Ron Gray Posted May 31, 2020 Share Posted May 31, 2020 Look at Danny Fenton’s thread, Hawker Nimrod, to see what he tried on that build (including Flite Metal).Here Edited By Ron Gray on 31/05/2020 07:20:14 Quote Link to comment Share on other sites More sharing options...
Martian Posted May 31, 2020 Share Posted May 31, 2020 Posted by Eric Robson on 30/05/2020 23:05:44: Never mind Martian , just fly it inverted! Still looks good . What span is it? Cheers Eric 55" I think Quote Link to comment Share on other sites More sharing options...
Jonathan S Posted June 2, 2020 Share Posted June 2, 2020 HI all, very excited about this plane arriving. Just getting some bits together to be able to start this build when it arrives. I have a couple of questions. What tools other than the usual (craft knife, sandpaper / permagrit, razor saw) Should I look to invest in to make my life easier? What size build board will I need my current one is for building small VMC rubber powered models. Thanks Jo Quote Link to comment Share on other sites More sharing options...
Peter Jenkins Posted June 2, 2020 Share Posted June 2, 2020 Jonathan Plasterboard makes a good building board. Flat and it will take pins quite easily. You can get your supplier to cut the board to size or take a circular saw to it. I use the SLEC Plan Protector over the plan and that has worked brilliantly. In addition to your existing tools, a pillar drill is a good long term investment. Good luck. Peter Quote Link to comment Share on other sites More sharing options...
SR 71 Posted June 3, 2020 Share Posted June 3, 2020 I always use a stanley knife and a straight edge to cut plasterboard, cut the paper backing one side crack the board on the cut it will fold over then cut the back side with it still folded, you get a nice clean cut, cutting with a saw will leave a rough edge, its always cut with a knife in the building trade Quote Link to comment Share on other sites More sharing options...
Piers Bowlan Posted June 3, 2020 Share Posted June 3, 2020 Jonathan, I expect you have one but a steel rule for cutting balsa strips is essential, I have one, two foot and one metre lengths. A set of engineering T squares are very useful too. A razor plane I would classify as essential too. Welcome to the forum by the way. Quote Link to comment Share on other sites More sharing options...
Paul Johnson 4 Posted June 3, 2020 Share Posted June 3, 2020 Hi Jonathan, You ill be pleasantly surprised with Richards Kits. The 'Plan' is usually an outline drawing only as the model tends to fit together very well and has jigging to obtain the correct washout/dihedral. Have a look at the Spitfire build and you will get a feel for how the kit will be. Oh and with all these sharp instruments, don't forget the plasters (Glynn you stocked up mate?) Quote Link to comment Share on other sites More sharing options...
Jonathan S Posted June 4, 2020 Share Posted June 4, 2020 HI, Thanks for all your help and advise. I have been reading the Spitfire builds with great interest. I am not sure if they fill me with confidence or make me more scared of what I have got myself into.... Hopefully someone else will post lots of pictures and do a P51 step by step build or Richard might get a few stupid questions from the build newbie.. So other than the tools any idea of the parts we will need to complete the build, trying to get a shopping list of stuff drawn up so I can spread the cost (hide it from the wife). thanks Jon Quote Link to comment Share on other sites More sharing options...
Paul Johnson 4 Posted June 4, 2020 Share Posted June 4, 2020 Jon, I would start by find a good 'example' of a colour scheme that takes your interest. That alone can be a challenge. There are many to choose from. Don't worry about the how to either, there will be plenty of info here as and when the kits are released. Any extras can be 'acquired' as the build progresses. Quote Link to comment Share on other sites More sharing options...
Jonathan S Posted June 6, 2020 Share Posted June 6, 2020 HI all, I found this link while looking for P51's. Lists pretty much every variation of P51 I have seen... https://www.rcgroups.com/forums/showthread.php?1112761-P-51-Mustang-Squadron-Markings-Reference-Thread P51 markings and colours Might be useful when thinking about what colour you want to paint and if you want a B or D.... Have fun Jon Quote Link to comment Share on other sites More sharing options...
