toto Posted July 23, 2023 Share Posted July 23, 2023 Well,  I've been made to eat my own words ...... previous statement ....... I don't like z bends in push rod connections ...... now altered to say ..... I love em .....  Bought myself a set of Z bend pliers and after trying them out, I can see how they can form an accurate and suitably " tight " fit.  I won't say I will be using them absolutely everywhere as some application are maybe not so suitable but .... there are a lot of common everyday examples where they will now be used.  Easy to do, accurate.... and quick. The first 5hing I had to do was work out where in the jaws the bend started so accurate measurement of the push rod could be measured and marked prior to lining up in the jaws.  Once you have this in your head ,... your good to go..  I'm now a convert.  Toto 1 Quote Link to comment Share on other sites More sharing options...
EvilC57 Posted July 23, 2023 Share Posted July 23, 2023 I’ve used them for years. I’ve found the trick is to use a marker pen to put a small mark on the wire exactly where you want the first bend to be (e.g. adjacent to the hole in the servo arm), then make sure you have the pliers the right way around before performing the bends. 1 Quote Link to comment Share on other sites More sharing options...
toto Posted July 23, 2023 Author Share Posted July 23, 2023 They will hold a coveted place in my armoury going forward ... they are easy to use .... even in my arthritic hands.  I'm about to embark on another trainer assembly and these pliers could not have been delivered at a more convenient time. A great time saving device as well as not as much time faffing around with grub screws and connectors etc. It also take away the potential failure through vibration etc.  It was not that I didn't like them at all, I just queried the potential for " slop " being built in but I think that concern has been evaporated.  Bring on the Z bends .  Toto 2 Quote Link to comment Share on other sites More sharing options...
toto Posted July 23, 2023 Author Share Posted July 23, 2023 One thing to add to the above.....  These were £ 18.00. Now I buy a lot of tools ( part of my previous sparky life ) and I believe good " qua Ity " tools are worth every penny.  However, for any fellow newbie ..... I'd say " weigh it up first " as a purchase. If you think that you only intend involving yourself moderately in the hobby .... owning 2 or maybe 3 models max, then its £ 18.00 maybe better spent on something else. Especially if you are on a limited budget.  I'd say that on an average model, be it a trainer or whatever, you may yield on average a useage of say a dozen possible applications ( if you are lucky ) after which this tool could become redundant.  If the above scenario is true of you ..... it maybe better using the connections that come " in the box " modifying to improve reliability of these and spending the £18.00 on maybe better servo's or putting it towards an extra battery. ..... just a thought before anyone goes racing out there to buy a set. I'm not trying to take anything away from the fact that they are very good at what they are intended for.  Should you be looking to have a hangar load of models, even over time, then I'd say they are pretty indispensable.  Toto Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted July 23, 2023 Share Posted July 23, 2023 If you need a Z bend connection then you really do need a pair of Z bend pliers, it doesn’t matter how many ‘planes or how many Z bends. You can bodge a Z bend but it will be just that, a bodge, so get the tool for the job. 3 Quote Link to comment Share on other sites More sharing options...
toto Posted July 23, 2023 Author Share Posted July 23, 2023 I still dont know if I would justify the £18.00 on one model. There are other options and again, suggested for the budget conscious.  I tried making my own Z bends and agree, the were not up to the job so on the basis of " a correct tool for every job " you are 100% right.  Toto Quote Link to comment Share on other sites More sharing options...
Geoff S Posted July 23, 2023 Share Posted July 23, 2023 I remember some Z bend pliers that had an adaptation with a pin you could put through the hole in the servo arm to help get the bend in the right place. I have a 'normal' pair but anything to help getting the bend in the right place would be a great help. Quote Link to comment Share on other sites More sharing options...
Zflyer Posted July 23, 2023 Share Posted July 23, 2023 Just got a pair. I have previously used the bend and twist method, however the stress on the wire is evident. Havent let me down so far but yhink this tool a more 'stress' free option. Quote Link to comment Share on other sites More sharing options...
Graham Bowers Posted July 23, 2023 Share Posted July 23, 2023 36 minutes ago, toto said: I still dont know if I would justify the £18.00 on one model. <SNIP> The "one model" state was passed some time ago, with hardly a blink, as I recall ;-)  Happens in other past-times too, and is formalised in a "rule" world of cycling:   12. // The correct number of bikes to own is n+1.While the minimum number of bikes one should own is three, the correct number is n+1, where n is the number of bikes currently owned. This equation may also be re-written as s-1, where s is the number of bikes owned that would result in separation from your partner. 1 Quote Link to comment Share on other sites More sharing options...
