position on the plan, (mentioned earlier in this thread as conservative, nose heavy) I could go. I like "light" for the overall weight! I'll probably put the 6S in and check the weight and starting CofG position. For information, someone on another forum asked about the MLVSS sensor (normally plugs into the pack balance connector and reads all the cell voltages) and if it would work to just measure the whole pack voltage, wired to the ESC power leads only. I did some tests and came up with wiring 6, 2K7 or 3K3 resistors, one each between the seven connections to the MLVSS. This provides suitable input voltages to each one, and then gives the total pack voltage. I'll need some stick time on other models before I fly this! Mike Quote Link to comment Share on other sites More sharing options...
RICHARD WILLS Posted April 7, 2019 Share Posted April 7, 2019 The larger tail size supplied with the kit is the "default " standard set up . The C of G on the plan assumes this . Once the test flight is out of the way, you can start moving the C of G back . Only one person that I know has used the smaller tail , which I wish I had never referred to on the plan ! Usually my kits all have larger tail areas and nobody even notices . Richard Quote Link to comment Share on other sites More sharing options...
Raymond Blackler Posted April 7, 2019 Share Posted April 7, 2019 I have been flying warbirds for more years then I wish to admit, and most of my models were not to scale, which results in a much more flyable model , nobody ever noticed they were not to scale Ray Quote Link to comment Share on other sites More sharing options...
Maurice Dyer Posted April 7, 2019 Share Posted April 7, 2019 Chaos Are these still available to buy, as kits Quote Link to comment Share on other sites More sharing options...
RICHARD WILLS Posted April 7, 2019 Share Posted April 7, 2019 Sadly, only the Spitfire is currently available. Quote Link to comment Share on other sites More sharing options...
Mike Blandford Posted April 9, 2019 Share Posted April 9, 2019 I've just weighed my Hurricane (without flight pack) and it comes out at 6 lb 8.2 oz. The 6S, 3000 battery is around 18 to 19 oz, so I'm looking at 7 lb 11 oz plus any extra nose weight I need! Mike Quote Link to comment Share on other sites More sharing options...
Glynn Posted March 13, 2022 Share Posted March 13, 2022 So with Richard moving to Wiltshire, me still in Essex, Covid and lockdowns, we ended up with the stock in storage. Richard has started to sort out some things. So I thought I would give you guy's the heads up. I have just put one P51B kit, one P51D kit and Two Hurricane kits on the WarbirdReplicas.co.uk website. There is also One JU88 Bomber kit but you will have to email me for that. All are first come first served. Glynn Quote Link to comment Share on other sites More sharing options...
Andy J Posted May 24, 2022 Share Posted May 24, 2022 Getting my Hurricane back in flying condition after a long lay up. Can anyone recommend the aileron and elevator deflections as inadvertently lost the Tx settings for the model. Quote Link to comment Share on other sites More sharing options...
gillyg1 Posted October 24, 2022 Share Posted October 24, 2022 Guys about to start my hurricane, as a winter build , going to do it as 7L, shuttleworths sea hurricane. One thing i'm not clear on, is the 3 colours on the airframe. 1, underside : duck egg blue 2: top side: dark sea grey. 3: ??? is it : extra dark sea grey,or would it be some sort of green ? I've seen it modelled with the 3rd colour being green, however this was critisized in the write up as incorrect. So any advice would be welcome. Many thanks Graham ( Cornwall) Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted October 24, 2022 Share Posted October 24, 2022 Not sure if these helps, taken in September (I was more interested in the exhaust stubs!). Quote Link to comment Share on other sites More sharing options...
Jon H Posted October 24, 2022 Share Posted October 24, 2022 I believe its called slate grey but it looks green. I painted an airfix sunderland years ago and remember it from there Quote Link to comment Share on other sites More sharing options...
Jon H Posted October 24, 2022 Share Posted October 24, 2022 Google foo found this and its got the humbrol paint codes. Humbrol 224 is slate grey Quote Link to comment Share on other sites More sharing options...
gillyg1 Posted October 24, 2022 Share Posted October 24, 2022 Cheers guys, Jon very helpful. Ron photos will come in handy when finishing, do you have any photos of the deck hook with associated securing points? Quote Link to comment Share on other sites More sharing options...
gillyg1 Posted October 24, 2022 Share Posted October 24, 2022 Has anyone on here modelled the sea hurricane before ? If so who did you use for decals and technical nomencleture ? In contact with " Moorland scale model decals" Been quoted £67 for decals and tech set including postage. Quote Link to comment Share on other sites More sharing options...
Eric Robson Posted October 24, 2022 Share Posted October 24, 2022 Don't know if Glynn Lander is still doing decals as he has been off the forum for a while, it would be worth your while to pm him as he does sets for the Warbird replicas kits. a lot less than £67, at least they were before L.T. that is for the main decals squadron codes and numbers. Quote Link to comment Share on other sites More sharing options...
Jon H Posted October 24, 2022 Share Posted October 24, 2022 On my DB hurricane i was feeling cheap so painted the insignia myself. It came out so well i am likely to continue painting them. For the roundels i just cut out circles of masking tape with a compass cutter and sprayed the colours in turn. You can also try getting some waterslide decal paper and printing your own. I tried this recently on my ugly mustang and i am satisfied with the results. 1 Quote Link to comment Share on other sites More sharing options...
Maurice Dyer Posted October 25, 2022 Share Posted October 25, 2022 I've used waterside transfer decal paper loads before, and although not F4C standards, very satisfied. Quote Link to comment Share on other sites More sharing options...
