Nigel Grant 1 Posted September 25, 2022 Share Posted September 25, 2022 Hi Peter This one looks to be similar to your Miss Sizzles but with built up ailerons and wheel fairings. I'm sure both were good fliers - do you have preference as which was the better model? Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted September 25, 2022 Author Share Posted September 25, 2022 In fact the two models that influenced the design was The Ohmen for the fuselage and Ballerina for the wing. It is possibly a little less wild than The Ohmen and nearer Ballerina but it is still very much an individual model. Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted October 5, 2022 Share Posted October 5, 2022 Sounds good to me Peter, and being an addict, I have just pressed the buy button from Sarik. Steve Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted October 5, 2022 Author Share Posted October 5, 2022 I am sure that you will like it. Quote Link to comment Share on other sites More sharing options...
kc Posted October 6, 2022 Share Posted October 6, 2022 There is a Sarik discount code -HOUND - for use in the next couple of weeks see the details here. It would be interesting to know which parts are included as the 'Laser Cut Wood Pack' - is it all the items shown in Peter's first photo? Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted October 6, 2022 Author Share Posted October 6, 2022 Just a point, The motor mount former should be 1/4" ply. This was my mistake on the drawing and I did advise the correction after checking the proofs. 2 laminations of 1/8" would be just as good. Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted October 7, 2022 Share Posted October 7, 2022 17 hours ago, kc said: It would be interesting to know which parts are included as the 'Laser Cut Wood Pack' - is it all the items shown in Peter's first photo? and more I hope, wing servo trays are normally included, when it arrives, I will lay out the parts as in Peters photo for comparison. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted October 7, 2022 Author Share Posted October 7, 2022 16 minutes ago, EarlyBird said: and more I hope, wing servo trays are normally included, when it arrives, I will lay out the parts as in Peters photo for comparison. That will be interesting to see. Quote Link to comment Share on other sites More sharing options...
kc Posted October 7, 2022 Share Posted October 7, 2022 22 hours ago, Peter Miller said: Just a point, The motor mount former should be 1/4" ply. This was my mistake on the drawing and I did advise the correction after checking the proofs. 2 laminations of 1/8" would be just as good. Actually F1 is correctly shown as 1/4 birch ply on the pull out plan in RCME. Presumably the laser cut parts would use 1/4 or perhaps they would supply 2 layers of 1/8. Quote Link to comment Share on other sites More sharing options...
kc Posted October 9, 2022 Share Posted October 9, 2022 I have roughly estimated the amount of balsa that I would need to build this model - I will put the various sizes and quantity on here if anyone needs it. At Balsa Cabin prices ( SLEC is usually the same ) it comes to £68 for the balsa for entire model. Balsa is expensive now! Plus the ply at about £7 for the large ply fus doublers. There are numerous other small ply parts of various thickness which might come from many modellers scrap box. Otherwise allow extra for various sizes of ply. The laser cut parts set possibly includes the fuselage sides, wing ribs and tailplane etc parts which amount to about £ 20 of the balsa - so maybe you need only £48 worth of extra balsa if you get the laser parts. It remains to be seen what you actually get in the parts set - maybe it also includes the battery platform, wing bolt plate, servo mounts etc. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted October 9, 2022 Author Share Posted October 9, 2022 I always wonder if just buying the wood and cutting your own parts out would not save a bit of cash. But then I am tight fisted. 1 Quote Link to comment Share on other sites More sharing options...
