tiny-james Posted November 20, 2022 Share Posted November 20, 2022 Morning all So, I have found a car battery in my garage so I can now charge my lippo batteries on site/airfield. But the bad news is the IMAX b6 ac/dc charger I inherited from my son has no cable to connect to a car battery so I thought I would buy a second charger as I can't find a replacement cable. second hand would be nice but what charger is good for this purpose. Quote Link to comment Share on other sites More sharing options...
Shaun Walsh Posted November 20, 2022 Share Posted November 20, 2022 (edited) Does it not have a jack socket marked 11-18V DC next to the mains socket on the charger? Edited November 20, 2022 by Shaun Walsh 1 Quote Link to comment Share on other sites More sharing options...
tiny-james Posted November 20, 2022 Author Share Posted November 20, 2022 @Shaun Walsh Yes it does but as I've said I have no cable for it Quote Link to comment Share on other sites More sharing options...
tiny-james Posted November 20, 2022 Author Share Posted November 20, 2022 this is the cable I'm missing at time 1.25 in the video Quote Link to comment Share on other sites More sharing options...
Gary Manuel Posted November 20, 2022 Share Posted November 20, 2022 (edited) That's a readily available "cloverleaf" cable. Edit. My mistake, it's the DC jack socket you are after. Edited November 20, 2022 by Gary Manuel Quote Link to comment Share on other sites More sharing options...
leccyflyer Posted November 20, 2022 Share Posted November 20, 2022 (edited) Belay my last pipe - sounds like it's a DC power supply adaptor you need. Edited November 20, 2022 by leccyflyer Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted November 20, 2022 Share Posted November 20, 2022 Like this Steve 1 Quote Link to comment Share on other sites More sharing options...
tiny-james Posted November 20, 2022 Author Share Posted November 20, 2022 yes where did you find this??????? Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted November 20, 2022 Share Posted November 20, 2022 Searched for DC barrel connector alligator clips. Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted November 20, 2022 Share Posted November 20, 2022 Dc Barrel 5.5x2.1mm 2.5mm Male Plug Connector To Dual Alligator Clip Battery Clamp Cable - Buy Alligator Clip Cable,Battery Clamp Cable,Dc Alligator Clip Cable Product on Alibaba.com Quote Link to comment Share on other sites More sharing options...
gangster Posted November 20, 2022 Share Posted November 20, 2022 I reckon that that little DC connector is a design error on that charger. At the size of them they surely are for just a couple of amps. I have used a B6 (clone) for field charging for years usually on 3s lipos at 3 amps. I melted that connector one day charging a 4s at 5 amps. I then realised to do this that poor little plug would be carrying about 10 A. I have chucked out that connector and hard wired it to a fused lead Quote Link to comment Share on other sites More sharing options...
Barryorbik Posted November 21, 2022 Share Posted November 21, 2022 True Gangster, I have modified quite a few of this style charger by removing the DC socket completely and hardwiring the 12V leads directly to the circuit board. Biggest issue is adding a cable grip to prevent the wires being pulled off. Will try to post a picture of a converted one later. Barry 1 Quote Link to comment Share on other sites More sharing options...
Barryorbik Posted November 21, 2022 Share Posted November 21, 2022 Here is one I did earlier. Rubber cable strain relief grommet and a cable tie inside to prevent the wire being pulled out. Quote Link to comment Share on other sites More sharing options...
Trevor Posted November 22, 2022 Share Posted November 22, 2022 Those barrel connectors come in a range of different internal diameters and also vary in length. The quality of the connection depends critically on whether you've got exactly the right plug for the socket. Of course, if you're using the one that came with the charger, that shouldn't be a problem. Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted November 22, 2022 Share Posted November 22, 2022 Some valid comments and not one I'd thought about before, but for info if you are looking for a charger for field use then some now come with better connectors, my Overlander DC100 has an XT60 for external power (plus it can be used as a low power 12v power supply when the charger is on mains supply). Not had any problems charging 6s batteries at 3amps. Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted November 22, 2022 Share Posted November 22, 2022 I have couple of Imax 6 chargers and have never had a problem with the input socket overheating although I mostly charge 4s packs but have always used the lead/plug that came with unit. One thing I have done though is to fit a Shockty diode in the lead as being distracted some while back I connected it to a battery just for fraction of a second and the "magic smoke" came out . The Imax 6 is protected against wrong polarity on the output so why not on the input? Quote Link to comment Share on other sites More sharing options...