Geoff S Posted July 23, 2023 Share Posted July 23, 2023 2 hours ago, Graham Bowers said: The "one model" state was passed some time ago, with hardly a blink, as I recall 😉  Happens in other past-times too, and is formalised in a "rule" world of cycling:   12. // The correct number of bikes to own is n+1.While the minimum number of bikes one should own is three, the correct number is n+1, where n is the number of bikes currently owned. This equation may also be re-written as s-1, where s is the number of bikes owned that would result in separation from your partner.  As regards pedal cycles, I'm fortunate that my wife is as enthusiastic as I am, though I probably have more. We also have a shared bicycle (a Cannondale tandem). The vast majority of our holidays involve cycling - at one time seriously but not so much now. Quote Link to comment Share on other sites More sharing options...
Graham Bowers Posted July 23, 2023 Share Posted July 23, 2023 1 hour ago, Geoff S said:  As regards pedal cycles, I'm fortunate that my wife is as enthusiastic as I am, though I probably have more. We also have a shared bicycle (a Cannondale tandem). The vast majority of our holidays involve cycling - at one time seriously but not so much now. Lucky man.  My wife has tried, however isn't confident cycling. The last attempt involved a pedal assist bike and one to one lessons, however it didn't do the trick.  Upside is I I have a long leash, so bicycling adventures are very much on the agenda. Quote Link to comment Share on other sites More sharing options...
Nigel R Posted July 24, 2023 Share Posted July 24, 2023 20 hours ago, Geoff S said: I have a 'normal' pair but anything to help getting the bend in the right place would be a great help. Â Dead easy really: Â Measure the length of rod you need. Subtract 5/16. Put edge of pliers at that point. Bend. Done. Â Â Quote Link to comment Share on other sites More sharing options...
Nigel R Posted July 24, 2023 Share Posted July 24, 2023 16 hours ago, Geoff S said: This equation may also be re-written as s-1, where s is the number of bikes owned that would result in separation from your partner.  I have three bikes, one of which I don't need and should get rid of, because I'm too old to be doing downhill riding.  On the other hand, my wife definitely owns 's-1' bikes. Seven or eight, or maybe nine, last count, depending on whether you count the one that was mislaid and last seen at the in-laws house many years ago.  They take up a lot more storage space than toy planes.  However, even too many bikes are a lot cheaper than one horse, which she used to do when younger.  Swings and roundabouts. Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted July 24, 2023 Share Posted July 24, 2023 A bit off track, but "Swings and roundabouts" you can ride to the Butchers, or eat the Horse,,, 1 Quote Link to comment Share on other sites More sharing options...
eflightray Posted August 3, 2023 Share Posted August 3, 2023 I gave up on 'Z' bends and went over to a single bend and a wire keeper. Made it easy to disconnect a pushrod. Also added a zig-zag bend if the pushrod needed any length adjustment, but then that was back in my single channel days.  Ray  Quote Link to comment Share on other sites More sharing options...
PatMc Posted August 3, 2023 Share Posted August 3, 2023 Of course you can always use ordinary, common or garden, pliers to make a perfectly acceptable but not in-line "Z" bend that serves the same function as an in-line one. The only real difference is cosmetic. Quote Link to comment Share on other sites More sharing options...
Keith Billinge Posted August 3, 2023 Share Posted August 3, 2023 On 24/07/2023 at 08:55, Nigel R said: Â Dead easy really: Â Measure the length of rod you need. Subtract 5/16. Put edge of pliers at that point. Bend. Done. Â Â Is that 5/16 or 7.9mm? Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted August 4, 2023 Share Posted August 4, 2023 8mm - 2 thousands of an inch,,,😊 Quote Link to comment Share on other sites More sharing options...
Nigel R Posted August 4, 2023 Share Posted August 4, 2023 split the difference? Quote Link to comment Share on other sites More sharing options...
Simon Chaddock Posted August 4, 2023 Share Posted August 4, 2023 If you keep the link rod short (servo near the control surface?) you can use soft 'paper slip' wire. You can then make a small 'inline' Z bend using needle nose pliers. If is not quite inline it is easy to bend it so that it is.  If you get the length wrong you can always make another, paper clips are cheap. Not suitable for everyone but it suites my 'small & light' principles  Quote Link to comment Share on other sites More sharing options...
