The Ohmen
EarlyBird
5 minutes ago, Trevor said:
Ah yes, the myriad of jobs swept up under the simple instruction 'prepare the airframe for covering'! ?
Yes and I made more work for myself by changing the design. I now have to tweak the cowl as I shortened the nose which changed the shape so I lowered the cowl to suit now the motor is too high and the spinner does not fit and.. well you get the idea.
1 hour ago, Peter Miller said:
I can promise you that NO ONE has ever seen a model like it
Must be one of your own designs from the offset as opposed being based around a full size, now this is really interesting
Floats?
Ability to take off vertically?
Canards?
Forward facing wings?
T tail?
All of the above....Can't wait ?
Taking pre-orders?
On 11/10/2021 at 11:42, Peter Miller said:
In actual fact things may be bent and curved but they all line up with the line of flight and air flow. They are not twisted.
I bet no one thought that it would fly, me for one. ? Truly amazing.
Started covering the fuselage starting with the fiddly bits.
I have copied the Ballerina battery hatch by using covering hinge and magnets.
This has worked well so far.
Test assemble is next before covering the sides.
Presumably this could be a real money maker - someone is bound to bet you it cannot fly!
It just proves that anything can fly if the pilot is clever enough.   Or it proves that some people are expert with Photoshop.......
Come on Peter tell us why you did it!
Edited by kc
Back in the 40s there was a cartoon in Aeromodeller showing a very distorted fighter with the caption "The designer's slide rule was bent"
For years I have wondered if a model could built like that.
Recently I got totally bored with designing the same thin all the time and so decided to do one.  Our editor wants an article n how to do it and make it fly.
Proof.I just spent and afternoon flying it again
  • 4 weeks later...
