Flyer Posted August 17, 2020 Share Posted August 17, 2020 'Sounds' interesting. May have to rob the piggie bank Quote Link to comment Share on other sites More sharing options...
Peter Jenkins Posted August 17, 2020 Share Posted August 17, 2020 Thanks Richard. Quote Link to comment Share on other sites More sharing options...
Jonathan S Posted August 17, 2020 Share Posted August 17, 2020 Richard, Any news on the Pilot as well while were talking about what we need to raid from the piggy bank? Quote Link to comment Share on other sites More sharing options...
RICHARD WILLS Posted August 17, 2020 Author Share Posted August 17, 2020 Oh yes , already thought of that , Had some made by the genius sculptor David , 1/8 American Pilots . We also have a 3d printed cockpit kit . Sorry , he's lying down on the job , Great detail though , Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted August 17, 2020 Share Posted August 17, 2020 Looks really good Richard, any pics of the cockpit? Quote Link to comment Share on other sites More sharing options...
Jonathan S Posted August 17, 2020 Share Posted August 17, 2020 Pilot looks great Quote Link to comment Share on other sites More sharing options...
Glynn Posted August 17, 2020 Share Posted August 17, 2020 Pictures of the cockpit kit will be coming soon as I tweak the dimensions to suit Richards build, there will be two versions one for the High back B/C and one for the D as the radio was different due to the room behind the Pilot. Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted August 17, 2020 Share Posted August 17, 2020 Thanks Glynn. Quote Link to comment Share on other sites More sharing options...
leccyflyer Posted August 17, 2020 Share Posted August 17, 2020 Hi Richard - those look and sound great, please add the pilot, cockpit kit and sound system to my P-51B order. Thanks Brian. Quote Link to comment Share on other sites More sharing options...
parridav Posted August 21, 2020 Share Posted August 21, 2020 Richard please add pilot and cockpit kit to my P51D. Thanks David P Quote Link to comment Share on other sites More sharing options...
peter harvey 1 Posted August 26, 2020 Share Posted August 26, 2020 as Richard says Andrew (Mr rc sound) is a great bloke, I have one of his systems and after removing it from a model, I set it up on a bench to try something out. The result was that the set up didnt work, after a few emails back and forwards to Andrew we worked out why, The model that it had been in had a flight battery in and as usual I switched this on before connecting the main battery, the set up on the bench I just plugged in the lipo which also fed the sound system, as the receiver takes a few seconds to initiate as does the esc the sound system initiated straight away, with a result that it could not find the start up position for the motor and as a consequence initiation failed. This was simply fixed by a switch in the feed to the sound board to make sure that lipo connected first the sound system. Sounds simple and obvious now but it took a lot of head scratching to sort. Peter Quote Link to comment Share on other sites More sharing options...
Paul Johnson 4 Posted August 26, 2020 Share Posted August 26, 2020 Hi Guys, I hope you are seated well I have a little something to share..... Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted August 26, 2020 Share Posted August 26, 2020 C’mon Paul, open it! Quote Link to comment Share on other sites More sharing options...
Paul Johnson 4 Posted August 26, 2020 Share Posted August 26, 2020 How about a different angle... will that be enough? Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted August 26, 2020 Share Posted August 26, 2020 For all we know it could be an empty box, we need proof! Quote Link to comment Share on other sites More sharing options...
Flyer Posted August 26, 2020 Share Posted August 26, 2020 The batteries to run the sound system ??? Quote Link to comment Share on other sites More sharing options...
Paul Johnson 4 Posted August 26, 2020 Share Posted August 26, 2020 Okay okay I wasn't sure you were ready yet... BUT... Thats it till the weekend as I am currently at work and the box is at home. NO I won't give you my address Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted August 26, 2020 Share Posted August 26, 2020 Gosh, a white flower pot as well! Quote Link to comment Share on other sites More sharing options...
peter harvey 1 Posted August 26, 2020 Share Posted August 26, 2020 the flight battery runs receiver servos etc and the main battery just runs the motor, andrew supplies a piggyback connection to whatever your lipu connects with cheers Peter Quote Link to comment Share on other sites More sharing options...
Jonathan S Posted August 26, 2020 Share Posted August 26, 2020 Wow amazing.... looks great cannot wait to see the build. Are you going to add sound? Quote Link to comment Share on other sites More sharing options...
Paul Johnson 4 Posted August 26, 2020 Share Posted August 26, 2020 Posted by Jonathan Sharland on 26/08/2020 18:20:05: Wow amazing.... looks great cannot wait to see the build. Are you going to add sound? Sound? No I'll just be typing, no narrative Quote Link to comment Share on other sites More sharing options...
Paul Johnson 4 Posted August 26, 2020 Share Posted August 26, 2020 just for you Ron.... Initial contents... And NO the toes on the bottom left are not included... Mouldings.... Canopy.... up to its usually high standard. Laser cut parts are of a high standard, with very little or no distortion. Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted August 26, 2020 Share Posted August 26, 2020 That looks so good, can't wait for you to get started on the build. Quote Link to comment Share on other sites More sharing options...
Paul Johnson 4 Posted August 26, 2020 Share Posted August 26, 2020 Well let's see if I can do you all justice.... Here's the aim Quote Link to comment Share on other sites More sharing options...
Paul Johnson 4 Posted August 26, 2020 Share Posted August 26, 2020 Just a reminder Guys, please make sure all who have asked for a kit make sure you have sent Richard a pm. Including Your name, not just your forum name, Full address and complete list of what you require. It's the two boys who sort the kits and check the pm's. If left to Richard......well.... Quote Link to comment Share on other sites More sharing options...
