Scruffmeister Posted February 27 Share Posted February 27 I am trying to build up the courage to use Super 'Phatic glue to secure the "CA" hinges in my current build (a 60" electric 3D/aerobat). The testing I have done with scrap wood and hinges has been successful and the joint seems very strong. The wicking properties are evident and can be seen in the top half of the hinge in the attached photo. However, I am unsure of the long term properties of the joint when subjected to constant flexing in this environment. If you have been using Super 'Phatic (or indeed any aliphatic) glue for "CA" hinges, please could you let me know your experiences, failures and longevity? Thank you! Quote Link to comment Share on other sites More sharing options...
Philip Lewis 3 Posted February 27 Share Posted February 27 I've always used aliphatic glue to glue on those hinges, CA can grab too quickly and allows minimum time for repositioning accurately whereas aliphatic gives you plenty of time to position exactly where you want, the fact that it wicks i.e. is a creeping glue to me seems to make it the perfect choice. Been doing that now for well over ten years on planes that have hundreds or even thousands of flights and haven't had a failure yet an that is on 2 meter aerobat's and 60CC gassers, constant flexing isn't a problem because you aren't flexing the glue. Quote Link to comment Share on other sites More sharing options...
Scruffmeister Posted February 27 Author Share Posted February 27 Thanks @Philip Lewis 3. Out of interest, do you take the approach of wicking the glue just as you would with CA, or do you coat the hinge itself before inserting into the slot? I'm finding that Super 'Phatic doesn't give a huge amount of time to reposition with balsa/flock so juts perfecting my technique! Quote Link to comment Share on other sites More sharing options...
Philip Lewis 3 Posted February 27 Share Posted February 27 (edited) Bit of both, squeeze some glue into the joint and also lightly coat the hinge, insert and wipe away excess with a damp tissue, also it doesn't bloom like cyno. I don't use Super Phatic just aliphatic from Deluxe Materials, you don't get time to hang about but time is sufficient to accurately align an aileron with the rest of the wing in my experience. Obviously make sure to give it a good pull test. Edited February 27 by Philip Lewis 3 Quote Link to comment Share on other sites More sharing options...
Nigel R Posted February 27 Share Posted February 27 4 hours ago, Philip Lewis 3 said: I've always used aliphatic glue to glue on those hinges, CA can grab too quickly and allows minimum time for repositioning accurately whereas aliphatic gives you plenty of time to position exactly where you want, As far as I know, the flocked hinges are inserted first, you get everything all lined up in place, and only then you drop CA onto the hinge to fix it all in position. There's no 'repositioning' going on...? 1 Quote Link to comment Share on other sites More sharing options...
leccyflyer Posted February 27 Share Posted February 27 I suspect that Pacer Hinge Glue is essentially aliphatic and their advice is to fill the pre-cut slot with glue then insert the hinge, which has worked fine for me. I have a heepodeemic nurdle on the bottle spout and insert that into the hinge cavity until a line of glue appears at the hinge line, then Insert the hinge, put a smear on the half of the hinge that is left sticking out and a squirt into the hinge slit on the control surface then bring them together, wiping away any excess that seeps onto the hinge line.. Quicker to do than to write out and avoids having to use CA, which is a real bonus for me. Quote Link to comment Share on other sites More sharing options...
Nigel R Posted February 27 Share Posted February 27 5 minutes ago, leccyflyer said: Pacer Hinge Glue is essentially aliphatic ...but may dry to a more rubbery consistency, may contain something to etch nylon, etc. maybe not "just aliphatic" ? 🙂 I use the stuff on those thicker nylon hinges (without flocking) in much the same manner you describe (fill the slot, then insert the hinge) - it has never failed me. I have destruction tested a couple of test pieces - and both times the nylon hinge ripped before the wood / hinge joint would let go. Quote Link to comment Share on other sites More sharing options...
leccyflyer Posted February 27 Share Posted February 27 Please don't misquote my post Nigel. Quote Link to comment Share on other sites More sharing options...
Scruffmeister Posted February 27 Author Share Posted February 27 Thanks @Philip Lewis 3, much appreciated. Quote Link to comment Share on other sites More sharing options...
FlyinFlynn Posted February 28 Share Posted February 28 You could always use something like this hinge drilling jig to make a hole, then slot it with a slotting jig. that way the glue will have an easier job penetrating all the way down to the bottom of the spar. Quote Link to comment Share on other sites More sharing options...