Peter Jenkins Posted June 7, 2020 Share Posted June 7, 2020 Jon, that's a useful link but it fails to show very much of the original specifier and user of the Mustang, the RAF. The Mustang was borne out of a visit by a British Purchasing Commission who in Jan 1940 wanted North American to licence built P40s for them. By April 1940, the Commission had decided that the P40 was not longer suitable for European combat conditions so they agreed that NA could submit its own design to the Commissions requirements. Considering that NA had only built trainer aircraft (the Harvard being the most well known) they did well to meet the Commission deadline of 120 days for the first prototype. Much is made of the laminar flow wing employed but when assessed in the UK the boffins did not think that had much effect but rather the use of flush riveting and the quality of the skin joins plus the very clean lines of the design (including the ventral radiator) was responsible. None of this would have happened had it not been for the British order and the Mustang would never have been born. Also, the British and French had placed orders for 11,000 aircraft on US industry and the British then also placed a further 22,000 orders after the fall of France. This allowed the US companies to prepare for production so that when the US entered the war in Dec 1941 the US aircraft production capacity had been well and truly primed. Apparently, had this not been the case, it would have taken around 3 years for the US aircraft production capacity to build up to the required level and the war would have extended for much longer - but that's another story. The Allison engined Mustangs performed very well at lower levels, up to 20,000 ft after which the single speed single stage supercharger failed to keep the power up unlike the Merlin which had a 2 speed 2 stage supercharger with intercooler. The Mustang Mk 1, 1A and 2 (P51 and P51A US designation) were therefore used for Army Cooperation and Tactical Reconnaissance by the RAF and the USAAF. RR took up the idea of replacing the Allison with the Merlin 61 and when this was approved by both the UK and US, the true value of the Mustang was finally realised. The first Merlin Mustang flew in Oct 42 and proved a great success. The combination of the design brilliance of North American and the technical brilliance of RR combined to make the Mustang the success it became. The Mustang's long range was enhanced by it's performance at altitude where it could now outperform all piston engined German fighters. The Merlin was licence built by Packard for all the production Mustangs from then on. The P51B (designated P51C for those built at Dallas) became the Mustang III in RAF service. The RAF retrofitted the Malcolm hood to all their Mustang IIIs and some USAAF Mustangs were also fitted with Malcolm hood which provided better visibility than the standard B model canopy. In Feb 44, 19 Sqn was equipped with Mustang Mk IIIs and were transferred to Fighter Command. However, the real solution to better rear vision was a bubble canopy and that followed in short order after a major re-design to the aft fuselage. The first P51D, Merlin Mk IV (also designated P51K for Dallas built models). The RAF received its first Mustang Mk IV (P51D) in Sep 44 and their first task was to fly long range fighter escort for USAAF bombing raids into Germany pending the buildup of the USAAF's Mustang force. I think that there were around 12 RAF squadrons that operated the Mustang Mk IV (P51D) and a lot more operated the Allison engined Mustang. As it happens, I'm using the Polish RAF 303 Sqn for my P51D build and their aircraft look like this: I just thought it worth setting the record straight as regards how the Mustang was born and what made it the huge success it became in the final D model. The British contribution to both was vital. Quote Link to comment Share on other sites More sharing options...
Paul Johnson 4 Posted June 7, 2020 Share Posted June 7, 2020 Peter, a nice piece of history and Jon as I said a lot to choose from. I bet that makes deciding easier now...!!! I believe that a lot of the pilots that flew both types actually preferred the razor back version as it was slightly faster. I have always looked for a particular pilot or event from history that I found inspiring for my subject. I have chosen one particular dare devil's escapades in particular as it portrays the typical fighter ace guts and determination. This being the Berlin Express. But it can also be from something you have seen at a air show or museum that inspires you. Edited By Paul Johnson 4 on 07/06/2020 06:27:05 Quote Link to comment Share on other sites More sharing options...