Piers Bowlan Posted October 10, 2022 Share Posted October 10, 2022 Some people are put off building from a plan simply because they consider cutting out the parts a chore. I really enjoy this aspect of making my own ‘kit of parts’, especially with your designs Peter. In the main they involve simple shapes that are quick to make. Sarik and SLEC provide an excellent service and the accurate fit of the CNC parts speeds up the build too (usually!). Great for those cash rich and time poor. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted October 10, 2022 Author Share Posted October 10, 2022 I have only once had a set of parts cut out for one of my plans SLEC cut out the parts for Destiny and they did the most perfect job of that. But then Destiny was something rather special. Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted October 10, 2022 Share Posted October 10, 2022 4 minutes ago, Peter Miller said: Thanks. OK I will do that. Removed now. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted October 10, 2022 Author Share Posted October 10, 2022 9 minutes ago, EarlyBird said: Removed now. THanks to who ever did that. I was sure that I sent a small view of the plan. Now only got a few other things to worry me for the rest of the day Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted October 15, 2022 Share Posted October 15, 2022 Delivered from Sarik yesterday. F1 is cut from 1/4 ply as are the U/C mounts LHS, RHS and base. From 1/8 ply the battery tray, fuselage wing bolt plate for the captive nuts, Aileron horn plates and Tailwheel mount. From 1/16 Aileron servo plates, C2 cowl plate and wing bolt plate. Looks like if it's on the drawing it's included in the cut parts. Steve Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted October 15, 2022 Author Share Posted October 15, 2022 That sounds excellent!! Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted October 15, 2022 Author Share Posted October 15, 2022 That looks pretty good Quote Link to comment Share on other sites More sharing options...
tspr12 Posted October 16, 2022 Share Posted October 16, 2022 Hello Mr. Miller I am from Slovakia. I found your model HOUD DOG in electronic format RCM&E 10/2022. I like the shape and dimensions of the model. That's why I have a question. Can I get a model drawing in electronic format? Thank you for understanding. Joseph Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted October 19, 2022 Share Posted October 19, 2022 I have made a start by popping out all of the cut parts. The wings will be built first so that I can use the fuselage ply doubler for something 🤔 to help shape the wing profile. Steve Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted October 20, 2022 Share Posted October 20, 2022 Started the wings by sanding the burnt wood off the ribs and test fitting the 1/4 spars. The R3 ribs are all the same and the spar cut outs are made to accommodate the dihedral brace. Not a big problem but if cutting your own parts, no problem at all now you know. Now cutting out the TE for the ribs to slot into. Steve Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted October 20, 2022 Author Share Posted October 20, 2022 Only the centre ribs should have the allowance for the dihedral brace. The plan shows 20 ribs without that allowance. which are in the aileron area. This means that there are a few ribs between the dihedral brace an the start f the aileron which are wrong. Luckily not too much of a problem, just a little packing. Poor proof checking on my part. 1 Quote Link to comment Share on other sites More sharing options...
Teacher Posted October 22, 2022 Share Posted October 22, 2022 Hi Peter, Just started my hound dog build. I'm back into aero modelling and have learnt myself to fly over the last two Years. Much better than I did in the 70s! I needed a model to learn to do better aero's. And think your hound will be most suitable. Started my build today, wings first, I see the little problem with cut out on the inner few ribs. As you say just a bit of packing should sort it. Anyway, thank you for designing a interesting model, I've followed a few of your posts for a while now and your a credit to our hobby. David, in Durham. 1 Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted October 22, 2022 Author Share Posted October 22, 2022 Hi David. I am glad that you like the look of Hound Dog. I am sure that you will like it. You will find Hound Dog very docile on low rates and not the slightest bit stressful on high rates. I must admit that I almost feel that I should have increased the rates in the article but my club mates will tell you that with models like The Ohmen and my Peggy Sue the only time they are flying straight and level is when I am flying them inverted and most people find THEM too much. And thank you for your kind remarks Peter Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted October 22, 2022 Share Posted October 22, 2022 Welcome to the forum @Teacher, This is as far as I have got. The only part glued is the bottom spar to the bottom sheet, the rest is dry fit. I set up a simple jig to cut all the spar webs for both wings in one go. I will modify the R3 cut outs by gluing scrap 1/8" square balsa packing then make up more parts before continuing with the glue. Steve Quote Link to comment Share on other sites More sharing options...