Nigel R Posted February 28 Share Posted February 28 19 hours ago, leccyflyer said: Please don't misquote my post Nigel. OP is asking about aliphatic and you're talking about something else. That said - I'm not sure how I'm misquoting your post, I quite literally pressed the 'quote' button. I'm not even trying to argue your point, rather I'm agreeing with it. No offense intended. Quote Link to comment Share on other sites More sharing options...
leccyflyer Posted February 28 Share Posted February 28 3 hours ago, Nigel R said: OP is asking about aliphatic and you're talking about something else. That said - I'm not sure how I'm misquoting your post, I quite literally pressed the 'quote' button. I'm not even trying to argue your point, rather I'm agreeing with it. No offense intended. I said " I suspect that Pacer Hinge Glue is essentially aliphatic....". You edited the quoted post to remove the qualifier, that I had precisely inserted to preface the point I was making. That changes the point and makes it look like an assertion on my part, which it is not. It's simple quoting etiquette not to misrepresent by omission, a post which is clearly a qualified statement.. Quote Link to comment Share on other sites More sharing options...
Nigel R Posted February 28 Share Posted February 28 Ok. Sorry about that. I didn't intend to alter the meaning of your post from hypothesis to assertion. 1 Quote Link to comment Share on other sites More sharing options...
leccyflyer Posted February 28 Share Posted February 28 No problem, there isn't anything vital hinging on it ;). Thanks. 1 1 Quote Link to comment Share on other sites More sharing options...
David Davis 2 Posted March 5 Share Posted March 5 I have been impressed by the qualities of De Luxe Products "Super Phatic" glue when building a new wing for my Baron. I am simultaneously building a Galaxy Models "Mystic" and have reached the stage where I am hinging the control surfaces. I am using large Kavan pinned hinges on this model which will be powered by a Laser 155. https://www.slecuk.com/accessories/hinges/kavan-heavy-duty-pin-hinge-10-per-pkt. In the past I have always used epoxy to glue hinges to the airframe after applying a little grease to the pivot. Do you think that Super Phatic would be suitable for the hinges in this installation? Quote Link to comment Share on other sites More sharing options...
Don Fry Posted March 5 Share Posted March 5 I’ve got a pot of that, very good glue, and I’ve used it for hinges . Rubbery glue=tough. But, being a bloke wot has been round the block, you know the answer, 5 minutes to make a test piece, dry it for a day, and break it. Then YOU know, one less fail point. Quote Link to comment Share on other sites More sharing options...
David Davis 2 Posted March 5 Share Posted March 5 Good idea. Quote Link to comment Share on other sites More sharing options...
David Davis Posted March 11 Share Posted March 11 Today's my seventy-sixth birthday, lots to do so I don't have much time but herewith the results of using De Luxe Materials Super Phatic glue with large Kavan pinned hinges as suggested by Don Fry above. These will be used on my Laser 155 powered Mystic. Slots were made into two pieces of scrap 1/4" (6mm) balsa. Five drops of the glue were put on each face of each leaf of the hinge and the two pieces of wood were pressed together. Having left the joint to dry for more than 24 hours I found it impossible to pull the two pieces of wood apart. Normally I put some form of grease on the fulcrum usually butter but this time I did not bother. The hinge moves freely and I did not add cocktail sticks or dress makers' pins. I have used this glue extensively in the build of the new wing of my Baron and have been very impressed by it. 2 1 Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted March 11 Share Posted March 11 Happy Birthday DD 🎂🎁🎈 Quote Link to comment Share on other sites More sharing options...
David Davis Posted March 11 Share Posted March 11 2 hours ago, Ron Gray said: Happy Birthday DD 🎂🎁🎈 Thank you Ron. Quote Link to comment Share on other sites More sharing options...
kc Posted March 11 Share Posted March 11 Happy Birthday - and it might be best to get the Moderators to remove exact details of your birthday! Date of birth is so often used as a password that it might cause problems if too many know it...... Could be a good idea to 'pin' the hinges on a fairly large model to be really safe. Quote Link to comment Share on other sites More sharing options...
Geoff S Posted March 11 Share Posted March 11 I wrote off the fuselage (amongst other things) on my ARTF Wot 4 a few days ago. The wing is almost undamaged but one of the ailerons came out, complete with the hinges, as did the rudder. It's 5 years since I assembled it, but I think I used cyano. When I build a model, I always pin the hinges with cocktail sticks (about 2mm dia), as it was an ARTF I used what is supposed to be standard practice but in extremis the hinges came out. I never had any issues with the flying until the ultimate test and, when checked, the ailerons and rudder seemed firmly attached. Personally, if I were building the model, whatever glue I used I'd pin the hinges. Quote Link to comment Share on other sites More sharing options...