Paul Johnson 4 Posted June 7, 2020 Share Posted June 7, 2020 Berlin Express Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted June 7, 2020 Share Posted June 7, 2020 Oh, I was going to do that one Paul, I'll have to look for another subject now Edited By Ron Gray on 07/06/2020 08:58:18 Quote Link to comment Share on other sites More sharing options...
Paul Johnson 4 Posted June 7, 2020 Share Posted June 7, 2020 There's always room for one more.... then we can compare notes.. Quote Link to comment Share on other sites More sharing options...
Peter Jenkins Posted June 7, 2020 Share Posted June 7, 2020 Don't forget the Eagle Squadron folk. The 3 squadrons that were eventually mostly staffed by Americans were 71, 121 and 133. Take a look at Wikipedia. When they transferred to the USAAF, the 3 squadrons stayed together and became the first operational fighters for the USAAF as the 4th Fighter Group and as 334, 335 and 336 Fighter Squadrons retaining their Spitfires until they were replaced with P47s and then P51s. Some of the Eagle Sqn pilots were: It is reported that Pilot Officer Art Donahue DFC stayed with the Eagle Squadron only a short time before requesting a transfer back to his original RAF unit. He did not appreciate the unruly behavior of many of the American pilots. He was killed in action in 1942.[13][14] Captain Don Gentile was a pilot with 133 Squadron, claiming two air victories, and by March 1944 had become the 4th Fighter Group's top ace in World War II, with 22 aerial kills. Colonel Chesley "Pete" Peterson had 130 sorties with the Eagle Squadrons and became the youngest squadron commander in the RAF. When the Eagle Squadrons were transferred to the 4th Fighter Group, Peterson became the group's executive officer, succeeding to command of the group in April 1943, and becoming at 23 the youngest (at the time) colonel in the USAAF. Colonel Donald Blakeslee was a pilot in 121 and 133 Squadrons during 1942, making 120 sorties and claiming three aerial kills. He became deputy commander of the 4th Fighter Group under Chesley Peterson, then commanded the group from January to October 1944. More choice! Incidentally, some of the Polish pilots were also seconded to the USAAF to help to train up the newcomers and the RAF helped to teach current fighter tactics to the American fighter pilots. Quote Link to comment Share on other sites More sharing options...
Peter Jenkins Posted June 7, 2020 Share Posted June 7, 2020 Posted by Paul Johnson 4 on 07/06/2020 06:26:17: I believe that a lot of the pilots that flew both types actually preferred the razor back version as it was slightly faster. In my first posting in the RAF, I met an old Sqn Ldr who it turned out had flown Mustangs in WW2. He first met a Mustang (a Mustang II with the Allison engine) when he joined a Squadron (I never did ask which one) in North Africa. His Flt Cdr asked if he'd flown Mustangs to be greeted with "No". So, he was taken out to the aircraft, sat in the cockpit, given 20 mins instruction on the instruments and handling, had the engine started for him, and then told to fly it for 20 mins. He landed, and they loaded 2 x 250 lb bombs and he was told to fly it for 20 mins to get the feel of it. After landing, he was dragged off to a briefing while 2 x 500 lb bombs were loaded and he joined the Sqn in his first operational ground attack. He'd been warned to "unload" the aircraft (gentle nudge forward with the stick) as he released the bombs as otherwise it was possible for one to hang up and when you pulled out you had 500 lb on one wing only! He duly unloaded and pickled and in his desire to get out pulled too hard and blacked out, coming to with the aircraft pointing vertically up. He decided the best solution was to continue with the loop and then escape. The old hands looked on at the new boy and raised their eyebrows at this aerobating under fire! When they transferred to the Merlin-engined Mustang III they had to learn not to nurse the Merlin along, as had been the case with the Allison, as otherwise the plugs fouled up. A lesson no one felt up to passing on to an Air Cdre who came down to fly with them. He was used to the Allison engine and nursed the Merlin along. As he had chosen to lead the squadron, the rest followed at nurse speed but would break out of formation to give the Merlin some stick to clean the plugs before rejoining. The Air Cdre thought this very odd behaviour and named them the weavers for their actions! He was also the first pilot to bale out of a Mustang and survive! All others had been hit by the tailplane and died. He was fished out of the Med and stood up at briefing the next day to recount how he did it! Well, he said, I just dived over the side aiming for the wing trailing edge! He preferred the Mustang III (B) as he was a short chap and when he went to the Mustang IV (D model) he found that he couldn't see as well to the rear 3/4s looking down as the bubble canopy sloped up at the back. He was mostly involved in ground attack as opposed to air defence. Apart from that, he didn't seem to have a preference for the Mk III. At lower levels, it may have been the difference in supercharger settings that gave the B the edge over the D but I've not seen this as a general comment on the difference between the B and D model. Quote Link to comment Share on other sites More sharing options...
