cymaz Posted November 5, 2022 Author Share Posted November 5, 2022 Now lowered the tanks even more, the necks are in line with the carbs. Short video with uniflow tank set up and changed to OS F plugs. The needles need some fine tuning but Mrs C called me in for dinner The Quote Link to comment Share on other sites More sharing options...
cymaz Posted November 12, 2022 Author Share Posted November 12, 2022 Slowly making progress on the engine runs. Not prefect yet... Quote Link to comment Share on other sites More sharing options...
cymaz Posted December 14, 2022 Author Share Posted December 14, 2022 We have a building bench ☺️ Quote Link to comment Share on other sites More sharing options...
flight1 Posted December 14, 2022 Share Posted December 14, 2022 That's a proper high class dining room table😁 + i hope that is the regulatory 92cm work top height or a job's work might be around?!. oh! what's that build hiding in the corner? you got to tell all as we have seen it now🤔🙃 Quote Link to comment Share on other sites More sharing options...
cymaz Posted December 14, 2022 Author Share Posted December 14, 2022 I’m sure Brian will tell you all about it on Friday, should he attend the meeting🤗 Quote Link to comment Share on other sites More sharing options...
Chris Walby Posted December 14, 2022 Share Posted December 14, 2022 Not wanting to put a downer on the good work, but are you sure the building board is level along its entire length? And that its going to stay flat for the entire build. Don't ask me how I know double thickness chip board can have a twist in it... Quote Link to comment Share on other sites More sharing options...
cymaz Posted December 14, 2022 Author Share Posted December 14, 2022 I will be checking it with spirit levels and Brian very soon. I understand your concern! Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted December 14, 2022 Share Posted December 14, 2022 2 hours ago, cymaz said: We have a building bench ☺️ A bit early the fuselage behind it isn't finished,,, Quote Link to comment Share on other sites More sharing options...
alan p Posted December 14, 2022 Share Posted December 14, 2022 The one behind looks like razor back P47. How do you getaway with building in the lounge😲 Quote Link to comment Share on other sites More sharing options...
cymaz Posted December 14, 2022 Author Share Posted December 14, 2022 The secret is to use someone else’s lounge😎….shhhhh 1 Quote Link to comment Share on other sites More sharing options...
cymaz Posted December 23, 2022 Author Share Posted December 23, 2022 Retract units arrived this morning! Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted December 23, 2022 Share Posted December 23, 2022 I take it that you did not fancy the ones I sent you then, don`t blame you but those stubs into the legs will need to be very substantial, at least 8mm and rather tougher than mild steel. They will require a few more than the two grub screws shown since the side load on the u/c can be considerable unless landings are perfectly straight. Quote Link to comment Share on other sites More sharing options...
cymaz Posted December 23, 2022 Author Share Posted December 23, 2022 Martin, you’ve got a pm Quote Link to comment Share on other sites More sharing options...
cymaz Posted February 4, 2023 Author Share Posted February 4, 2023 Brian the builder is suffering I’ll health at the moment. The project is on hold until he recovers. I wish him a speedy recovery x Quote Link to comment Share on other sites More sharing options...
cymaz Posted June 24, 2023 Author Share Posted June 24, 2023 Finally.....the build has begun 🥳 I’m off to see Brian on Sunday so pictures to follow folks. Brian is on the mend and wanting to build. I’ve got a JE inverted muffler to see if we can streamline the exhaust exit, that will be tomorrow. The inner engine nacelles are first to be built as they contain the UC. They’re more cramped and need some careful planning. Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted June 24, 2023 Share Posted June 24, 2023 1 hour ago, cymaz said: Brian is on the mend That's good news I was wondering how Brian was. Even better that he wants to build. Steve Quote Link to comment Share on other sites More sharing options...
cymaz Posted July 2, 2023 Author Share Posted July 2, 2023 Nearly 4 hours work here 🤨 These inboard engine nacelles are a bind, not a lot of room! 2 Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted July 3, 2023 Share Posted July 3, 2023 Yes quite. I ended up with very small SLEC tanks but luckily the motors were very frugal. I also had to contend with cells and switches to ensure that the plugs kept glowing at idle. Cannot remember if I used Herts Models intelligent glow switches or a purely mechanical switch set up. Quote Link to comment Share on other sites More sharing options...
cymaz Posted July 3, 2023 Author Share Posted July 3, 2023 I’ve done some running inverted glows using uniflow tanks. Not bad but all the heights and everything has to be correct Quote Link to comment Share on other sites More sharing options...
cymaz Posted July 4, 2023 Author Share Posted July 4, 2023 Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted July 7, 2023 Share Posted July 7, 2023 That landing gear looks very nice. Don`t know how much experience you have with retracts but a couple of small grub screws onto what look to be 8mm stubs will not stand a chance against the twisting motion of twin legs. Quote Link to comment Share on other sites More sharing options...
stu knowles Posted July 8, 2023 Share Posted July 8, 2023 (edited) Hang on! twin legs have less rotational stress than a single leg. The joiner will need a flat or a dimple but it should be fine. Edited July 8, 2023 by stu knowles Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted July 8, 2023 Share Posted July 8, 2023 Hang on Stu, I used to have one of the above models. Fine if every landing is perfect and always into wind but in reality is never like that. Quote Link to comment Share on other sites More sharing options...
cymaz Posted July 8, 2023 Author Share Posted July 8, 2023 23 hours ago, Martin McIntosh said: That landing gear looks very nice. Don`t know how much experience you have with retracts but a couple of small grub screws onto what look to be 8mm stubs will not stand a chance against the twisting motion of twin legs. There is a total of 4 set screws to each leg mount Quote Link to comment Share on other sites More sharing options...
cymaz Posted July 10, 2023 Author Share Posted July 10, 2023 Another video! Just to remind me how to do the other 3 throttle runs. The Z bend is to accommodate the removal of about 3-4mm of material from the mating face of the muffler. This will bring it just inside the cowl. Nothing is fixed on at the moment the push rod is held in by friction.... Quote Link to comment Share on other sites More sharing options...