leccyflyer Posted June 7, 2020 Share Posted June 7, 2020 Berlin Express is the scheme chosen by VQ Models for their new 60" span ARTF P-51B, featured in this month's RCM&E shopping roundup pages. Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted June 7, 2020 Share Posted June 7, 2020 Apologies if this has been posted before, but nice Mustang site here. Quote Link to comment Share on other sites More sharing options...
Paul Johnson 4 Posted June 7, 2020 Share Posted June 7, 2020 Hi Ron Nice site, thanks. Quote Link to comment Share on other sites More sharing options...
Paul Johnson 4 Posted June 8, 2020 Share Posted June 8, 2020 I came across this picture and it made me think on how some strive to accquire a model finished to a pristine condition... I don't think these guys were too worried about blending the edges Quote Link to comment Share on other sites More sharing options...
RICHARD WILLS Posted June 27, 2020 Author Share Posted June 27, 2020 Ah , they clearly havent been to St Martins school of art . In fact , I dont think they have even had the benefit of watching "Vision On " . On the P51 front , I have to explain why its taking a bit longer than we hoped . Two issues to work around . We want everyone to be able to use the FMS P51 spinner and propeller . It is well proven and generally available at a reasonable cost .The problem is that our original P51 fuselage had a 3" spinner where as the FMS spinner is nearer to 3.25 " . The cowl is a four inch deep vac form which needs to have inward sloping sides to have any chance of getting it off the mould , so opening up the front is not an option . Consequently we have had to redesign all of the fuselage components as well as design a new wing , Secondly , my kit cutter is contracted to produce wings for Doolittle media (so he has to do most of the "doing " They have hundreds of designs on their books and of course , at the moment , everyone is at home ordering wings for their lockdown build. Having said all that , a fair bit has been done . And the result will be a well sorted and sustainable model with out any loose ends that most kits leave you to ponder , ( a pet hate of mine ) Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted June 27, 2020 Share Posted June 27, 2020 Having a loose end at my age is something to avoid. it reminds me a bit of when I was at college and the lecturer was asking about the benefits of having a tower crane on site. He said that for one thing it speeds erection time, a bright spark responded with “I’ll have six please”. Quote Link to comment Share on other sites More sharing options...
Paul Johnson 4 Posted June 27, 2020 Share Posted June 27, 2020 I tend to find that as the bits fall off I just stop and pick them up and worry about gluing them back later.... I'm beginning to wonder if it's worth actually gluing them back as they tend to just go rusty these days..... Quote Link to comment Share on other sites More sharing options...
Nigel Dell Posted June 27, 2020 Share Posted June 27, 2020 Posted by Ron Gray on 14/05/2020 09:25:33: If I do build the P82 then colours are somewhat limited but Black Knight looks nice although would / could be an orientation issue! Also the fuse would need lengthening (like the P51H) along with the other more obvious mods. Edited By Ron Gray on 14/05/2020 09:26:53 Just seen this thread. Ron, there are a few schemes out there for the F82 that is of interest to us:- Quote Link to comment Share on other sites More sharing options...
